Holset users unite!
Hey guys im in the process of building my 2nd monster sohc the setup consists of the following:
D16z6
stock bore vitaras
fj h beams/arp 2000s
acl bearings/npr rings
arp head studs
hx35w turbo
td autowerks top mount mani
38mm tial wg
2.5in charge piping
3in dp
z6 trans, welded diff
xtd stage 4 clutch
aem w/b, autometer boost
now for fuel ive got a few questions my power goal is mid 400s at 20-25psi, what size injectors would be sutable? im thinking around 800cc's or so im also going to be using 255 pump and im undecided if i want to use ectune or the program fj sells, im going to be self tuning this one and im looking for user friendly ****
questions or comments would be awesome
D16z6
stock bore vitaras
arp head studs
hx35w turbo
38mm tial wg
2.5in charge piping
3in dp
xtd stage 4 clutch
Hi, does anyone knows the partnumber of a HX35 V-Band non wastegated turbine housing with 12ccm like this
http://www.gillettdiesel.com/12cm2no...nehousing.aspx
Been reading this thread for over an hour! I'm picking up a good condition HY35 to go on my stock 97 LS Integra. What turbo manifold would work with this? I want something that will keep A/C and P/S.
Hy there i got hx35/40 hybrid whit fitted .58 t3 housing from yiyito turbo service on my y8 hatch and it pulls realy hard i hope this help for you guys im waiting for bisi 3.6 cam to hit the dyno. last dyno pull was 361whp at 24 psi on 93 octane on dynojet whit ebay turbo, for now do a street tune at 25-26 psi and the wheel spins are insane . i love this turbo i got full boost at 5000.
I am working on a hx35/he351vgt hybrid. I am using the compressor wheel out of the he351vgt. It is the same size as the hx40 has 7 blades and is billet from what the guys from holset say.
Hello everyone. i would like to know what stud bolts you guys used and what bolts you used and what were there Grades because everywhere i go they are all 8.8 metric and i want to see if its holding it down for you guys that have hx35 and hx40. also since i literally looked at every 125 pages of this thread i say everyone is an inspiration to make me run my HX40 turbo. HOLSET FTW!
My HX40
Its going in my project Dmn
My HX40
I have a good question does the weight of the turbo have a huge impact on the turbo manifold on the exhaust studs to the block? My hx40 weight about 35 pounds and i kinda want to build a custom support beam to help with the weight of the turbo. i seen a b series honda with a hx40 and ive also seen one guy on here with a hx52 but im using a cast iron manifold and i determine that to be very strong since it comes OEM on diesel trucks and even my old car (evo 8)
Hi, I have this turbo and it's apparently ok but I see that 3 blades seems to be 0.5mm higher than the rest. They don't seem bent and spins freely. What do you think? The machined sides seem to be ok.
http://www.youtube.com/watch?v=GvAKeMA2zoI
i wanna see those pictures... and we can't let this threat die man... i just got my hands on 2 brand new holsets... one is an hx35 and the other is an hx40 both brand new.. for the greatest price ever... lol
I am working on a hx40/hx50 hybrid next 66mm 7 blade
I bought it like that i just wiped it down with Mobile 1 synthetic oil. but the best polishing product i know is called "Mothers Mag polish" the damn thing is incredible. Im going to paint mine so i dont want to polish it.
