DA Integra's Only
Old May 2, 2011 | 03:44 PM
  #47226
kNOwLedGe.'s Avatar
Default Re: DA Integra's Only
Originally Posted by OldSkoolDa91
so, is anyone else pissed at how obama is taking all the credit right now?
There is a Politics forum for this. Take your derp somewhere else.
Old May 2, 2011 | 03:50 PM
  #47227
eaperez209's Avatar
Originally Posted by be18see1
Mine has always been fine. Except for that one time it broke. lol
my buddy had one on his ef and it was a nitemare you had to constantly adjust the cable....the pedal feel was horrible and shifting wasnt too smooth thats kinda the reason i decided to go outside the box and do something different and so far i love it!!! took my car the n1 concepts once and their mechanic couldnt believe it the i took my car to get tuned and same thing the guy actually said "mayb i gotta incorporated this in my race car( 91 crx with k24)"
Old May 2, 2011 | 04:07 PM
  #47228
Mattb16teg's Avatar
Community Builder
Community Influencer
Originally Posted by eaperez209
LOL VERY FUNNY....fyi i converted my DA to hydro trans because it is near impossible to find a good b16/b17cable trans specially one with lsd....am currently running a 98 type r trans with a 4.7 fd on a all motor set up pushing 237whp......i
How about some pics of info?
Old May 2, 2011 | 04:09 PM
  #47229
eaperez209's Avatar
you got it....ill take a few shot tonite after work and ill post em up soon
Old May 2, 2011 | 05:03 PM
  #47230
Bond's Avatar
Didn't I read somewhere that you can swap the internals from a hydro into a cable case? Maybe I'm way off, but I sure thought I read that before. Like even just the gear set or gears themselves?
I personally still rock the cable with no plans on ever running hydro. People bitch about engagement, but I love it. It's raw and real, lol.
Old May 2, 2011 | 05:22 PM
  #47231
90HondaDA's Avatar
TEEHEE
Old May 2, 2011 | 06:42 PM
  #47232
mr arizonas pop's Avatar
Icon2 Re: DA Integra's Only
Gotta b16 vtec wit a t66 turbo set up. But I'm throwing code 23. Knock valve right? Where the heck is the thing. And what size wrench do I need?
Old May 3, 2011 | 03:52 AM
  #47233
Snazzy95eg8's Avatar
Old May 3, 2011 | 04:30 AM
  #47234
Mattb16teg's Avatar
Community Builder
That is a code for something being wrong with the knock sensor, either the wiring or the sensor itself. It's on the back of the block near the top, close to the head and it's like a 26mm or so.
More info on said setup. B16 and T66?! Must be a build block with some aggressive cams.
Old May 3, 2011 | 06:38 AM
  #47235
EFcivicJDM's Avatar
hey guys
does anyone know the part no for the green clips that go on the moulding on the side of the front windscreen for a DA?
or can they even be got from honda?
thanks
Old May 3, 2011 | 06:53 AM
  #47236
tougetuned_ef's Avatar
hey guy i need a little help and i cant post on g2ic for some reason. im doing my wire tuck and i had hb420 over here helping me and he doesnt know where this wire needs to go and neither do i. my car is a 92 gs but ive eliminated almost everything that doesnt need to be on the car to make it run, ie. ac, ps, all airboxes in the dash, ect.
so i cut out the ac stuff on the ac side of the right side harness and there is a blk/yel wire coming out of the 2 wire plug in that area. the on wire on the rad fan side goes to the rad fan, and the blk/yel wire goes to what in my service manual says is an ac relay. this was in a pic of where the relays are located but the schematic says something different. but im cut them out and dont want to have to re-solder and try to hide this.
the schematic shows this wire going to whats called the radiator fan control module. ???? never heard of this before and dont know where it would be located. is this one of the relays on the ac side of the harness? here is a pic of the plug and the wire. any help would be great. i just need to know where i can run this wire without having any cel codes or what not.
Old May 3, 2011 | 08:10 AM
  #47237
Mattb16teg's Avatar
Community Builder
I think that control module is somewhere under the dash.
Going to order a new clutch disc while everything is out, gonna go with an unsprung disc this time.
Old May 3, 2011 | 08:54 AM
  #47238
eaperez209's Avatar
ok here are the pic of my hydro conversion been running it for about a year and no issues....btw i also used all oem parts
Old May 3, 2011 | 09:24 AM
  #47239
95-db6-719's Avatar
^ now care to explain how the clutch peddle on the other side of the brake booster ends up depressing that setup. You should do a write up on it
Old May 3, 2011 | 09:29 AM
  #47240
Mattb16teg's Avatar
Community Builder
I meant specs on the motor?
Old May 3, 2011 | 09:32 AM
  #47241
eaperez209's Avatar
yep that was the tricky part as the is no space by the strut tower to mount a clutch cylinder....all i did was change my clutch pedal assembly and drilled on big hole for the cylinder and two little holes for the bolts that hold it in place....then i took the clutch lines and slave cylinder from a dc and adjusted the as necessary to fit my da.....as you see it is not rocket science and there are no reliability issues at all as there isnt much to go wrong all you need is the ryte parts and a little outta the box thinking
Old May 3, 2011 | 09:45 AM
  #47242
eaperez209's Avatar
my bad i didnt get that.....ok lets see its a b18c bottom block with 85mm Rs sleves, knife edge and balance Ls crank, golden eagle rods, 12.5:1 Rs Pistons, port flow b16 head, supertech valve springs and titanium retainers, buddy club spec IV cam, skunk2 cam gears, edlebrock victor x manifold port matched to the head, 70mm skunk2 tb, aem fuel rail, 440 RC injectors, hytech replica header, weapon r 3in air intake, 6al msd, act 6 pluck clutch and 12lb flywheel, 255 walbro fuel pump, greddy exhaust.....that should be it i think
Old May 3, 2011 | 10:10 AM
  #47243
ahhh haa! i found it in the service manual. its a box in front of the cabin fuse box. i see the blk/yel wire they are talking about. i guess i will run the wire all the way through to that spot and solder them together. its the timer reset signal i guess for after you turn off the car this wire sends the signal for the fan to turn off after its cycle. i hope this works.
Old May 3, 2011 | 10:42 AM
  #47244
Mattb16teg's Avatar
Community Builder
Eh 85mm? No room for error there, good luck with it!
Any pics, track times?
What suspension?
Old May 3, 2011 | 11:20 AM
  #47245
eaperez209's Avatar
yea i know my tuner recommended i stay at 84.5mm just incase anything went wrong we could still bore out to 85mm bt at the time all i cared about was making good numbers so i didnt listen .....dont have any track times yet bt mite go next week with a few of my buddies if i do ill let you know.....as of now am running on skunk2 pro s suspension as far as pics what would you like to see? i can try getting a few
Old May 3, 2011 | 11:25 AM
  #47246
g2_teg_'s Avatar
im with you completely except the part in the bold. did u build a bracket that goes from the clutch pedal over to the master cylinder?
Old May 3, 2011 | 11:40 AM
  #47247
Mattb16teg's Avatar
Community Builder
That small difference in bore will not make a hp difference, kinda sucks you shot yourself in the foot however hopefully it all works out for you.
How are those buddy club cams?
Old May 3, 2011 | 11:49 AM
  #47248
eaperez209's Avatar
no need for building ur own bracket all i did was take a clutch pedal assembly from a 91 prulede and believe it or not evrything falls into place fairly nice.....this actually took me quite some time to figure out bt am a manager at a wrecking yard so i literally had hundreds of cars to look at for possible parts donors until i found all i needed
Old May 3, 2011 | 12:01 PM
  #47249
g2_teg_'s Avatar
how does it connect though? u didn't put it on the right side of the gas pedal did you?
Old May 3, 2011 | 12:34 PM
  #47250
eaperez209's Avatar
yea i know that now bt too late to fix it tho
cams are great they really suit my build.....i was running sk2 turner 2's and those cams where good as well bt not for my set up the sk2 cams seem to make more power at higher rpm....in my case the sk2 cams were making power way past 9.5k rpm bt i didnt feel comfortable revving my engine so far on a Ls crank on the other hand the buddy club cam made 2hp more than the skunk2 at only 8.7k rpm bt lost power ryte after that also one less foot pound of torque
