Function and Form coilover thread
Old Mar 30, 2011 | 09:01 AM
  #1351
Rylan's Avatar
Default Re: Function and Form coilover thread
Sounds like the spring isnt preloaded and has play
Yeah, I agree sounds like it could just be the coil moving around, which is possible if the spring isn't pre loaded.
Old Mar 30, 2011 | 09:06 AM
  #1352
SHG_Claudio's Avatar
I dont doubt it, I explained SpeciaKay like 20 times how to adjust it and he still was clueless lol
Old Mar 30, 2011 | 09:17 AM
  #1353
Rylan's Avatar
Mine came pre loaded right out of the box, and I didn't touch it lol
Not even on the car yet
Old Mar 30, 2011 | 05:37 PM
  #1354
theservant's Avatar
Originally Posted by cd5_2NR
what a nightmare...installed the fronts with no issues...the rear shoulda been a 30min job and ended up taking 2 whole days...
rear end was a bitchhh...first..left side strut bolt broke off...then right side strut bolt seized...decided to go with plan b...remove entire LCA with struts still attached...all but 1 LCA bolt came off...spent a whole day drilling...then finally cut the bolt off at its end and where the bushing is...had to order new LCAs...
*will have pics as soon as i can throw the rear functions on w/the new LCAs...i took her for a drive with just the fronts lowered...rode smooth as hell and no noise or squeaks...
bro i totally feel ya. front end was a piece o cake. rears? oh of course had to be absolute nightmares. had to have a friend run me to the store to buy a sawzall to swap em. good ol frozen bushing bolts. stupid *** midwest. i put in new function and form lcas with poly bushings and sprayed the new bolts with white lithium grease so no more rust.
Old Apr 1, 2011 | 01:55 PM
  #1355
Khevin's Avatar
Anyone see anything wrong with this? HBKFanatic thinks there isn't enough shock inside the mount. Any other ideas?
Old Apr 1, 2011 | 02:02 PM
  #1356
hatchy69's Avatar
He could be right man. There's maaadd threads showing! It's worth a try to thread the shock in a little to see if there's any difference.
Old Apr 1, 2011 | 03:20 PM
  #1357
mitsubishiv5's Avatar
holy **** monster truck status
Old Apr 1, 2011 | 07:04 PM
  #1358
ryanNoob's Avatar
SpecialKay, did you adjust the mount that the spring sits on? If so you adjust your preload. What's your current height?
Old Apr 1, 2011 | 07:50 PM
  #1359
jdm2envy's Avatar
Originally Posted by Arthas
I have EG Type Ones in my EK.
I do have room to go lower.
do you rub the tires when you turn your wheels?
Old Apr 1, 2011 | 07:55 PM
  #1360
Khevin's Avatar
Not very low,
Old Apr 1, 2011 | 07:58 PM
  #1361
looks like its maxed out pretty much.
Old Apr 1, 2011 | 08:13 PM
  #1362
Khevin's Avatar
I have quite a bit more threads to go lower.
Old Apr 1, 2011 | 08:20 PM
  #1363
lol, thats as high as you can go lol. I had to raise mine for the winter and it was incredibly low still haha. Hes on 14s too so hes already pretty low.
Old Apr 2, 2011 | 06:19 AM
  #1364
Need_jdm's Avatar
specialkay here
Old Apr 2, 2011 | 06:59 AM
  #1365
Rylan's Avatar
Why would he do that? That is the locking collar? It wont do any good being half way up the sleeve?
Old Apr 2, 2011 | 08:25 AM
  #1366
Genuine Rolla's Avatar
he's saying to put the locking collar up, and then spin the whole thread body into the shock, so that it'll lower it.
Old Apr 2, 2011 | 10:04 AM
  #1367
Khevin's Avatar
Thanks guys, I'm gonna try all these things and if nothing fixes it I'm assuming it's blown. At least I have warranty
Old Apr 2, 2011 | 10:37 AM
  #1368
My_EFsedan's Avatar
cause the top collars and spring are the preload. according to the instructions, to lower the car to desire height, move the lower collar up and twist the whole lower portion up.
Old Apr 2, 2011 | 12:19 PM
  #1369
Rylan's Avatar
I thought he ment just spinning the bottom locking collar up there LOL
Old Apr 3, 2011 | 01:04 AM
  #1370
Need_jdm's Avatar
just to make it easy to understand
when i say remove shock from the Lower Control Arm i mean remove the bolt that holds the coilover to the LCA
then you move up the red thing its the only way to lower and raise your function forms correctly
DO NOT ADJUST THE TOP OF YOUR COILOVER YOU WILL MESS UP YOUR PRELOAD SETTINGS AND MAKE THEM STIFF OR SOFT AND BOUNCY
Old Apr 3, 2011 | 10:52 AM
  #1371
Thats the wrong way to do it bro :/
Old Apr 3, 2011 | 10:55 AM
  #1372
wannaBjdmca6's Avatar
you dont need to remove the LCA bolt. just grab the 2 upper collars together and spin toward whatever height you want. the whole unit should spin.
read the instructions you guys.
Old Apr 3, 2011 | 11:06 AM
  #1373
Need_jdm's Avatar
oh i guess i add extra work the way i adjust,but mines is not at a 4x4 status and my preload is still ok
  #1374
Need_jdm's Avatar
whats wrong about it?
Old Apr 3, 2011 | 11:14 AM
  #1375
Taking out the LCA bolt all the time isnt good. But thats a lot of work to adjust height. All you gotta do is spin the top perch, it is locked with the other perch so they spin the together with the shock, youre not actually changing the preload like that. To change the preload you would have to twist one clockwise and the other counterclockwise until they unlock from one another.
