DA Integra's Only
Old Jul 14, 2007 | 10:06 AM
  #17151
92LSVTEC's Avatar
Default Re: (Morasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morasso &raquo;</TD></TR><TR><TD CLASS="quote">
Just tried replacing that, brand new from Acura. No luck. So I need to go take that back to acura.
Car just cranks, doesnt start. Radio and lights all work. Belts spin when cranking...
Any other options guys, I really need to get my car running.</TD></TR></TABLE>
i cant belive you changed that without checking for spark first...
and testing for spark is quite easy... just to what project said
Old Jul 14, 2007 | 10:34 AM
  #17152
Morasso's Avatar
Default Re: (92LSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
and testing for spark is quite easy... just to what project said</TD></TR></TABLE>
Well **** man, thats what a lot of people told me the problem was.
Just pop the plug out and crank?
Do I need to ground it or anything.
Old Jul 14, 2007 | 10:53 AM
  #17153
RA22FEVER's Avatar
heres my DA
Old Jul 14, 2007 | 10:57 AM
  #17154
92LSVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">did you check for spark? if its making a popping sound, the cylinders coud be loading up with fuel, but not sparking... a honda with a bad distributor? not possible </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGe. &raquo;</TD></TR><TR><TD CLASS="quote">If it's not the main relay, it going to be either the rotor, coil, or ignitor.</TD></TR></TABLE>
those two quotes got lost among the 400 quotes of the pic of that k20
Old Jul 14, 2007 | 03:06 PM
  #17155
Dateggy21's Avatar
original paint ftw
Modified by Dateggy21 at 9:34 PM 7/14/2007
Old Jul 14, 2007 | 03:21 PM
  #17156
kNOwLedGe.'s Avatar
those two quotes got lost among the 400 quotes of the pic of that k20</TD></TR></TABLE>
I was going to say the same thing
You should've checked for spark. The problem could be as simple as a broken rotor. Take off the distributor cap and look.
Old Jul 14, 2007 | 05:30 PM
  #17157
DualCamDan's Avatar
Yea, i was thinking somthing Dizzy wise too... i had it hapen to me w/ my Rex just after i swapped it.
Old Jul 14, 2007 | 10:28 PM
  #17158
Mattyg2's Avatar
Default Re: (Dateggy21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dateggy21 &raquo;</TD></TR><TR><TD CLASS="quote">original paint ftw
Modified by Dateggy21 at 9:34 PM 7/14/2007</TD></TR></TABLE>
original paint FTW, mine is nice too as someone who seen my car would say
Old Jul 15, 2007 | 01:41 AM
  #17159
Brice.Hayden's Avatar
Default Re: (RA22FEVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RA22FEVER &raquo;</TD></TR><TR><TD CLASS="quote">heres my DA
I really like those rims!!!
Old Jul 15, 2007 | 08:32 AM
  #17160
Morasso's Avatar
Default Re: (JasperDA9)
No spark guys.
So possibly my Rotor or Coil?
All I need to do is pop off the distrubutor cap to check those out right?
Old Jul 15, 2007 | 09:01 AM
  #17161
DATZ WEAKSAUCE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morasso &raquo;</TD></TR><TR><TD CLASS="quote">No spark guys.
All I need to do is pop off the distrubutor cap to check those out right?</TD></TR></TABLE>
most likely it is not your rotor. most like gonna be your ignitier. to check your coil just crank your car and your rpm needle should bounce around. and to check your ignitier your gonna need a volt meter search ht couple good articles on how to do that
Old Jul 15, 2007 | 09:03 AM
  #17162
Morasso's Avatar
Default Re: (DATZ WEAKSAUCE)
So assuming my RPMS dont bounce when I crank, thats a symptom of a bad Coil?
Is there anyway to check the coil physically?
Old Jul 15, 2007 | 09:05 AM
  #17163
SYNSEI's Avatar
Ahhh. Youre the guy with the Celica project. Love your DA...and the project.
Old Jul 15, 2007 | 09:07 AM
  #17164
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morasso &raquo;</TD></TR><TR><TD CLASS="quote">So assuming my RPMS dont bounce when I crank, thats a symptom of a bad Coil?
Is there anyway to check the coil physically?</TD></TR></TABLE>
yup no bounce= bad coil
Old Jul 15, 2007 | 09:10 AM
  #17165
DSRxSALSA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DATZ WEAKSAUCE &raquo;</TD></TR><TR><TD CLASS="quote">
yup no bounce= bad coil</TD></TR></TABLE>
mine didnt bounce and i had a bad ignitor. check resistance on the coil and make sure its within spec first before assuming its the coil.
Old Jul 15, 2007 | 09:42 AM
  #17166
Morasso's Avatar
Default Re: (DSRxSALSA)
RPMs didnt bounce
Although, I was looking over my plugs and plugs 1 and 2 are COVERED in oil, like covered.
Plugs 3 and 4 are fine.
Should I try cleaning the plugs? Or does that not matter considering plug 4 is clean and wasn't getting a spark.
Old Jul 15, 2007 | 09:45 AM
  #17167
Morasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSRxSALSA &raquo;</TD></TR><TR><TD CLASS="quote">
mine didnt bounce and i had a bad ignitor. check resistance on the coil and make sure its within spec first before assuming its the coil. </TD></TR></TABLE>
How do I go about doing that?
Old Jul 15, 2007 | 10:52 AM
  #17168
DSRxSALSA's Avatar
How do I go about doing that?</TD></TR></TABLE>
hold on let me go check my chiltons and see if it shows the range its supposed to be in. i dont know it from the top of my head
Old Jul 15, 2007 | 11:05 AM
  #17169
DSRxSALSA's Avatar
alright here we go since my scanner is broken im going to type this out for you. make sure this is done with the KOEO.
1.with the ignition off, remove the distributor cap.
2. remove the 2 screws to disconnect the blk/yel wire from teminal A (positive) and wht/ blu from terminal b (negative) of the coil.
3. using and DVOM, check resistance between terminals. replace coil if not within specification.
-&gt; resistance will vary with coil temp. specifications are at 70F (20c)
4. check the primary windings resistance between terminals A and B is at 0.6-0.8 ohms
5. check the secondary windings resistance terminals A and the coil tower is 9760-14640 ohms.
6. replace coil if the resistance is not within spec.
i hope this helps :D
Old Jul 15, 2007 | 11:09 AM
  #17170
Morasso's Avatar
**** I dont have a volt meter
Off to Autozone, again...
I took out my plugs and cleaned them off, the actually terminals on the plugs are fine, so thats not the problem.
whenever I turn my key to III and don't try to start the car, my CEL stays on, is that normal? If not I have my ECU out ready to go to check codes, I just don't know how to do that either
Old Jul 15, 2007 | 12:46 PM
  #17171
I got a honda's Avatar
anyone have the champagne color DA?? im thinkin bout pickin one up.....thanx
Old Jul 15, 2007 | 01:11 PM
  #17172
integda9-92's Avatar
Old Jul 15, 2007 | 03:07 PM
  #17173
jdmkrazie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morasso &raquo;</TD></TR><TR><TD CLASS="quote">**** I dont have a volt meter
whenever I turn my key to III and don't try to start the car, my CEL stays on, is that normal? If not I have my ECU out ready to go to check codes, I just don't know how to do that either </TD></TR></TABLE>
didn't get the chance to read any ones advice yet. but have you checked the main relay? could just be that.
Old Jul 15, 2007 | 03:36 PM
  #17174
Default Re: (jdmkrazie)
hahaha ***...he already bought a new one and it didnt work...he went back to Acura to return it
Old Jul 15, 2007 | 03:56 PM
  #17175
jdmkrazie's Avatar
who's an ***? i was just saying lol. was too lazy to read the last 2 pages.
