DA Integra's Only
Old May 5, 2011 | 11:04 AM
  #47301
OldskoojdmDA9's Avatar
Default Re: DA Integra's Only
Originally Posted by Mattb16teg
Well I actually meant for the block. Last week I picked up a new block which ended up being a big pile of crap. So I was scrambling to find a new block so I can get the car back up.
Waiting on my new clutch disc too.
Ahh I see. Which block did you pick up?
Old May 5, 2011 | 11:39 AM
  #47302
Mattb16teg's Avatar
Community Builder
Community Influencer
just an LS
Old May 5, 2011 | 01:45 PM
  #47303
tougetuned_ef's Avatar
Originally Posted by Colin
No. The system is ground switch system. You need a ground but it needs to be on a switch. That switch is your ECT switch. Unless you plan on deleting your ECT switch your ground MUST be the yel/grn wire from the ECT switch.
Yes, that technique for capping off a hot lead is fine. I also like to pull fuses if possible. But sometimes you can't if another system also sources power from that fuse.
Yes, that is correct. It'll be exactly like that except you'll be using the white wire for power which leads to the #12 (15a) fuse. This white wire is already connected to your radiator fan, so you do not need to rewire the power side of the fan, only the ground side.
cool thanks for the info. im off tomorrow so i will be pulling the right side harness apart and re-doing it again.
Originally Posted by Bond
Get yourself the female end from a junkyard and make your own. Or just repin it. It's so much cleaner to just repin it using the obd female pins. Just solder then in after cutting the obd0 ones off due to the obd-0 pins are shorter in length. Ive done this on all mine with zero problems and it looks factory.
the car is obd1. i have the stock obd2 em1 si harness here so i will be taking the injector plugs, dizzy plugs and vtec, knock from that harness.
Old May 5, 2011 | 02:01 PM
  #47304
oemda's Avatar
Originally Posted by OldskoojdmDA9
Thanks! Yeah it took me a while to figure out the kit I wanted, but I love my current setup. I personally love the 90-91 bumpers so finding a lip kit was no easy task. In my opinion, the USRacing front lip really sets off the front. The Mugen replica sides and OEM optional rear lip just make it complete. I also need to pick up JDM thin side moldings to finish it off!
and yet, very well done bro. I regret getting rid of my OEM hood bra cause im now having a hard time finding another one. Get the thin moldings cause that's sexy!
Old May 5, 2011 | 11:04 PM
  #47305
Thanks again man. I was very fortunate to buy my hood bra and fender covers in mint condition, I only put it on for meets and on sunny days. The constant Seattle rain would trash it if I always left it on lol.
JDM thin side moldings are definitely on the list! Wheels are coming before them though
Old May 6, 2011 | 06:32 AM
  #47306
almotor18's Avatar
MY passenger seat belt wont retract and keeps beeping any idea on how to fix guys?
Old May 6, 2011 | 07:08 AM
  #47307
Mattb16teg's Avatar
Community Builder
Is it stuck on something or does it seem like the motor is kaput?
Old May 6, 2011 | 07:09 AM
  #47308
almotor18's Avatar
no the motor is fine i tested it by pulling it and opening and closing the door it goes right back down just if u were gonna get in it doesnt fasten around u
Old May 6, 2011 | 07:26 AM
  #47309
tegtuner01's Avatar
have you pulled on it to see if it safety locked?
Old May 6, 2011 | 07:27 AM
  #47310
almotor18's Avatar
Yes i turn on the car its fine...after a few minutes it starts beeping and the belt doesnt retract at all on my red one....sucks
Old May 6, 2011 | 07:37 AM
  #47311
Mattb16teg's Avatar
Community Builder
WAT?
This is the age of technology, just record a video with your phone and post it up.
Old May 6, 2011 | 07:42 AM
  #47312
almotor18's Avatar
lol u have a point hhahha ill go n see wat happens in a few
Old May 6, 2011 | 09:11 AM
  #47313
be18see1's Avatar
First tune is set for tomorrow! Just have to hook up my gauges, zip tie my fender liners up, and install my exhaust gasket and she *should* be ready to rip! I'll try to get a video!
Old May 6, 2011 | 10:28 AM
  #47314
Mattb16teg's Avatar
Community Builder
Good luck man, take some tools and be ready for some stress. Little things always pop up.
Have you driven the car yet? I take it not.
Old May 6, 2011 | 11:23 AM
  #47315
im sooooo sick of all these damn wires!!!! why did i ever start this? my back is on fire from being hunched over in my pass seat. i need a beer!
Old May 6, 2011 | 11:27 AM
  #47316
Mattb16teg's Avatar
Community Builder
hahah I hate everything and anything wiring related.
Esp when it's a cluster **** like a main harness.
Old May 6, 2011 | 12:15 PM
  #47317
morganm58's Avatar
Originally Posted by Snazzy95eg8
what rims are these. they are a good look
Old May 6, 2011 | 12:32 PM
  #47318
be18see1's Avatar
RC Starks
Old May 6, 2011 | 03:59 PM
  #47319
I Am The Ghost's Avatar
Originally Posted by 95-db6-719
he just showed you how to do it..what more do u need to know, use a LS lower and a vtec upper. bracket, problem solved.
the 92-93 GsR bracket is not the easiest too find dick!
i wasn't even talking to you!
Old May 6, 2011 | 04:31 PM
  #47320
so i got the cabin headlight harnesses about 95% done. my back was killing me too much to stay in there so i made a ramp to get my engine stand up and over the curb between my garage and the basement. then i installed the im, tb and the iacv that i got from the junkyard. i also got the fuel line that i needed. then moved the split up engine harness over to the b16. just need to steal some plugs from my em1 si engine harness like vtec, knock, and injector plugs. just trying to decide if i really want to cut from that harness. it is my brothers and he wants 100$ for it.
Old May 6, 2011 | 08:33 PM
  #47321
OldSkoolDa91's Avatar
f that. save yourself a lot of money and just go cut the plugs off a harness in the junkyard
Old May 6, 2011 | 10:21 PM
  #47322
I had this same problem about a year ago. Behind the passenger seat on the B-pillar panel there is a small rectangular/square cover. Pull it off, and underneath is a hole that fits an Allen key. It's the crank motor that winds up the seat belt. If you have the OEM hex key turn it back and forth and you will physically move the belt itself. I did this for about 25 minutes. After cranking back and forth the belt finally hopped back on track and retracted to it's correct position.
This usually happens to most people's DA's, the seatbelt usually just comes off the track. Wind it up for a good 10-20 minutes and hopefully it will work for you again!
Old May 6, 2011 | 10:23 PM
  #47323
oemda's Avatar
Hahahah yeaa. I had one on my old 4 door and didnt take it out for a year and it looked ugly under when i finally took it off.
Sounds good man. post when you do.
Old May 7, 2011 | 12:02 AM
  #47324
tegman23's Avatar
anyone know of a bike rack I can buy for a da? my road bike is a PITA to get inside lol
Old May 7, 2011 | 01:13 AM
  #47325
JDM'd OUT's Avatar
almost similar problem but my belt stays where it wraps around me. the beeping sound i just unplug it from the device on the passenger side. acura wants to charge a diagnostic fee when this is lifetime warranty. im okay with it but i might try to fix it
