Holset users unite!
Old Jul 1, 2007 | 05:24 PM
  #1801
slowhitEJ1's Avatar
Default Re: (preveink)
ok.. kinda new to this holset thing.. apparently about 2 years behind by the start date on the thread, but it's cool.. anyways.. i'm lookin to make about 300-350 on a z6 with vitara pistons and i've got everything else figured out except for the manifold and the turbo.. my setup so far includes
Z6 block and head
vitara pistons
eagle rods
tial 38mm wastegate
greddy type s bov (probably)
treadstone intercooler (egay)
Zex 59300 Cam
stock valve train (for now)
stock IM
so.. here's where i'm stuck.. i've been thinkin that either an hx30 or an hy30 would be best, but due to a seemingly VERY limited availability, i'm looking at other alternatives.. would an hx35 be too much/big?? also.. i read till about page 40ish or so but didn't find much on the D series half of the field.. also, decent quality manifold to spool that bitch would be nice (by decent i mean <<< full race, << 600 dollars, > SSAC.. suggestions would be great.. thanks guys
(hoping "newb" flaming won't erupt)
Old Jul 1, 2007 | 06:39 PM
  #1802
Joseph Davis's Avatar
Default Re: (slowhitEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowhitEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">would an hx35 be too much/big?? also.. i read till about page 40ish or so but didn't find much on the D series half of the field.. also, decent quality manifold to spool that bitch would be nice)</TD></TR></TABLE>
You either want to pair cylinders for an HX35, or run an HY35 with a traditional single turbine inlet manifold.
You should run a regular old fashioned log, IMO. Nothing spools a turbo faster, and it is HT's favorite manifold by a large margin: https://honda-tech.com/zerothread?id=2008014
You might also consider a different turbo entirely, HX/HY35's are pretty big (and HX30 are freaking tiny) unless you are looking for a drag racing powerband. Unless you're a good driver it might be a bit laggy on the street.
Old Jul 1, 2007 | 07:32 PM
  #1803
slowhitEJ1's Avatar
Default Re: (Joseph Davis)
haha.. just the person i was wanting to reply lol.. "expert" come to mind??
yeah.. anyways... i was considering a 50 trim T3/T04E for this, but no one can give me a straight answer on that either.. some people say "oh yeah.. that's THE turbo you want.. nothing else" then others say, "you're an idiot.. why would you want something like that?? you should get a xxxxx" and it just goes from there..
with my lack of experience, and it being obvious that everyone has their own opinions based on THIER experiences, i don't know what i want/need and there are NO turbo single cam's ANYWHERE near me that i know of that i would be able to compare some different setups, only a SSAC b20, and a 600+hp 60-2 powered GSR hatch, and a 550+ hp coupe..
i've been looking at the log manifolds and with the price and the spool times, i think that's what i'll be goin with.. it wouldn't be a daily driven car, so the streetability wouldn't be a huge factor to me.. i know i probably shouldn't ask this because of some rule or another, but what do you think it would hit full boost at? also, i understand that the hy35's like to be around 20 or so psi.. would that be acceptable for this setup?? fjt was running like 32 psi on his right (i know that's way above what i want to make, but just saying..) i would say i'm decent, certainly not the best, but i've had people that have reputations of being EXCELLENT drivers in my area tell me i'm damn good but i'm not one to boast myself up nor does "some guys" opinion really matter.. thanks for your time and i apoligize for the hella long post.. (i would pm you but i can't)
Modified by slowhitEJ1 at 9:00 PM 7/1/2007
Old Jul 1, 2007 | 07:58 PM
  #1804
Never had a Holset on a single cam to say, but a .50 T04E with a stage three .63 AR turbine is a fine turbo. For a log mani it'll start to spool at 3000 and have 8-10 psi by 3500 with lightning spool from there.
You get a few hundred rpms slower spool with one of the tubular manifolds, typically, but sometimes those spool just as quickly if not quicker than logs. Manifold dynamics can be really strange.
Old Jul 1, 2007 | 08:04 PM
  #1805
slowhitEJ1's Avatar
ok cool.. i was just looking at these because of the affordability of them.. and they're used on millions of factory motors for SOME reason so i figured they would be somewhat more reliable than something else.. but at this moment i realize i'm talking about reliability with a turbo sohc.. lol.. go figure.. i'll keep lookin into it.. i'll probably PM you sometime in the near future. thanks Mr. Davis..later,
Old Jul 1, 2007 | 08:08 PM
  #1806
I like the Holsets because they are big shaft OEM turbos and last a good long while.
You get comparable results out of Garrett turbos, as well, although the T04/T3 units tend to have shorter lifespans since the T04 wheel is heavier than the T3 shaft/bearings were designed for. You still get tens of thousands of miles out of them, and they are the best bang for the buck for someone who can't afford/build the custom manifolding required to fit a bulky HX35 into their engine bay.
Old Jul 1, 2007 | 08:55 PM
  #1807
SwappedTURBOegg's Avatar
WOOOT!! i just bought a 60mm inducer HX40 NEW with ULTRA RARE 16cm housing.
any one wana buy my H1E with 18cm housing i get boost at 5k
Old Jul 1, 2007 | 09:01 PM
  #1808
heres a stupid 2 second vid of my car with the H1E
http://smg.photobucket.com/alb...9.flv
Old Jul 5, 2007 | 09:37 AM
  #1809
doubleA's Avatar
Default Re: (SwappedTURBOegg)
turbine housing for sale!
http://cgi.ebay.com/ebaymotors...wItem
Old Jul 6, 2007 | 05:59 AM
  #1810
Root79's Avatar
Default Re: (doubleA)
Realy sorry for advertise. Don't kill me.
For sale Holset HX35, little bit used ~600km.
Pm me.
Old Jul 6, 2007 | 03:21 PM
  #1811
sq_creations's Avatar
Default Re: (Root79)
just bid on it.
so here is my experiance so far. I just killed my sc61 and came accross my buddy's H1C he took off his cummin's . I picked it up for 100 bucks. Im running a b16 with wiesco gsr pistons (aprox 8.2:1) with eagle rods, stock sleeves and stock b16 head with gsr cams 750cc injectors hondata s300 3.5bar zeitronix map and wb. Now my sc61 would hit full boost (18psi pump 30 race) about 6k 1&2 and 4500 in 3&4 gear so im use to lag. I took out the H1C with a 18cm housing and it hit 12psi at 8500 (red line) in 1st, 20 psi at 7500 in 2nd, a 24 psi at 6500 in 3rd That is on a 18psi spring no boost controller. I plan on getting a smaller 12 - 14 cm 2 housing then will take it to the dyno. My goal is to hit 400+ whp. Im at a little disadvantage because I live 5600 ft above sealevel though.
Here are some of the useful links i have found in all my research. It never hurts to duplicate Imo.
http://www.htturbo.com/th.htm
http://www.theturbotrader.com/...49_22
http://www.ftlbperformance.com/hx35.html
http://www.goldfarbinc.com/index.html
http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
http://www.dsmtuners.com/forum...45691
Old Jul 6, 2007 | 04:17 PM
  #1812
LoSt is BlaCk's Avatar
Default Re: (sq_creations)
good info
Old Jul 6, 2007 | 04:36 PM
  #1813
spoolin turbo s's Avatar
Default Re: (LoSt is BlaCk)
what holset will support 500 whp?
what holset will support 500whp?
when will each of these spool?
Old Jul 6, 2007 | 04:37 PM
  #1814
Default Re: (spoolin turbo s)
when does each holset spool on a 1.8?
Old Jul 6, 2007 | 06:58 PM
  #1815
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin turbo s &raquo;</TD></TR><TR><TD CLASS="quote">what holset will support 500 whp?
when will each of these spool?</TD></TR></TABLE>
We heard you the first time.
hx35 with the 12cm housing and if you read this thread you will find numerous times where drumking has stated exactly where the turbo will spool on a 1.8L engine.
Old Jul 7, 2007 | 09:01 AM
  #1816
Default Re: (KeyserSoze)
Exactly where a turbo spools depends on the manifold as well. And I am NOT talking about paired cylinders, although that helps a LOT.
Old Jul 7, 2007 | 10:25 AM
  #1817
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">We heard you the first time.
hx35 with the 12cm housing and if you read this thread you will find numerous times where drumking has stated exactly where the turbo will spool on a 1.8L engine. </TD></TR></TABLE>
hahaha i know...i post it numerous times w/ stock exh #'s...open dp etc....go back to page like 20....and start reading
Old Jul 9, 2007 | 06:09 AM
  #1818
j-spec_cc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">WOOOT!! i just bought a 60mm inducer HX40 NEW with ULTRA RARE 16cm housing.
any one wana buy my H1E with 18cm housing i get boost at 5k </TD></TR></TABLE>
how much you looking for? for the life of me i can't find a compressor wheel for my h1e and it seems like my only choice might be to just buy another h1e until a compressor wheel becomes available.
Old Jul 10, 2007 | 12:01 AM
  #1819
Default Re: (j-spec_cc2)
i sold it to anothe rguy on here already. my 40 came in today so ill be shipping his tomorrow. woot for holsets
Old Jul 14, 2007 | 11:57 PM
  #1820
deeweezy187's Avatar
Is anybody running a h1c on a spoolin performance manifold?
Old Jul 15, 2007 | 07:51 AM
  #1821
preveink's Avatar
ive got a a good hx35 center section $50.00 new compressor wheel for a h1c and housing to match it $150.
also have a wh1c compressor housing which has some small scratches from the fan blade hitting it , perfect if you want to make a hybrid with a hx55 wheel.
Old Jul 17, 2007 | 10:19 AM
  #1822
I got the manifold today and left you some feed back. I'll be putting it on tonight. Ill let you guys know the comparsion between the 18cm and the 12cm soon.
Old Jul 17, 2007 | 10:40 AM
  #1823
Si Shane's Avatar
Everyone has problems w/ the 9cm^2 housing at high flow. This holset 3 series seems like a double edged sword. I've come near the limit of 91 octane + my tuning skillz + my hy35 setup and it is nowhere near maxing the turbine out, pulls all the way to redline.
I would love to get on a dyno with some race gas and see what the hy35 can do for me, but that wont happen anytime soon. I wouldn't want this turbo to spool any slower yet it seems silly to run the smaller housing with the large compressor. If I did it again I would do paired cylinders on a 12cm^2 to get similar spool while taking advantage of the compressor.
Old Jul 17, 2007 | 11:53 AM
  #1824
Tjabo's Avatar
Default Re: (Si Shane)
What's your engine and manifold setup?
Old Jul 17, 2007 | 12:26 PM
  #1825
Euro-Trash's Avatar
Default Re: (Tjabo)
this seams to be the biggest import oriented and most informative holset thread ive found online so i figured i would ask a few questions.
i have a VW vr6 motor 2.8, and im thinking about getting either an h1c or possible a hx40 to run on it. A lot of people i know use gt40s and gt42rs on there vr6's and im wondering what i could expect from either one of those holset turbos.
i know i probably sound like a noob but im new to this whole holset thing, wondering if anybody had compressor maps for either one of those..
thanks for the info so far
