DA Integra's Only
Old Apr 24, 2011 | 06:22 AM
  #47051
g2_teg_'s Avatar
Default Re: DA Integra's Only
Originally Posted by Mattb16teg
Well the block has a hairline crack in Cyl 1.
Lasted me 6 years, saw nitrous, high compression and turbo, so no complaints here.
Looks like I need to find another LS block.
Funny though the thing made power with the cracked sleeve!
critical?
Old Apr 24, 2011 | 08:04 AM
  #47052
Bond's Avatar
Originally Posted by g2_teg_
critical?
Still with this??? lol. Cut the guy some slack
At any rate, matt I hope you find a new block asap and get it back and running soon. Best of luck on the rebuild.
Old Apr 24, 2011 | 08:15 AM
  #47053
g2_teg_'s Avatar
im kidding. it was a jest. he already mentioned that he sprayed it and boosted it for ~6 years. I think if he stayed all motor the whole time, there would be no crack though.
Matt i was selling an LS block for awhile. just sold it last week though.
Anybody have a stock DA intake arm that they don't want?
Old Apr 24, 2011 | 08:19 AM
  #47054
OldSkoolDa91's Avatar
Originally Posted by tegman23
Thanks man, I always think my car looks like garbage, but alot of people said it was nice today, so it makes me feel good lol
dude i dont think it looks bad at all. and i never looked that close at your cage before, such good work the guy did on it. i'm tempted to see about having him do mine when the time comes
matt, like i told you last night, i've got a few blocks layin around and can def meet up with ya to help ya out. i'll give ya the best one i have laying around with the main caps for $50
Old Apr 24, 2011 | 08:21 AM
  #47055
i've got a few random intake arms laying around, but i couldn't tell you which one is from a da. guess i could take pics and measurements?
Old Apr 24, 2011 | 09:25 AM
  #47056
tougetuned_ef's Avatar
little update, i picked up an engine stand today for $43 and got my b16 on it. finally i wont have to suffer from back pain from being hunched over on the ground doing my wiring. im also concerned with my flywheel on the b16. i pulled the clutch and noticed the clutch disc left material on the flywheel. should i have the flywheel re-surfaced before putting it all back together?
also i got some of the holes filled in my bay and primed them. i have to do quite a bit more sanding to get it all smoothed out. i decided im not going to do the headlight harness wire tuck. im just going to re-route then lower in the bay under the trans and left motor mount to hide them a little better. reason being that i dont really trust my self with all of this wiring and i want to save myself the aggrivation of trouble shooting hundreds of wires.
i also found a new awsome oem parts site. its hondapartsunlimited.com . they had all of the firewall plugs i needed to get the bay painted with no paint going into the cabin. i also just ordered all of the plugs for the cowel cover and the cowel gasket. things seem to be going smoothly so far. crossing my fingers hoping that im not speaking too soon!
Old Apr 24, 2011 | 10:57 AM
  #47057
g2_teg_'s Avatar
for the flywheel- I always have a nervous breakdown when making this decision. I know people have gotten away with not resurfacing it, but it would be terrible if it doesn't work out for you. from looking at your flywheel it looks like you could fix it with some fine grit sandpaper. But if it were me, I'd leave that to the professionals and drop it off at the machine shop.
Old Apr 24, 2011 | 11:23 AM
  #47058
honestly, i have never once gotten a flywheel re-surfaced. i've used new clutches and old clutches. never had any problems. if i feel they need cleaned up, i use some fine grit wet sand paper. just wet sand it and see how it looks. then if you feel its not clean enough or smooth enough, you can get it re-surfaced. either way, wet sanding it will show you exactly what you're working with once you get all the clutch off of it
Old Apr 24, 2011 | 02:52 PM
  #47059
ok i will try that tomorrow night. this motor sat in a wrecked car for 2 years before it was taken out and brought to my basement and then sat for 6 months till today when i pulled the clutch off to mount it to the stand. i will do all my work that needs to be done before the motor comes off of the stand and then take it from there.
i dont know of any good machine shops in my area. the one place i took my head to be re-surfaced is the same place my local dealer takes there stuff to and after i heard some horror stories i wish i had known of before i took my LS head there.
Old Apr 24, 2011 | 03:32 PM
  #47060
tegman23's Avatar
Thanks andy, yeah it took a little to draw it up, and when he did it I was there alot to explain. buit it turned out perfect.
made an appt to get tuned and make some power 500whp here i come
Old Apr 24, 2011 | 04:20 PM
  #47061
be18see1's Avatar
resurface your flywheel.
Old Apr 24, 2011 | 04:39 PM
  #47062
when are you getting it tuned? and why stop at 500 when you have a sleeved block? j/w
Old Apr 24, 2011 | 05:06 PM
  #47063
95-db6-719's Avatar
often the need to pay the 40-60 dollars is not needed.
unless the flywheel has hot spots(raises or dimples), is extremely scored, or has cracks in the surface, a resurface is pissing money down the drain.
like was stated, rough it up with some sand paper, to remove any glazing that might have occured to get a good break in and a good bite.
  #47064
Mattb16teg's Avatar
Community Builder
Community Influencer
LoL, got a few blocks lined up, just price shopping now.
LoL, ANY motor or setup in the quest for power will bust, all motor or not........
Old Apr 24, 2011 | 05:39 PM
  #47065
be18see1's Avatar
risk vs. reward
Old Apr 24, 2011 | 06:29 PM
  #47066
Mattb16teg's Avatar
Community Builder
risk vs. reward
Yup, no motor lasts forever, sorry I don't live in internet fantasy land lol!
If people actually saw/knew more HIGH HP all motor setups they would realize they too are susceptible to the same problems as any other setup.
Old Apr 24, 2011 | 06:40 PM
  #47067
g2_teg_'s Avatar
I made 235whp with a block Honda made in their factory. All motor. As far as street cars go I think that's pretty good (< 12 second 1/4 mile). Got 30 Mpg and ran as reliably as the last tax that Honda sold.
Old Apr 24, 2011 | 06:45 PM
  #47068
g2_teg_'s Avatar
I guess it could've broken if I over revved it?
Old Apr 24, 2011 | 06:46 PM
  #47069
hb420's Avatar
Still talking about this
Old Apr 24, 2011 | 06:47 PM
  #47070
Mattb16teg's Avatar
Community Builder
Yea on a k(big difference)
You guys always try to turn this into some dick measuring competition yet no one who speaks us is pushing their setup like I am. I'm not saying it's the highest hp car in the world but still more power than expected for what it is.
Old Apr 24, 2011 | 06:49 PM
  #47071
Mattb16teg's Avatar
Community Builder
LoL, where's it at now??
Old Apr 24, 2011 | 06:51 PM
  #47072
Mattb16teg's Avatar
Community Builder
I should post up all the run files and logs from this current setup, it has seen at least 100 pulls on the dyno messing with little things here and there, seeing what works and what doesn't and what yields the best power curve.
Old Apr 24, 2011 | 06:54 PM
  #47073
Mattb16teg's Avatar
Community Builder
LoL, sadly yes, it's funny.
The internet has spoken!!!!!!!!!!!!!!!!!!!!!!!!!!
  #47074
g2_teg_'s Avatar
I guess what I'm getting at is that its perfectly possible to make power on the street without cracking manifold blowing out engine rings or cracking blocks. Or maybe I just don't push the car as much as u? Who knows? It will spend about one day a week hitting 8-9000 rpm about 80 times in about 3 hours. But what is that compared to going down a track, waiting an hour, going again, breaking down and foing home?
Old Apr 24, 2011 | 06:59 PM
  #47075
g2_teg_'s Avatar
Eh. So its probably spent more time on the dyno then at the track? Mine was only on the dyno one time. So maybe your right, u pushed the car way harder then I pushed mine, on the dyno.
