Holset users unite!
Old Jun 28, 2010 | 10:54 AM
  #3051
extremeracer's Avatar
Default Re: Holset users unite!
Originally Posted by GsrRussell
How can I determine which housing I have on my HX40?
It is stamped on the inside of the turbine housing just below the flange
eg : 14/16/17/18
Old Jul 1, 2010 | 11:59 AM
  #3052
deeweezy187's Avatar
Anybody want to buy a holset h1c or trade for a t3/t4?
Old Jul 2, 2010 | 04:45 PM
  #3053
KaoticBrd's Avatar
This thread makes me want a Holset! Anyone have or know where to find a list maybe of what trucks these come from. I'm lookin for a HX40 or HX50. It would be easier to know what they come from when i get looking around.
Old Jul 5, 2010 | 03:58 PM
  #3054
projcrxday's Avatar
hey holset masters!!! lol, well im jumping on the holset bandwagon again for the second year, last year i was running and hx35w on my ek b16 hatch, i fell in love other then my traction issues with it hahaha... long story short had to sell the hatch to get into a house. so i thought it would be time to resurrect my very first honda thats been sitting for some years now a 90 crx, i picked up a b16a2 from a 2000 civic si with only 90k on it, i will be running a similiar setup to my ek hatch but with an hx40 i just picked. here are some quick pics i took before i left work, i shaved all the markings i could from the intake side and will be sending the hotside and manifold off to get a fresh new ceramic coating and polished intake compressor, i will keep you posted with pics hope you guys enjoy
also i am going to try something a little different then i did with my hx35w last year i did just a mild port on the exhaust side to see how much it would increase flow and eliminate some of that lag time it worked very well to my suprise, so with this hx40 i went alot farther with the port work to i gasket matched it and am going to try a knife edge on the center section since i will be useing a single port manifold rather then a twin scroll. i will keep you updated with progress, as of right now the ports are rough cut and still need cleaning.
Old Jul 5, 2010 | 04:43 PM
  #3055
catsman50's Avatar
does anyone know of a sohc setup running a h1c with a 16cm housing? Planing on doing a setup on my stock y8 this winter with that turbo at 15psi.
Old Jul 5, 2010 | 06:28 PM
  #3056
da_dude's Avatar
^ I believe dr.d-series is running the same turbo.
Old Jul 8, 2010 | 10:00 AM
  #3057
projcrxday's Avatar
ive got a few buddys running the h1c turbos on there sohc motors, one is built and other is stock. they love that turbo.
Old Jul 8, 2010 | 11:34 AM
  #3058
ReDemoN's Avatar
DixielandImports Please
I have a H1E which I believe is close to the H1C.
The damn thing LOVED 25lbs.
And wanted more.
Old Jul 8, 2010 | 09:49 PM
  #3059
98integralsB18's Avatar
hey i just got a hx35 for my ls-t. i just built the bottom end no head work. but i was wondering about oil restrictor. what size or what will i need for my oil line. I'm using -3 an right now but i don't know if that will be to much pressure or not. thanks
Old Jul 10, 2010 | 09:49 AM
  #3060
young geezer's Avatar
ok so i bought a hx35w the other day and i know they come from the newer once 00-02. and i also know they are suppose to have 7 blade but mine has 8 blade. so i just want to know if mine is the newer once or older once.
Old Jul 10, 2010 | 11:57 AM
  #3061
i am also using a external wastegate and was wonding if i need to weld shut the internal wastegate hole? thanks.
Old Jul 10, 2010 | 02:18 PM
  #3062
Gold DA9's Avatar
weld it shut.
Old Jul 12, 2010 | 09:32 AM
  #3063
catsman50's Avatar
sweet! my plan is to run 15psi on a stock motor. I'm going to be running a 16cm housing and a 4" exhaust
Old Jul 12, 2010 | 12:04 PM
  #3064
slowhitEJ1's Avatar
z6 with Vitaras, FJ spec rods, 59300, crower springs and retainers, twin scroll manifold, hx35 with a 12cm housing, 3" open down pipe. this is at 14psi and a street tune. the next two pulls i did 237hp/193tq and 242hp/198tq. thought i'd throw in some info for the guys that want to run one of these on a D.
Old Jul 12, 2010 | 02:22 PM
  #3065
da_dude's Avatar
^ Shouldn't it be making more power?
Old Jul 12, 2010 | 02:42 PM
  #3066
wantboost's Avatar
Who is Mr Robot?
Everything about holsets, from compressor wheel sizes, to turbine wheel sizes, wheel differences, model differences and spotting models...
http://www.turbo-mopar.com/forums/vb...&articleid=122
another good read
http://turbobyholset.com/forum/gener...info-everyone/
Old Jul 12, 2010 | 03:04 PM
  #3067
slowhitEJ1's Avatar
cam at 0*, ignition turned to 16*, it was only for drivability, not for power... the reason for my post was more so to show the curve and when i hit boost, rather than the power. thanks for you concern though
Old Jul 14, 2010 | 04:30 PM
  #3068
LS AzZkIkr's Avatar
Hey projcrxday! I was wondering if you could elaborate on the benifits of porting your turbine housing? I am thinking about doing the same to mine and would like to know some people's experience with this.
Old Jul 15, 2010 | 12:16 AM
  #3069
Gold DA9's Avatar
hoping to pick up a Holset this weekend.. needs rebuilt, but i think it will be worth it.
Old Jul 20, 2010 | 09:22 PM
  #3070
i am also thinking about porting out the divider sharper but i am more leaning on buying a new exhaust housing from BEP or something like that. can anyone point me to the right place to buy it from and which one should i get. i want one with out the divider one. thanks guys.
Old Jul 20, 2010 | 11:32 PM
  #3071
Gold DA9's Avatar
sending you a pm.
Old Jul 21, 2010 | 08:29 AM
  #3072
where you guys got the v band for these turbo. all the one that i found dont line up with these.
Old Jul 21, 2010 | 10:34 AM
  #3073
ashb82's Avatar
I welded a 3 inch v-band to my flange.
Old Jul 23, 2010 | 12:09 AM
  #3074
Gold DA9's Avatar
b-series guys.. On the HX35s when are you seeing full boost and how much boost are you running? Also please state which size housing you have.
Trying to get an idea of what spool would be like on my GSR with a log manifold... Thanks.
Old Jul 23, 2010 | 04:33 AM
  #3075
DS00ITR's Avatar
i did the same. worked well
