DA Integra's Only
Old Nov 4, 2010 | 06:32 AM
  #43951
OldSkoolDa91's Avatar
Default Re: DA Integra's Only
Originally Posted by Mattb16teg
Nah, too far with no easily accessible trailer. ECM link just put out an update to run an electronic boost controller so he is in the process of setting that up then needs to do some testing. It's fast but wouldn't be competitive at this race!
But then again it is an AWD car trapping @ 136 ....
Think he does it himself.
ahh that sucks. i wanted to see it run. but thats cool about the update for electronic boost controller
Old Nov 4, 2010 | 06:52 AM
  #43952
Mattb16teg's Avatar
Community Builder
Community Influencer
Yea, think the fuel system is maxed out, just has one 255 in it now.
Last Friday boost was spiking to about 35 psi and it seemed the pump was unable to keep up.
I mean the last run was an 11.1 @ 123 with him letting out at the 1000 foot mark due to breaking up. Compare that with it normally trapping around 135 ish and it's def a mid 10 second car.
Old Nov 4, 2010 | 08:32 AM
  #43953
negusjuda's Avatar
soooo i may be picking up a eg shell next week im going to look at it tomorow
Old Nov 4, 2010 | 09:58 AM
  #43954
yeah def sounds like its well into the 10s for sure
hatch or coupe?
Old Nov 4, 2010 | 12:03 PM
  #43955
Mattyg2's Avatar
Originally Posted by negusjuda
for some reason the left side of my car feels higher but when i measure its the sae on both sides lol and on the highway it wanders side to side
What tires do you have and are they balanced, even tread on ALL tires? Something doesn't look right if your rear camber is -1.5 then -2.8 on the other side. Have you checked the bushings to make sure they are OK enough to where it's not causing your "wander" problem. When you feel this wandering, is the street a fresh paved style asphalt, concrete with a bunch of slits/cracks/uneven style? I think you need to have someone else align it because there's something you're missing or have someone very experienced who knows how a car should feel, especially with this "wander" you keep you're having.
I've recently had about 3 alignments since I kept changing my suspension parts and replacing bushings/steering rack etc...And had 0 problems with alignment, car drives very straight and handles well.
Here's one of my alignment spec sheets from years ago when I was lowered on Tokico Blue shocks with Skunk2 coil over sleeves. Notice how close my specs are and one of your rear sides are WAY OFF. Another note for people who wear out tires fast, notice my front toe before alignment and after. You get TOE wear on your inside tires when lowering and not getting an alignment, not really negative camber wear because the car oem specs have negative camber already!
Old Nov 4, 2010 | 01:18 PM
  #43956
be18see1's Avatar
yeah but not 9 degrees that a lot of folks run.
Old Nov 4, 2010 | 01:46 PM
  #43957
Colin's Avatar
Originally Posted by be18see1
yeah but not 9 degrees that a lot of morons run.
I think you typed that wrong, fixed it for ya.
Matty didn't mean he was running too much camber, he meant it wasn't even from side to side. If the difference from side to side is off by that much then you've got something wrong with the car or you are just inept at making the necessary adjustments.
Old Nov 4, 2010 | 03:10 PM
  #43958
Mattyg2's Avatar
Yeah, that's exactly what I meant Colin.
I need to stop coming on forums, I keep wanting to buy stuff and lower my car when I see other cars now. If I didn't want my alignment out of spec I'd lower my car a bit more. Santa Barbara's roads are pretty nice and makes me feel really high, but soon as I go back to Los Angeles I retract my idea of lowering it soon as I have to enter my driveway at home. Redgardless, soon as I get my next set of tires I'm lowering it a lot more and getting a real balanced alignment by West End.
Old Nov 4, 2010 | 04:55 PM
  #43959
Mattb16teg's Avatar
Community Builder
I'm raising my car this weekend, then trying to get an alignment soon after.
Old Nov 4, 2010 | 05:23 PM
  #43960
DA is best's Avatar
Old Nov 4, 2010 | 05:42 PM
  #43961
negusjuda's Avatar
im in the process of changing bushings the streets here where i live are absolutly horrible lol except on the highway my wander isnt dramatic it minimal but it just annoys me also i found out today the alignment machine needed to be calibrated the spec numbers when doing the alignment would wander back and forth so i never got a for sure reading also the plates on the alignment lift needed to be greased it they didnt move like it was supposed to and as far as my rear camber i dont have adjustments for it yet thats on the way next week but bushings and steering rack are number one on the list
Old Nov 4, 2010 | 05:56 PM
  #43962
negusjuda's Avatar
also what bushings should i change first the front lower control arm bushings are barely a year old outer tie rods are new inners arent upper control arms are about 2 years old i know i wanna change trailing arms bushings rear control arms new anti sway bars front and back
Old Nov 4, 2010 | 06:07 PM
  #43963
Colin's Avatar
Sounds like you answered your own question.
1) "Front LCA's are barely a year old." Well, then looks like they don't need to be replaced, right?
2) "Outer tie rods are new." Well, these aren't bushings, but they're new, so they don't need to be replaced.
3) "Inners aren't." Again, not bushings, but if they're not new and your car is 20yrs old... probably a good idea to replace these. But unless they are bad, they don't NEED to be replaced.
4) "Upper control arms are about 2yrs old" That's pretty new, so as long as they're a quality part, the bushings are probably fine. Same goes for the ball joint.
5) "You wanna change rear trailing arm bushings, rear LCA bushings, and front and rear sway bar bushings" (edited HEAVILY for grammar and punctuation) Well, those sure sound like the bushings you should replace since they haven't been.
In general when it comes to all of these parts we're talking about, you do them all at once. It's much easier that way and will require one alignment instead of multiple. Either way, doesn't sound like you've already replaced about half or more of what needs to be done, so you're almost there.
Old Nov 4, 2010 | 06:40 PM
  #43964
95-db6-719's Avatar
Did you guys see password jdm is no making window visors for a DA...? so now no rediculous prices and the pain for trying to find a pair..
they also started making spoon cf mirrors and rear window visors for a DA.. all they need to do is start making oem quality hood bras and the rare DA parts will be utterly available.
Old Nov 4, 2010 | 07:49 PM
  #43965
Colin's Avatar
I'm pretty sure people saw it when you posted it the first time on the previous page... That stuff isn't anything new. There's already been someone making window visors, albeit in carbon, and Inline4 has been selling mirrors as well.
Old Nov 4, 2010 | 08:00 PM
  #43966
95-db6-719's Avatar
IDK why everyone in this thread constantly seems to have a stick up there ***..
and these ones arnt carbon.. dur,dur,dur.
Old Nov 4, 2010 | 08:06 PM
  #43967
Originally Posted by DA is best
i think i'm in love!!
Old Nov 5, 2010 | 02:57 AM
  #43968
The G2 Racer's Avatar
Two reasons, you can't read and you're beating your chest over PJDMs over priced products.
Learn some tact.
Old Nov 5, 2010 | 02:59 AM
  #43969
be18see1's Avatar
Maybe because you're a jackass. Also, do you realize that if they start making all these aftermarket "uber rare" parts, they're not rare any more? And this last thing is a pet peeve of mine. When you're going to try to make a comment to call someone out, like what you tried to do above, please please please use correct grammar. You instantly lose all credibility when you spell things incorrectly, don't know when to use "there" and "their," and end every sentence with "...".
Old Nov 5, 2010 | 03:50 AM
  #43970
negusjuda's Avatar
lol only on honda-tech
Old Nov 5, 2010 | 04:10 AM
  #43971
Mattb16teg's Avatar
Community Builder
His comment about people having sticks in THEIR rectums does hold water though..............
Old Nov 5, 2010 | 05:18 AM
  #43972
hb420's Avatar
Password gay dm sucks and they are way overpriced... the end.
Everyone has their own opinion and aren't going to like everything that everybody likes. For some people it's cool that pwjdm is making copies of parts and slapping their name all over it. I personally don't like it at all because now the "rare parts" that you don't see to often (which made it cool) are now gonna have carbon of fiberglass knock off parts on every fanboys car. I don't even know why they are called password jdm because they sell knockoff parts and rota wheels that are listed as jdm wheels
Old Nov 5, 2010 | 05:25 AM
  #43973
negusjuda's Avatar
well im gonna be one of those fan boys lol. im on a budget and cant imagine paying the amount that the real jdm window visors cost.
Old Nov 5, 2010 | 05:29 AM
  #43974
negusjuda's Avatar
and speaking of knockoffs i just ordered my konig candys this morning. again couldnt imagine paying the price of the real work jdm wheels lol. now functional parts like suspension, engine, and tranny parts i can cough up the cash for but wheels and acsessories( hope i spelled that right dont want the grammer and punctuation cops to get me lol) i cant pay top dollar for
Old Nov 5, 2010 | 05:38 AM
  #43975
hb420's Avatar
You think that they will be cheap coming from pwjdm??? lol, they sell a battery box for a relocation kit for $160 and the same box cost $38 plus shipping anywhere else. I really don't care what wheels people buy for their own cars, it's not my car or money... i just hate that pwjdm is selling rotas and listing them as jdm wheels.
