Holset users unite!
finally got the motor in. Holset HX35 on a z6/vitara build with a twin scroll mani. still have to do some vacuum hose stuff, and fab a mount for the radiator
you can see here how the downpipe runs, and why the radiator wont fit in the stock location, and i MIGHT lose power steering but i think i can move the cooler lines out of the way.. opinions?
Will this manifold work on a h1c?
http://www.spoolinperformance.com/sp...69b0f8c1ee243a
You can get everything from a dodge dealer if off a dodge truck. If not you gotta goto a truck place that sells cummins stuff.
As for an oil Feed I found the easy thing to do is to go to the dodge dealership get the factory one and drill the center and tap it for a 1/8npt.
what do you guys think about this turbo. I want to go pick it up but want your guys opinion. Its gonna be for my d16z6 vitara/fjt build
http://lasvegas.craigslist.org/pts/1452717113.html or
http://lasvegas.craigslist.org/pts/1452719083.html
which turbo is that, looks like h1c, ne way i just gat hx35 i have a spa top mount, people,with hx35 what other exhaust housing is there for the hx35,when i took off the wastegate acuator all that mounting point for acuator is ugly, i either want to grind off or find a replacement, was thinking bout the h1c housing cause its nice and smooth, ne suggestions, my reasons are because of my top mount, i know the 14cm housing spools great on b-series just look like **** when running top mount?
so you want a non wastegated housing like these http://www.htturbo.com/thnew.htm
anyone?
need a fitting that is 4an male and m12x1.5 with a restrictor for my hx35 b16 setup. Where can I get one. Or do I not need a restrictor. thanks lmk
12cm^2 = .63 A/R
16cm^2 = .83 A/R
18cm^2 =1.00 A/R
spa top mount, hx35w ,want to upgrade to bep ex housing, and squeez as much as i can from my low mile 99 holset, ps. i havent clocked the turbo or nething yet just wanted to see what it looked like, so sexy all i got to say
