DA Integra's Only
Old Nov 2, 2010 | 09:55 AM
  #43901
OldSkoolDa91's Avatar
Default Re: DA Integra's Only
Originally Posted by Mattb16teg
Ju coming homes?!
Sweet, yea hopefully we get down there at a decent time but I doubt it. lol
Remember to bring lots of clothes! It's gonna be freaking cold again.
hahah you had me thinking I was crazy! I've never seen a traction bar that mounts there, wonder what ones your talking about.
what kinda question is that? you know damn well i'm gonna be there!! lol. and yeah, i've been preaching to my gf about how many clothes she's gonna need. i think shes finally starting to grasp that hey, its gonna be colder than ***** out once the sun goes down!!
and yeah, there are traction bars that mount in the factory front tow hook locations. i know a lot of them for eg's are like that. not sure about da's
Old Nov 2, 2010 | 10:01 AM
  #43902
AfroIntegra's Avatar
Originally Posted by Colin
What sort of testing did you do? I don't see how you could do anything worth interpreting w/o some pretty intense equipment. And in an instance like this the rigidity of the part off the car is almost a completely useless comparison. the rigidity of the piece will change once bolted to the car because at that point the piece braces the car as well as the car bracing the crossmember. Additionally, some gnarly research may have gone in to the OEM crossmember, maybe it's designed in such a way that the flex you saw isn't an issue due to the way the forces are put on the piece when installed. Unless you're a high level automotive engineer I don't know how qualified you'd be to make any judgements regarding this stuff (no offense, I don't fall into that category either).
And yes, it does mount to where the stock tow hooks are bolted up, as well as 1/2 of the mounting locations the stock crossmember uses.
Check out this link Colin: http://www.full-race.com/articles/traction_bars.pdf
Old Nov 2, 2010 | 10:10 AM
  #43903
70mach1's Avatar
did some work to my teg since I got it. Did the walbro 255 pump, jetta front lip, GS-R tail lights, 16 inch konig rims, tinted front bumper lights. got sum H&R springs coming in tomorrow so I can get rid of the 4x4 look.
Old Nov 2, 2010 | 01:10 PM
  #43904
be18see1's Avatar
Aha! Matt, look at page 3 of the link AfroIntegra posted. Crossmember mounted to the SIDE of the frame rail. I knew it existed.
Old Nov 2, 2010 | 01:30 PM
  #43905
GlassJAw's Avatar
1990 XSi Integra has just been sold..... waiting on payment / collection now.
Old Nov 2, 2010 | 02:01 PM
  #43906
Mattb16teg's Avatar
Community Builder
Community Influencer
Yea, I have one, lol just couldn't understand what you were trying to describe so I just gave up, haha.
Old Nov 2, 2010 | 02:02 PM
  #43907
teggi's Avatar
who was asking for pics of how i fixed the cowl leak?
Old Nov 2, 2010 | 02:14 PM
  #43908
Mattb16teg's Avatar
Community Builder
There's an OG write-up on G2IC if anyone needs it.
http://forums.g2ic.com/tegtips/interior/15.html
Old Nov 2, 2010 | 02:17 PM
  #43909
be18see1's Avatar
ah. so what I was saying is still valid.
Old Nov 2, 2010 | 02:21 PM
  #43910
teggi's Avatar
i know, but someone was asking me how i did mine. since i made a cover for the hole instead of replacing the little seals.
Old Nov 2, 2010 | 03:06 PM
  #43911
c_mack9's Avatar
if youre the one that used a cut up antifreeze jug,it was me.
Old Nov 2, 2010 | 03:55 PM
  #43912
be18see1's Avatar
Quick question: I have two wiring couplers that I'm not sure what their purpose is. One definitely went to the powersteering line but I'm not sure which. The other I have no idea. One is a four pin square plug with two green wires and two black. The other is a two pin plug with one red and one black. Any ideas? Both couplers are pretty small and are in the wiring that would have been routed out the driver's side of the firewall.
Old Nov 2, 2010 | 04:50 PM
  #43913
Mattb16teg's Avatar
Community Builder
I'm a visual guy, pics?
Old Nov 2, 2010 | 05:00 PM
  #43914
be18see1's Avatar
that would be easier, but my camera is at a friend's house...
Old Nov 2, 2010 | 05:35 PM
  #43915
ELIDA9's Avatar
I am sure that the two pin connector is the power steering one.
Old Nov 3, 2010 | 02:59 AM
  #43916
be18see1's Avatar
Ok, so now I have a four pin with two green and two black. What is/was even over on that side that is a candidate? Maybe purge solenoid for emissions? Can someone take a quick look at their car next time they're around it and check that guy out?
Old Nov 3, 2010 | 03:06 AM
  #43917
be18see1's Avatar
Aha problem solved.
Old Nov 3, 2010 | 04:59 AM
  #43918
Colin's Avatar
Originally Posted by AfroIntegra
I've read all of that before. I don't doubt they put a lot of design effort into it, and that it's over engineered in some regards. And obviously this isn't a definite indicator, but if you've ever seen the FR traction bar setup that they make for the EF chassis you'd know that whoever does their design work is by no means perfect. The EF bar they make seems to have been designed by an intern because they had to have been able to do a better job than they did. I still sorta can't get over the fact that it's as bad as it is.
I still just don't see being able to make a real judgement about a FR vs a custom/mod OEM piece like I mentioned w/o either some serious back to back testing or a very good understanding of the forces involved in the scenario (like I said, an automotive engineer). I'm not saying that the FR is a bad piece, just that I'm not convinced it's an amazing upgrade when compared to a modded stock piece. It's something I wish I was able to get more info about, but I just don't see that happening.
And as far as the bar mounting to the side of the frame rail... yes, that's what we've been saying. It bolts to where the stock tow hooks are mounted.
Old Nov 3, 2010 | 06:41 AM
  #43919
Mattb16teg's Avatar
Community Builder
What's bringing up your disbelief in this product?
Old Nov 3, 2010 | 11:43 AM
  #43920
4 more days matt!! really hope we get some warmer day time weather though!
Old Nov 3, 2010 | 12:28 PM
  #43921
negusjuda's Avatar
anyone know a good camber kit for the da i see not many people make them for our cars
Old Nov 3, 2010 | 12:37 PM
  #43922
.:Spoon_Fed_09:.'s Avatar
im rocking eibach on the rear and eBay's on the front, to tell u the truth eBay's suck, but people tell me that they are the same as skunk 2 so idk what to get
Old Nov 3, 2010 | 01:14 PM
  #43923
Mattb16teg's Avatar
Community Builder
Yea! Got a Halloween party the night before so I'm going to be hurt, LoL!
Guy who has my turbo says it looks fine but that's just after a visual inspection. He will take it apart but it'll cost me.
I just capped off the oil feed line and started the car and it didn't smoke and I figured if it was valve seals it would be horrible open manifold.
I do have the valve cover on with the vents, they were relieving a lot of pressure so maybe that also helped?
Not sure what to do.
Old Nov 3, 2010 | 01:28 PM
  #43924
projectTeG's Avatar
i heard the skunks were good. i have the spc adj. balljoints and they are ok if your not slammed.
Old Nov 3, 2010 | 02:05 PM
  #43925
skunks slip all the time. honestly, i have the ebay camber kit for up front that just replace the joints on the upper control arm that bolts to the frame (if that makes sense lol) and ive had no problems with them. hell i even bought them used
