Holset users unite!
i recently put my ls-t holset build in my ef...with a top mount and im having a lot of placement issues just 2 big...but its slowly coming,,,one problem at a time...and tha pics....! http://hondamarketplace.com/album.php?albumid=11963 link from that one n theres more..
any websites or places that you guys recommend to goto, in order to buy one of these turbos? i'm looking to get an hy35 or hx35 for my stock gsr build.
junk yard or ebay. you just have to search on ebay and the deals are on there. though I hear the chinese are making knock off holsets now
i install a he351vgt turbo on my f22b1 today. i took it up the road it would not spool till about 5500rpm 6psi on a 8psi spring wastegate. Do you think it would be a boost leak or just to big of a turbo. I had a turbonetics 60 trim that was way better spooled at 3500 rpms. Man it so slow now what you guys think.
had to turn the compressor housing you think that would effect it. It dont even have a turbo jet sound. I tested it for boost leaks nothing is leaking. i turned the vgt both ways nothing helps me spool faster any advice
I got my he351ve vgt f22b1 civic running good today man i love it. I used a spring to hold the vgt closed then as the exhaust pressure rises the vgt will open on it own i hope. either way it spools fast as hell way better than my 60/62 turbonetics. It feel way faster to. i had to add alot more fuel to the tune. I think it feel better at 8psi than my old setup felt at 15psi. going to the drag strip soon so i will find out.
what fitting are you using on the oil inlet on an hx35.. motors built, parts are here, everything is figured out, except this.. please help.. can't find anything
