DA Integra's Only
Old Oct 31, 2010 | 09:39 AM
  #43851
OldSkoolDa91's Avatar
Default Re: DA Integra's Only
well thats good, i guess. lol
man, my friend just got his db8 tuned yesterday....OMG! he put down 430. REALLY needs better tires. has brand new falkens on it n they do not hook at all til like 95% of the way through 3rd after pedaling the **** out of it but once it hooks, holy ****! thing is straight nasty!
Old Oct 31, 2010 | 11:27 AM
  #43852
ncsi's Avatar
Took my turbo mani off yesterday. Its a spoolin performance cast log manifold. So I cleaned all residue off with this all purpose cleaner. Then scotch brighted it. Now just layed a layer of white high temp primer. Getting ready to spray the black coat on. Pics later hopefully it hold together ha!
Old Oct 31, 2010 | 12:27 PM
  #43853
be18see1's Avatar
^^Does that clear a full rad?
Old Oct 31, 2010 | 12:32 PM
  #43854
ncsi's Avatar
No sir ftmfl! I got a cxracing half rad.
Old Oct 31, 2010 | 01:18 PM
  #43855
be18see1's Avatar
shhhhhhhhhhhhhhiiiiiiiiiiiii that's what i wanted to run. I really don't want to have to buy a half rad when i have this perfectly good c&r full rad.
Old Oct 31, 2010 | 02:14 PM
  #43856
negusjuda's Avatar
wanna sell the full rad although im not sure if it will clear my kid racing header neither
Old Oct 31, 2010 | 02:18 PM
  #43857
Mattb16teg's Avatar
Community Builder
Community Influencer
You will HAVE to use a half sized rad, think we've discussed this before.
Old Oct 31, 2010 | 03:36 PM
  #43858
ncsi's Avatar
There are a couple mani's that work with full size. A kid with a b16 boosted is running one around here.
Old Oct 31, 2010 | 03:41 PM
  #43859
ncsi's Avatar
Sprayed mani, wastegate extension and part of wastegate black today with vht paint!
Old Oct 31, 2010 | 03:48 PM
  #43860
be18see1's Avatar
You definitely don't HAVE to run a half size. There's lots of manifolds that clear, I just wanted to know if the spoolin log was one of them.
Old Oct 31, 2010 | 04:07 PM
  #43861
The G2 Racer's Avatar
Post how that holds up, I want to paint my tubular but I don't want to spend the money to send it off the island to ceramic coat it.
Old Oct 31, 2010 | 04:15 PM
  #43862
ncsi's Avatar
^Will do! I used some adhesive remover. Then scuffed it with scotch bright. Then used vht primer then paint. So will see!
Old Oct 31, 2010 | 04:41 PM
  #43863
Might still have some of my hot parts coated because then I know they'll look good for years to come (I've got no real drive to change my new set up as I want to push it as far as I can).
Old Oct 31, 2010 | 06:18 PM
  #43864
ELIDA9's Avatar
mines....
Old Oct 31, 2010 | 06:40 PM
  #43865
EFcivicJDM's Avatar
nice eli
my subframe is flattened cos its so low will the full race traction bar cure this or is there away around it?
thanks
Old Oct 31, 2010 | 06:43 PM
  #43866
ELIDA9's Avatar
the traction bars will help, but I dont know by how much? Might want to raise the car up a bit IMO.
Old Oct 31, 2010 | 08:28 PM
  #43867
Mattb16teg's Avatar
Community Builder
There are manifold's that work with full sized rads, in other cars, none that I know of in DA's, like I said we had this talk recently.......
If there's lots of em for our cars, please post them up!
Old Oct 31, 2010 | 08:29 PM
  #43868
projectTeG's Avatar
i test fitted my spooling performance manifold on my Da tonight and it cleared the rad just fine, but the cold side was hitting the fans, so you will have to run slim fans and flip them for more clearance.
Old Oct 31, 2010 | 08:42 PM
  #43869
i've got an emusa cast mani that i'm curious to see how fitment is with the stock rad. just havent had a chance to check it out yet
Old Nov 1, 2010 | 02:52 AM
  #43870
be18see1's Avatar
Flipping the fans is not a problem. Mine are already flipped.
Old Nov 1, 2010 | 11:04 AM
  #43871
Mattb16teg's Avatar
Community Builder
Just incased my turbo in foam and bubble tape and sent it out. This guy is a stand up guy and will warranty anything wrong with the turbo. He said unless it appears it was oil starved which isn't the case due to the loads of oil blowing out of my exhaust!
Can't wait to get it back and have it NOT smoke its butt off!
Old Nov 1, 2010 | 12:19 PM
  #43872
negusjuda's Avatar
its very possible we did discuss it but where the problem that i would have with the header is where the half rad would sit which is why i didnt think a half rad would work i would have to sit it in a awkward position for the half rad to work im thinking of just using a stock teg rad and slim fan setup
Old Nov 1, 2010 | 12:24 PM
  #43873
negusjuda's Avatar
also is the steering rack from a 92 da the same as the 90-91
Old Nov 1, 2010 | 12:30 PM
  #43874
Colin's Avatar
Originally Posted by EFcivicJDM
nice eli
thanks
If your stock crossmember is that damaged due to your ride height then you will DESTROY a Full Race crossmember. I would say it would be a very unwise move and extremely dangerous as the failure of an aftermarket crossmember will be drastic and possibly catastrophic compared to putting a stock crossmember thru the same beating. You have 3 options for your current problem:
1) Raise the car up. (The intelligent option)
2) Have a custom traction bar designed which solves your problems. (The ideal, extremely expensive option which may not be 100% possible)
3) Keep it low and beat your car to shreds. (The not-so-intelligent option)
Eli, I'm guessing you don't have a Full Race traction bar and have never seen one on a DA. There isn't ground clearance or weight benefits to this traction bar, for the most part it's worse than stock in both those categories.
Old Nov 1, 2010 | 01:02 PM
  #43875
negusjuda's Avatar
yes the fullrace traction bar sits a lot lower then stock im thinking of putting my stock one back on but im gonna have to cut it for my header to fit
