Holset users unite!
Old Dec 17, 2009 | 12:02 PM
  #3001
Gold DA9's Avatar
Default Re: Holset users unite!
If I go turbo I will definately be picking up a holset. Right now just running a JRSC on my GSR.
Old Jan 11, 2010 | 01:40 PM
  #3002
sadmind's Avatar
how can you compare hx30 to hx35 to hy35, for 2lt engine, i search for fastest spool possible, and 400bhp~
Old Jan 11, 2010 | 05:20 PM
  #3003
912's Avatar
912
go to dsmtuners.com great holset info in forced induction sec theres a holset sticky
Old Jan 14, 2010 | 10:00 AM
  #3004
AccordtypeT's Avatar
What whp and what spool can I expect form a Holset,WH1C who came from of a Cummins diesel 1994 Dodge Ram 2500 , on a h22a1 forge with a port and polish head, cause may be i have a deal on it
Old Jan 15, 2010 | 04:01 PM
  #3005
Old Feb 2, 2010 | 07:46 PM
  #3006
marcj's Avatar
just wondering, does the HX30 turbine housings swap onto the hx35 and/or h1c ??
Old Feb 10, 2010 | 05:35 PM
  #3007
loch's Avatar
just put an hx35/12cm on my 4g92 mivec engined Lancer with the following specs
1600cc fuel injected mivec 4g92 engine
forged stock bore 4g93 wiseco pistons
stock head and gasket
acl mains and cons
stock cams
xs power ramhorn b16 manifold modified for the mitsubishi 4g92 engine
tial 38mm waste gate
hallman mbc
780cc precision injectors
megasquirt 1 v3
according to datalogs car makes positive pressure in 1st gear from 3800 rpm and 1st gear gives around 9 psi
2nd gives full 15 by 4200 rpm
planning to run 24 psi on this engine soon with water meth
sorry no dyno figures or timeslips yet
thanks to projectdc2 for the turbo, it
Old Mar 11, 2010 | 03:05 AM
  #3008
AfroIntegra's Avatar
Finally bought myself a HY35. Found it on Cumminsforum, lol. Definitely not bad at all, I'm excited to run it. Took the housings off the other day, wheels look bueno, so I'm going to clean everything up, weld the WG flapper, and slap it back together. Here she is in all her glory:
I have no idea what is all over the compressor:
Old Mar 15, 2010 | 12:20 PM
  #3009
DS00ITR's Avatar
wondering if a h1c is enough or if i should get a hx35. anyone using the h1c. lookin to make around 350 hp on a stock internal ls vtec with arp rod bolts and head studs. been looking for a wile and keep finding the h1c cheap. originally i was looking for a hx35
Old Mar 18, 2010 | 02:29 PM
  #3010
912's Avatar
912
if shooting just for 350 go with hy35 great sreet turbo, or all around turbo at that
Old Mar 18, 2010 | 05:36 PM
  #3011
deeweezy187's Avatar
i have an h1c and wanted to know if it will still work with a single scroll manifold?
Old Mar 18, 2010 | 06:56 PM
  #3012
DS00ITR's Avatar
thanks i actually just picked up a hx35 for a good price. going to try that for now if its too big i guess ill try and find a hy35. not really worried about the spool time mostly track and weekend driver.
Old Mar 20, 2010 | 04:02 AM
  #3013
Marc_Smith's Avatar
Q: Is a oil restrictor needed. btw: I got a HX35.
thx.
Old Mar 28, 2010 | 08:41 PM
  #3014
dbsharp's Avatar
I would also like to know what size oil feed restrictor most are using. I would really like to hear from those that have an oil pressure gauge at the turbo. What kind of pressure have you seen with what oil restrictor size?
Old Apr 5, 2010 | 06:53 PM
  #3015
DS00ITR's Avatar
i would also like to see what people are using as a restrictor. i have read through alot of these pages and some people say use on some say you dont need one but no one ever says what size restrictor or what pressures they are getting.
Old Apr 5, 2010 | 07:26 PM
  #3016
Garage 808 Hatch's Avatar
FYI we made 470whp on an HY35 on 18psi with an 84mm B16. On 92oct
Old Apr 7, 2010 | 12:40 AM
  #3017
SwappedTURBOegg's Avatar
wow i forgot all about this thread
Old Apr 7, 2010 | 12:42 AM
  #3018
Default Re: (slowhitEJ1)
which turbo is that, looks like h1c, ne way i just gat hx35 i have a spa top mount, people,with hx35 what other exhaust housing is there for the hx35,when i took off the wastegate acuator all that mounting point for acuator is ugly, i either want to grind off or find a replacement, was thinking bout the h1c housing cause its nice and smooth, ne suggestions, my reasons are because of my top mount, i know the 14cm housing spools great on b-series just look like **** when running top mount?
that was an HX52
Old Apr 7, 2010 | 02:29 PM
  #3019
B and B's Avatar
Loved
Community Favorite
Yes.
No need for an oil restrictor. Mines fine with a new GSR/ITR oil pump.
GE oil filter feed with Fastturbo line.
Old Apr 18, 2010 | 11:57 PM
  #3020
Marc_Smith's Avatar
I finally installed the HX35 in my EG, I build a selfmade oil restrictor out of a wheel bolt from a VW weldened with a 1/8" fitting for the oilfeed. Works perfectly. Get a tune this week. The spool sound scares me^^ Love it.
Old Apr 22, 2010 | 08:54 AM
  #3021
alloutmotor's Avatar
i have a t3 16cm^2 hx40 exhaust housing if anyone is interested went bullseye
Old Apr 25, 2010 | 08:28 PM
  #3022
joppe's Avatar
Does anyone know if u can change exhaust housings hy35 9cm to he341 8cm? I have hy35 9cm now and if i can put he341 in that exhaust housing i dont need to make new downpipe..
Old Apr 26, 2010 | 05:04 AM
  #3023
i have an h1c and recently bought a turbo manifold that isn't twin scroll will that hurt my performance?
Old Apr 27, 2010 | 09:24 PM
  #3024
battlecrxT's Avatar
So I picked this up for dirt cheap. Its a HX40. Does anyone have a 12cm housing for this monster?
Old May 9, 2010 | 04:12 PM
  #3025
my car is holset powered again!!!!!! hx52 k20a
