Function and Form coilover thread
Old Mar 28, 2011 | 02:48 AM
  #1326
hatchy69's Avatar
Default Re: Function and Form coilover thread
Cant wait to install mine. Just waiting for the sand and salt to get cleaned up.
Old Mar 28, 2011 | 04:47 AM
  #1327
SHG_Claudio's Avatar
Originally Posted by slo_hatch
my type2's on my s2000 are threaded all the way down in the shock body on the rears. there is no way they can thread any further. so when i adjust the preload on these, do i turn the collars up (creating more preload), or turn them down (decreasing preload)?? i watched that video about the s2 coilovers but they turned the spring perches up to make more room for the threads. since i cannot adjust height by the threads anymore, that method doesnt help me. lol can someone clear this up for me please?? thanks!
So let me get this right, you threaded the shock inside the mount as much as it would go? Then thats as low as you can go. You adjust the preload up so that you can have more room to thread the mount higher up but the mount is closed at the bottom so you can only fit so much shock inside there.
When you lower them to the max without touching the preload, theres maybe an inch or so of space under the shock to the base of the mount. When you add preload, you then have space to thread the mount higher but only so much until theres no space between the bottom of the shock and the base. Get it?
Originally Posted by ryanNoob
For those of you on Type 1's on 96-00 Civic's, what's the length of the spring for the rears? I'm asking for right out the box and with the preload not tampered with.
"Springs are pre-loaded out of the box. Pre-load is set at 5mm. You can check to ensure that your coilovers are set properly by measuring the length of the spring. All springs are either 150mm, 160mm, 180mm, 200mm, or 220mm. Once you have determined the length of your spring, you can minus the length by 5mm. E.G. 180mm minus 5mm (pre-load) is 175mm. The spring should be 175mm on the coilover to be pre-loaded properly. If you have any questions, please feel free to contact us, and we can verify this for you over the phone."
Originally Posted by Rok_Stok
Type 1s are good for the money, my car is sitting just where I want it.
Yeah pretty good upgrade for the money. Its nice being able to set the height to what you want.
I was talking to Migz and I mentioned you have Type 1s. He said he can come down and help you install them if you need. He helped me do mine
Old Mar 28, 2011 | 07:11 PM
  #1328
slo_hatch's Avatar
see...this is what im working with. when you try to lower the shock into the body of the bracket, it is really tough to turn. this makes me think it is bottoming out inside the mount. so how would i adjust this to get my car lower without sacrificing too much of the quality of ride or risking blowing the shock out. they are type2's btw.
Old Mar 28, 2011 | 07:34 PM
  #1329
JDMbrad's Avatar
Old Mar 28, 2011 | 07:42 PM
  #1330
Rylan's Avatar
^^^ Beautiful!
Old Mar 28, 2011 | 08:17 PM
  #1331
ryanNoob's Avatar
I read that on the website, but do you have the exact answer?
Old Mar 28, 2011 | 08:58 PM
  #1332
del sol noob's Avatar
can i install ground control extended top hats on my f&f type twos does any one know or have done thise
Old Mar 28, 2011 | 09:03 PM
  #1333
wannaBjdmca6's Avatar
I do like how they ride but bumps are just aweful nowadays, Im just trying to figure out if its just me. My preload is stock and I actually contacted them and they said it is okay to increase the preload so that the spring is less compressed and the ride would be softer just as long as I dont change it too much.
WTF? lmao increasing pre-load means the spring will be more compressed dude.
Old Mar 28, 2011 | 11:08 PM
  #1334
PartyShank's Avatar
Finally got my 2.5's .. Love them.
Old Mar 29, 2011 | 04:49 AM
  #1335
Genuine Rolla's Avatar
Just installed my Type One's last night. They ride amazing and they go pretty low in the front when all the way down. Lower than the coilover sleeves that I had before.
I'll post pics up today when I get the chance to take them.
Old Mar 29, 2011 | 04:55 AM
  #1336
JDM 98 GSR's Avatar
cant wait to puit my type 2s in my TL_S
Old Mar 29, 2011 | 05:41 AM
  #1337
Rylan's Avatar
I really like that man!
Old Mar 29, 2011 | 07:00 AM
  #1338
PartyShank's Avatar
Thanks bro
Old Mar 29, 2011 | 07:10 AM
  #1339
can i install ground control extended top hats on my f&f type twos does any one know or have done thise????????????????????????????????????????????? ??????????????????????????????????
Old Mar 29, 2011 | 07:24 AM
  #1340
Rylan's Avatar
I can't see why not, as long as they are for the same car they would probably work.
Old Mar 29, 2011 | 07:42 AM
  #1341
Thats crazy that you have that much space up there, have you messed with the preload at all? Either way, if the shocks are bottoming out inside the mount, then thats as low as you can go. Some coilovers are open ended so you don't have that problem but messing with preload won't do anything for height in your case. Im surprised theres still all that space though.
Ah. Sorry I have an EG app, not EK, dunno the EK specs.
For the sake of argument, no. Have a read
https://honda-tech.com/forums/suspension-brakes-54/function-form-type-2-extended-top-hats-2728583/
https://honda-tech.com/forums/suspension-brakes-54/function-form-extended-top-hat-2812649/
Lol my bad, I meant decreasing. Always saying increasing in this thread threw me off I think haha.
Old Mar 29, 2011 | 10:28 PM
  #1342
Khevin's Avatar
I have a fairly new(bought about 2 months ago BRAND NEW) set of FF1's on my EG hatch and there seems to be a problem with the rear passenger side coilover. Everytime I make a right turn there is a knockin noise as if something was loose. I have checked multiple times to see if there is anything loose but I see nothing. But when there is someone sitting in the rear passenger seat the knocking stops. Any ideas what it could be? Thanks to anyone who can help!
Old Mar 30, 2011 | 12:23 AM
  #1343
My_EFsedan's Avatar
installed type ones today. maxed without messing with preload.
type on my sedan, same thing.
they both ride GREAT!
Old Mar 30, 2011 | 12:34 AM
  #1344
Need_jdm's Avatar
i bought mine used and didn't get the tools.Anyone know if i can order the tools?
Old Mar 30, 2011 | 01:07 AM
  #1345
Original.'s Avatar
^ Don't really need the tools, they don't work well anyways. I always use a hammer and a flat head.
Old Mar 30, 2011 | 01:29 AM
  #1346
ryanNoob's Avatar
I have the same problem, but on both sides and I have an "EK" hatch. I've been rolling like that for about a month or two. Your suspension could be blown.
Old Mar 30, 2011 | 07:31 AM
  #1347
Khevin's Avatar
Wowzerz.
I have not even 1,500 miles on mine
Old Mar 30, 2011 | 07:36 AM
  #1348
Rok_Stok's Avatar
JDMbrad, those polished RSZ-Rs? Look pretty nice!
Old Mar 30, 2011 | 07:44 AM
  #1349
Sounds like the spring isnt preloaded and has play
Old Mar 30, 2011 | 08:05 AM
  #1350
JDMbrad's Avatar
Yes sir and thank you.
