Holset users unite!
Old Aug 29, 2009 | 09:55 PM
  #2951
slowhitEJ1's Avatar
Default Re: Holset users unite!
That's what I'm using on a vitara build with a zex 58300... Only thing different than
most guys is I'm using a twin scroll manifold so hopefully it'll spool faster... Well see soon
Last edited by slowhitEJ1; Aug 29, 2009 at 09:56 PM. Reason: iPhone can't type what I want it to
Old Aug 29, 2009 | 11:27 PM
  #2952
B and B's Avatar
Loved
Community Favorite
Originally Posted by slowhitEJ1
what fitting are you using on the oil inlet on an hx35.. motors built, parts are here, everything is figured out, except this.. please help.. can't find anything
I took the fitting from the Fastturbo kit and one from the turbo to a diesel shop and asked if they had a reducer/adapter to join them. No... but the guy hacked a piece off of one and brazed the two together in 5 minutes.
Old Aug 30, 2009 | 07:15 AM
  #2953
slowhitEJ1's Avatar
I found a -3an to m12x 1.5 fitting online but they eanted 30 bucks .... Figured I could find it cheaper somewhere else and now I wish I'd bought it cuz I can't find the site again...
Old Aug 30, 2009 | 03:47 PM
  #2954
Radyjr's Avatar
whats the best style manifold to run this turbo
Old Aug 30, 2009 | 04:31 PM
  #2955
AJxr's Avatar
divided, tubular, equal length manifold.
Old Aug 30, 2009 | 09:00 PM
  #2956
slowhitEJ1's Avatar
found the fitting to run a 3an line on the HX35 (m12 x 1.5)
http://www.pegasusautoracing.com/gro...D=PLUMADAP12MM
one like this
its not equal length but for my power goals (400-500) itll flow better than a log, and spool better than a ramhorn, and that's what i wanted... its an 8 blade HX35 btw..
Old Sep 1, 2009 | 06:24 AM
  #2957
billman's Avatar
hi, i can get my hands on a hx35 with a 14 turbine housing and a super 40 60/85mm compressor impeller.
how would it flow on a 2.5 liter engine and what hp can i see without excessive backpressure?
thanks
Old Sep 2, 2009 | 04:05 PM
  #2958
billman's Avatar
thanks
anyone???
Old Sep 2, 2009 | 04:36 PM
  #2959
AJxr's Avatar
one like this
everything in that picture gives me a boner....
rc autoworks manifold? looks similar to the one in the dudes avatar.
Old Sep 3, 2009 | 07:12 PM
  #2960
lsd96teg's Avatar
Just thought i'd chime in.......
I just put on an h1c holsett on my gsr, gotta say its a lot of fun! Good power too, i know i shouldnt have but i drove it before tune and around 4k its at full boost and boy can you tell when its there!
Old Sep 3, 2009 | 09:14 PM
  #2961
slowhitEJ1's Avatar
nah its not rcautowerks.. it will be if i ever have another one made though.. I wont give any credit to the guy that did it because i've got compliments on it, and i would hate to send other people to him just to get screwed like i did.. took 9 months and a "lost" turbo before i got this back, and now i have to spend more money to get the two wastegate flanges cut off and rewelded because they wont fit with the turbo's compressor housing, which is the whole reason i sent him the turbo in the first place.. and not to mention the #1 cylinder top stud had to be shortened just to fit the manifold on, and the piping is done is such a way that a nut wont fit on, so i either have to have the whole #1 runner fixed, or run it without a nut..
trying to clock the center section, do all of the bolts need to be out for it to turn or just the metal ring that the bolts go through? not the snap ring, the two peice ring that the bolts go through on the exhaust side.. one bolt is seized and the center section wont turn...
Old Sep 4, 2009 | 01:29 PM
  #2962
lsd96teg's Avatar
Yes you do have to loosen all 4 bolts, even then the housing may not want to clock/turn. Mine did not want to anyways....i took a torch to the housing to heat it up and it came right off.
Old Sep 6, 2009 | 09:21 AM
  #2963
slowhitEJ1's Avatar
Yup worked for me too.. Thanks for the info!
Old Sep 6, 2009 | 07:35 PM
  #2964
notfastenough's Avatar
Holset for sale, click the link thanks!
https://honda-tech.com/forums/texas-ok-la-sales-61/fs-holset-turbo-1g-dsm-bov-turbo-mani-shift-linkage-2640974/
Old Sep 9, 2009 | 04:50 AM
  #2965
turboblack2door's Avatar
i was judt wondering if my setup will net me my 400whp goal
Right now i have evo 8 injectors. will these be enough for 400hp. My setup is a jdm d15b, extended length fjt rods, vitara pistons (.020 over), walboro 255, 2 3/4in ic piping, will have a 3in dp, aeromotive fuel pressure regulator, JGS 40mm wg, CSAddict tubular mani, gm 3bar MAP, chipped and socketed p28
Just some teasers
Old Sep 9, 2009 | 08:37 AM
  #2966
turbohatch96y7's Avatar
Is that an hx 35?
Old Sep 9, 2009 | 08:53 AM
  #2967
yea it is
Old Sep 9, 2009 | 11:52 PM
  #2968
t0n's Avatar
t0n
Hi Guys,
I can get a hold of a brandnew Holset HX35W Turbo.
How would it work on the following setup, aiming for 500/600hp
H22a Engine
- Darton Sleeves
- Arias pistons (9,5:1)
- Custom rods
- ARP head bolts
- ARP main bolts
- Overhauled head
- Ferrea valves
- Supertech valves and retainers
D/P 4" Exhaust 3"
Any dyno's or other information is welcome.
Old Sep 10, 2009 | 02:05 PM
  #2969
b20beast83's Avatar
Is a h1b holset too small for a b16a built motor?
looking for 300-400whp
Old Sep 12, 2009 | 10:37 AM
  #2970
deeweezy187's Avatar
Will i blox turbo mani work with a h1c on b18b1 trying to make 300-320?
Old Sep 12, 2009 | 11:26 PM
  #2971
extremeracer's Avatar
Originally Posted by t0n
Hi Guys,
H22a Engine
- Darton Sleeves
- Custom rods
- ARP head bolts
- ARP main bolts
- Overhauled head
- Ferrea valves
D/P 4" Exhaust 3"
Check which version of the HX35 you can get - you'll need the 7 blade compressor to make over 500 whp. A HX40 or HX40 Pro might be a better bet since you have 2.2l and will be more efficient on the top end because of the bigger turbine !
On a efficient setup a HX40 (60lb/min) can maje close to your 600whp goal otherwise the Pro will have more flow which should get you to 600whp easier !
The HX35 7 blade should make a really responsive 500 whp on your H22 (provided the turbo manifold is a divided firing order setup)
Old Sep 18, 2009 | 09:51 PM
  #2972
AfroIntegra's Avatar
Looking for a HY35 or two, anybody have anything?
Old Sep 19, 2009 | 09:53 AM
  #2973
will a h1c work on a blox or drag cast iron manifold because i kno the turbo has a divided housing. Will that affect the performance.
Old Oct 11, 2009 | 07:50 AM
  #2974
Civic89stdB16's Avatar
whats a hx35 8 blade compressor wheel and 12cm^2 hot side good to. What will it spool at on a stock b16 with gsr cam drag car. thanks
Old Oct 11, 2009 | 01:57 PM
  #2975
also where to get a oil restrictor for my hx35 and what size. need it to work with my female side 4an feed line. thanks
