Holset users unite!
Old Aug 2, 2009 | 08:25 PM
  #2901
Civic89stdB16's Avatar
Default Re: Holset users unite!
hey what housing should I be looking for on the hx35 on the 98.5-07 cummins for what im looking for. the 12cm or the 9cm housing. thanks
Old Aug 3, 2009 | 04:38 AM
  #2902
fmfkid250's Avatar
The 9cm housing is an HY35.
I would try and stick with the 12cm. Since it has such a small compressor wheel.
Old Aug 4, 2009 | 08:28 AM
  #2903
what are the different compressor sizes for the hx35. I dont care about lag because its a drag car. so full boost at 5500 wont kill me. thanks
Old Aug 4, 2009 | 10:02 AM
  #2904
fmfkid250's Avatar
They are all 56mm as far as i know. There is a 7 blade and 8 blade.
I was reaching full boost on a built B20 around 5500 It ended up making 420whp around 22-23psi.
Old Aug 4, 2009 | 11:16 AM
  #2905
big-cat's Avatar
My setup is finally up and running. pulls like a ****. right around 18psi or so(broken gauge and tuner is out of town but he said it was safe to turn up to 20). Cant wait to put it on the dyno. I think my 2.5in full exhaust is holding me back a bunch but we will see. I'll up load some pics later or something.
but I have a new oil leak and can not figure out where its coming from. has nothing to do with turbo parts though. think its oil pan gasket. =( have kind of **** vid on youtube from my friends camera. just type in holset d16 and vid 1 imo is the best one.
LSD is amazing. I have no tire spin at all with some **** tires too
Old Aug 4, 2009 | 11:57 AM
  #2906
welfarepc's Avatar
ran 12.5 before the tune, hitting the track again this friday! (update: ran 11.9 @ 114.3)
HE351CW 4in down pipe to now a 3inch under axle exh
Originally Posted by welfarepc
got a pic
Old Aug 4, 2009 | 07:15 PM
  #2907
big-cat's Avatar
http://www.youtube.com/user/catsman7.../1/k0qsDDzbRRw
http://www.youtube.com/user/catsman7.../0/U9MDyFCRck4
vids dont do any justice besides my scared little brother. its around 17psi and hooks(thanks LSD ) its tuned but when my tuner gets back we are going to bump it up to around 22 and dyno tune it. I really want 350whp. but I think my 2.5in exhaust may hold me back....
Old Aug 4, 2009 | 07:51 PM
  #2908
Otis37's Avatar
hey big-cat, when are you seeing full spool by?
Old Aug 4, 2009 | 07:53 PM
  #2909
big-cat's Avatar
with my 2.5in exhaust around 5500 or so. need more boost and a 3in exhaust
Old Aug 6, 2009 | 01:47 PM
  #2910
turbohatch96y7's Avatar
I need some help i want to buy a holeset. I read that a hx model would be good but what about the H1c. I have a gsr with a small t3/t4 garret will the hx be the best one to get. Alao i see the h1 alot cheaper than the hx whats the diff.
Old Aug 6, 2009 | 02:57 PM
  #2911
ashb82's Avatar
i am putting a he351vg on my f22 this weekend what do you guys think of the he351vg. i will use a wastegate open the vgt. where can i find specs on it at
Old Aug 6, 2009 | 09:01 PM
  #2912
up
Old Aug 6, 2009 | 11:59 PM
  #2913
Jdmsoles's Avatar
From: Dodgin Cops all Round Ana-Crime to Orange & Sd
heres my set up im running a h1e need to remove that 26cm^2 housing for a 12cm^2 but that things wont come off LOL any tips!!....but nonetheless here it is thought i would share
Thanks to BMC for the topmount!.
Old Aug 7, 2009 | 06:54 AM
  #2914
big-cat's Avatar
yea sometimes they get stuck pretty good. Spray it with WD40 or pb blaster. some sort of lube. and grab a hammer and tap it outwards. like on the inside edge of the exhaust housing. just keep hitting it harder and harder till it breaks looks then tap it free all around. careful of your fans though no big deal I have a chip in one of my fans and another is bent so I think you will be fine.
Old Aug 7, 2009 | 05:54 PM
  #2915
TurboCivic11's Avatar
I posted about 100 pages ago when i ran my first HX35. But i now have a T4 topmount and im considering running an HX40. Anyone be able to give me any info about the 40's? Im hoping for 650+whp and like the affordabilty of the Holsets.
Old Aug 7, 2009 | 07:35 PM
  #2916
Jdmsoles's Avatar
sweet edit just took of turbine time for rebuild and balance.!
Old Aug 7, 2009 | 07:47 PM
  #2917
SaskCRX's Avatar
Hmmm i have a Holset HE351CW going onto my 1991 CRX Si w/B18C5.... Can anyone say boom?
Old Aug 7, 2009 | 09:48 PM
  #2918
Jdmsoles's Avatar
"!BOOM"!!!! GL
Old Aug 8, 2009 | 04:57 AM
  #2919
AJxr's Avatar
this is true, i heated mine up after soaking it in pb for awhile then went to town with a hammer. wouldnt budge so i got a little mad and then it came off haha. no damage though and ive been running it ever since.
Old Aug 9, 2009 | 06:17 PM
  #2920
fmfkid250's Avatar
You will be Fine, My Girl friend has one on a stock LS. It makes around 250whp on 10psi.
Old Aug 9, 2009 | 08:33 PM
  #2921
Jdmsoles's Avatar
i think you missed the joke, since LS has a comp of 9.2:1 and c5 is 10.5, not that the turbo will be the problem, its compression along with boost which will further increase comp, causing the boom he was talking about! lol.
Old Aug 10, 2009 | 04:54 AM
  #2922
big-cat's Avatar
it all depends on the tune. higher comp does make it easier to detonate but it can be tuned and not detonate. they are just a different platform.
Old Aug 10, 2009 | 05:25 AM
  #2923
fmfkid250's Avatar
Truth, You will be fine.
E-85 wouldent be a bad idea though!
Old Aug 10, 2009 | 06:10 AM
  #2924
ashb82's Avatar
I have a he351vgt turbo the turbo has coolant passages that seem to cool the vgt servo. i am not running the vgt servo so do you think i would be ok with out running coolant to the turbo.
Old Aug 10, 2009 | 07:25 AM
  #2925
Otis37's Avatar
I hae an HE341 for sale!! PM if interested.
