Function and Form coilover thread
Old Apr 3, 2011 | 11:48 AM
  #1376
mitsubishiv5's Avatar
Default Re: Function and Form coilover thread
ive always removed my lca to adjust the ride height. alot faster personally. just a bitch to pull the lca up towards the preloaded shock.
Old Apr 3, 2011 | 02:32 PM
  #1377
Rylan's Avatar
Couldn't you use a jack to push the LCA back up to the shock ?
Old Apr 3, 2011 | 02:42 PM
  #1378
i mean to say i unbolt the shock from the lca. makes life easier with a pump jack and an impact gun
Old Apr 3, 2011 | 04:39 PM
  #1379
SHG_Claudio's Avatar
Thats why its not a good way to do it. Even ifu were to havr those tools available, its not a good idea to keep beating the hell out of it every time you want to adjust the height. Much easier to spin the top collar. Its not a lot of force, you can literally spin it with both hands
Old Apr 3, 2011 | 04:42 PM
  #1380
Whats Up DOHC's Avatar
Why would you **** with preload to change ride height
The whole point of the design at the bottom is to retain suspension travel + spring load at any ride height
Old Apr 3, 2011 | 06:04 PM
  #1381
How many times do I have to explain this lol. Already here it goes again.
1. Loosen the lower perch (counterclockwise/lefty loosy) and spin it up.
2. Spin the top spring perch and spin it (clockwise/righty tighty).
3. Tighten the lower perch (clockwise/righty tighty) when the height is set and youre done.
You see, the 2 upper perches are LOCKED TOGETHER. This means that if you spin one or the other, the other will follow and spin in the same direction. Since they are locked together, they will spin the whole shock and this threads the shock in the mount or threads it out of the mount. Youre not actually changing the preload, the spring doesnt get anymore compressed/decompressed.
So by spinning the top one, the whole shock twists. To change the preload those 2 perches would have to be separated (twist one clockwise and the other counterclockwise). ONLY THEN would spinning the top collar actually compress/decompress the spring.
Get it?
Old Apr 3, 2011 | 07:06 PM
  #1382
Rylan's Avatar
Poor HBKfanatic explaining his heart out :p
Would it be a good idea to spray some sort of liquid grease on the threads that are threaded into the lower mount to keep the threads free and easy to spin later on down the road?
Old Apr 3, 2011 | 07:17 PM
  #1383
Yes it would. Especially in the winter. I recommend spraying the threads with WD-40. When I had to adjust mine after the winter, the fronts came off okay but the rears were hard. I had to use my heat gun and PB blaster to get the lower perch unlocked.
Cleaning them from time to time with a toothbrush is also good
Old Apr 3, 2011 | 07:19 PM
  #1384
Rylan's Avatar
Yeah I don't know about these ones, but with other coilover sleeves they got hard as hell to turn after some time. Ill lube the hell out of these, I will have them installed Thursday night! FINALLY lol
Old Apr 3, 2011 | 07:31 PM
  #1385
Khevin's Avatar
Claudio Is the man. /thread
Old Apr 3, 2011 | 07:39 PM
  #1386
/thread
Old Apr 3, 2011 | 08:51 PM
  #1387
Need_jdm's Avatar
+1 on the wd-40 and cleaning
i take my wheels off and clean my every now and then and use a little bit of that turtle wax and dry spray on mines
Old Apr 4, 2011 | 03:22 AM
  #1388
sole.phresh's Avatar
planning on coppin a set of these!
Old Apr 4, 2011 | 08:49 AM
  #1389
drivingenthus's Avatar
Installed these last weekend; very quick install -had to change the 88 crx lca's to the 89+ (88 crx lca are like ITR style lca). Great packaging and they look great, only thing to point out is that the rears go about 1.5 inches lower than the fronts. Front is maxed and rear has about 1.5 more to go down. Impression of ride is awesome, a little on the soft side but ride quality on harsh SF roads are about as good as my kw v3's on my other car. Might mess with preload a little bit in front to stiffen a lil, how many threads do you suggest I compress the spring?
p4c
Old Apr 4, 2011 | 09:00 AM
  #1390
Rylan's Avatar
I wouldn't mess with the preload at all if I were you. It can lower the lifespan of your suspension. They are preloaded correctly out of the box, I would leave them at that IMO.
Old Apr 4, 2011 | 09:21 AM
  #1391
Good point. Though I want to make another =]
Preload is an adjustment and not necessarily right or wrong. We just make a big deal about it here because of all the discussion of how to properly adjust the height. Race teams play with preload too so that the suspension behaves different. They are already preloaded 5mm from the box and this is just optimum for a longer life and ride quality but you should try adding more in 5mm increments and go from there. I have never bottomed out the springs so adding a little bit of preload won't hurt.
I actually think they are a bit stiff and plan on having as as little preload as I can so that the spring has no slack O.o
Old Apr 4, 2011 | 09:47 AM
  #1392
Rylan's Avatar
It says right on the instructions that messing with the preload will void your warranty that came with these coilovers. Just a thought anyways.
Old Apr 4, 2011 | 10:01 AM
  #1393
Thanks HBK, maybe I'll add 5mm and see how it feels. What are the spring rates on your Type 1 for EF?
haha -didn't read the instructions. this is only the 20th set of coilovers I've installed and Hondas are by far the easiest.
Old Apr 4, 2011 | 12:21 PM
  #1394
No, I believe it says adjusting the height by the preload will void the warranty, not adjusting the preload itself.
http://www.f2autolife.com/technical-tips-and-how-tos
I have them on my EG but the EFs are the same rates, 10k front and 6k rear.
Old Apr 4, 2011 | 03:25 PM
  #1395
Arthas's Avatar
You guys are fuggin' retarted.. Fa reals...
SPIN THE BOTTOM PERCH UPWARD TO LOWER CAR.
'nuff said.
Old Apr 4, 2011 | 03:31 PM
  #1396
'nuff said.
Am I doing it wrong?
Old Apr 4, 2011 | 03:33 PM
  #1397
Arthas's Avatar
You are doing it wrong. Do not give advice anymore. The bottom LCA bolt MUST be removed in order to adjust the settings.
WTF is wrong with you people.
Old Apr 4, 2011 | 03:42 PM
  #1398
Thanks for the new sig
Old Apr 4, 2011 | 04:10 PM
  #1399
Arthas's Avatar
Originally Posted by jdm2envy
do you rub the tires when you turn your wheels?
The rears no. The fronts, umm yeah very little though. I feel it the most when im doing a u turn from a dead stop.
Old Apr 4, 2011 | 07:45 PM
  #1400
Kyle is raaddd's Avatar
Ra-ta-ta-tat dat GDD
Mine rub a very very slight bit at full lock on 15x7 +45 195/50.
Now we'll see when I get my 15x9 +12 195/45
Still can't wait to order the 14k springs for my fronts. Probably get 12k for the rears as well
