DA Integra's Only
Old Nov 1, 2010 | 01:05 PM
  #43876
negusjuda's Avatar
Default Re: DA Integra's Only
and part numbers not gonna tell me if this steering rack i just got from a 92 da will work in my 91 da
Old Nov 1, 2010 | 01:12 PM
  #43877
Mattb16teg's Avatar
Community Builder
Community Influencer
Originally Posted by negusjuda
its very possible we did discuss it but where the problem that i would have with the header is where the half rad would sit which is why i didnt think a half rad would work i would have to sit it in a awkward position for the half rad to work im thinking of just using a stock teg rad and slim fan setup
huh? LoL
yes the fullrace traction bar sits a lot lower then stock im thinking of putting my stock one back on but im gonna have to cut it for my header to fit
Yes, it sits very, very low!
Old Nov 1, 2010 | 01:14 PM
  #43878
negusjuda's Avatar
lol matt i thought you was talking to me above when you said someone needed a half rad
Old Nov 1, 2010 | 01:56 PM
  #43879
Mattb16teg's Avatar
Community Builder
No, just turbo manifolds, since you're not cool we will exclude you
Old Nov 1, 2010 | 02:31 PM
  #43880
Colin's Avatar
Maybe, maybe not, you're basically ignoring the best and easiest way to gather info regarding that question of whether it'll fit or not. Checking part numbers is the very first thing you should do to check fitment compatibility.
If you check part numbers, and they are the same, then bam, you have your answer. Yes, it will fit. However, if you check part numbers and they aren't the same you simply need to continue to search for your answer as usual. And what, you wasted 90 seconds of time?
I'd say the amount of times I've wasted 90 seconds finding that part numbers are different is no where near the same as the massive amounts of time I've saved myself when I find out that the part numbers are the same. The benefit to checking part numbers can be huge, whereas the drawback is nothing or next to nothing.
Go look at the part numbers, trust me.
Old Nov 1, 2010 | 03:00 PM
  #43881
ELIDA9's Avatar
Originally Posted by Colin
Eli, I'm guessing you don't have a Full Race traction bar and have never seen one on a DA. There isn't ground clearance or weight benefits to this traction bar, for the most part it's worse than stock in both those categories.
I have never had them on a DA before.....I am suprised to hear that they sit lower than the factory units. Good thing I'm not slamed. Thanks for the info Colin.
Old Nov 1, 2010 | 03:09 PM
  #43882
wearedaughters's Avatar
Throwback:
http://www.flickr.com/photos/wearedaughters/4091188568/http://www.flickr.com/photos/wearedaughters/4091188568/ by http://www.flickr.com/people/wearedaughters/, on Flickr
Old Nov 1, 2010 | 03:12 PM
  #43883
Mattb16teg's Avatar
Community Builder
Yup, just good for the increased stiffness and points of adjustment.
Old Nov 1, 2010 | 03:37 PM
  #43884
Colin's Avatar
I'm not so certain the FR crossmember is really that much of a benefit at all besides adjustable caster and header clearance. Well, and bling factor. I don't have any data to back it up, but I'm beginning to wonder if a modified OEM crossmember would be superior in all regards except bling.
You can easily cut and notch your crossemember to clear just about any header you'd want to run and you can create adjustable caster with accord radius rods or even do something completely custom. And iirc there's even a spherical bearing setup you can run w/ the OEM style of radius rod.
This is one of those things that I'd love to have the time and resources to fully investigate, but realistically I don't. So until I run into a noticeable issue w/ my Full Race I'll be keeping it. I do however wish that I had installed the crossmember all by itself so that I could have a back to back comparison. Unfortunately I built the car from the ground up so there was no baseline with the stock crossmember.
Old Nov 1, 2010 | 04:00 PM
  #43885
Mattb16teg's Avatar
Community Builder
You have a point but I would rather buy something quality then attempt to make something half way work. That's just me though. It is also stiffer than the OEM unit. I did some playing around with them back when I put mine on. The OEM one flexed with forces applied to it more than the Full Race unit.
Old Nov 1, 2010 | 04:06 PM
  #43886
be18see1's Avatar
Ah but Matt, you should consider the mounting location/method. Doesn't the Full Race bar mount to the tow hook location? I would think now you're dealing with force being applied in a different way and that the mounting plates wouldn't be as solid as the factory pieces. The subframe is only as solid as its weakest point. I've looked at it before and I think I feel the same way as Colin.
Old Nov 1, 2010 | 04:18 PM
  #43887
Mattb16teg's Avatar
Community Builder
The tow hook location? I don't think so, LoL although I have no idea where that is so who knows.
Sorry, let me clear it up, I was just referring to the units themselves, not on the car.
Old Nov 1, 2010 | 05:11 PM
  #43888
be18see1's Avatar
I guess I mean tie downs, not tow hooks. There's two of them, one on each frame rail on the front of the car right behind the bulkhead. I think each has three 14mm bolts.
Old Nov 1, 2010 | 05:40 PM
  #43889
negusjuda's Avatar
lol yea im not a fan of snails on my car
Old Nov 1, 2010 | 05:43 PM
  #43890
Mattb16teg's Avatar
Community Builder
It mounts where the stock one mounts.. On each side, 1 bolt straight up into the frame and 2 - 3 bolts right into the frame vertically.
  #43891
negusjuda's Avatar
arent ef steering racks part numbers diffrent then da steering racks yet the ef rack will work in a da i understand some people wont people to look and search stuff which 70 percent dont find there answer when they search just like how searching the part numbers really dont tell me if it will work i have bout parts from the dealer with the same part number and it not be the right part s again part number dont answer my question
Old Nov 1, 2010 | 05:44 PM
  #43892
Mattb16teg's Avatar
Community Builder
LoL, we've all been there! Once it bites you, you are done!
Old Nov 1, 2010 | 07:41 PM
  #43893
Bond's Avatar
Haha soooo true.
I'm falling in love with my DA all over again and it's got me motivated to finish my new setup and get it running.
Old Nov 1, 2010 | 08:14 PM
  #43894
OldSkoolDa91's Avatar
hell yeah. boost is a very powerful bite! lol
you ready for sunday matt?
Old Nov 2, 2010 | 02:49 AM
  #43895
be18see1's Avatar
Oh ok. There IS some aftermarket crossmember that bolts up there though. I know I'm not crazy.
Old Nov 2, 2010 | 04:37 AM
  #43896
Mattb16teg's Avatar
Community Builder
Ju coming homes?!
Sweet, yea hopefully we get down there at a decent time but I doubt it. lol
Remember to bring lots of clothes! It's gonna be freaking cold again.
hahah you had me thinking I was crazy! I've never seen a traction bar that mounts there, wonder what ones your talking about.
Old Nov 2, 2010 | 05:02 AM
  #43897
Colin's Avatar
What sort of testing did you do? I don't see how you could do anything worth interpreting w/o some pretty intense equipment. And in an instance like this the rigidity of the part off the car is almost a completely useless comparison. the rigidity of the piece will change once bolted to the car because at that point the piece braces the car as well as the car bracing the crossmember. Additionally, some gnarly research may have gone in to the OEM crossmember, maybe it's designed in such a way that the flex you saw isn't an issue due to the way the forces are put on the piece when installed. Unless you're a high level automotive engineer I don't know how qualified you'd be to make any judgements regarding this stuff (no offense, I don't fall into that category either).
And yes, it does mount to where the stock tow hooks are bolted up, as well as 1/2 of the mounting locations the stock crossmember uses.
Old Nov 2, 2010 | 05:04 AM
  #43898
Colin's Avatar
You clearly didn't understand one word of my post, and I feel it was phrased in a manner making it extremely easy to understand. Yes, the EF part number is different, and yes it fits. My post agrees with that concept. In this case that situation doesn't apply. You've been wasting your time, you should have your answer already if you were willing to spend a few minutes on acuraautomotiveparts.org I don't think I can explain this in any more simple manner than I did originally so I'm not going to bother.
Old Nov 2, 2010 | 05:41 AM
  #43899
Mattb16teg's Avatar
Community Builder
No "scientific" comparisons were performed. Just used some caveman like push and pull techniques, leverage and weights to play around with it flexing it. Heck even standing on it! LoL, those were the best tests at hand.
You point about judgment carries no meaning to me because it is my opinion, I'm not composing a write up for Super Street so no biggie.
I would rather spend the money and buy something that I feel is a superior product.
I also put my traction bar on with mounts, so even though I want to say it felt better, who knows how much of that is attributed to the traction bar itself.
Old Nov 2, 2010 | 06:51 AM
  #43900
hb420's Avatar
Even though the part number is different and it can be put in.... you have to think about the things that have to be changed out to make it work. So in all reality it doesn't work because it's not plug and play like it should be when you order stuff from honda. Ive owned alot of hondas and i can say that i've never got the wrong part when i ordered sutff using the part numbers
