DA Integra's Only
Old Jul 12, 2010 | 02:44 PM
  #41126
Silva Bullit DC4's Avatar
Default Re: DA Integra's Only
Originally Posted by Mattb16teg
Woozers, that sounds like a boost creep problem to me!
Nope. The logs showed the same boost plots. 18.7 psi. The compressor was sucking all the hot air from the wastegate, making my intake air temps hotter, therefore, robbing horsepower. My buddy's car did the same thing and gained the same power a couple years back, only they did his car as an experiment with a long 90 degree bend.
https://honda-tech.com/forums/showth...light=dumptube
The post my tuner SOHC MShue was talking about.
Old Jul 12, 2010 | 02:45 PM
  #41127
JDM'd OUT's Avatar
Originally Posted by kNOwLedGe.
It will ride firm but not too bouncy. 7kg is a mildly stiff spring rate in the front, but the 3kg in the rear will keep the ride smooth.
This setup would understeer for sure with stock sway bars.
No wonder your name is "kNOwLedGe" you sure know a lot
Old Jul 12, 2010 | 02:47 PM
  #41128
JDM'd OUT's Avatar
[QUOTE=90_DA;43002374] this blue is called buckingham blue pearl. b-59p.
It's very dark in the shade but looks great in the sun..
I got a new wallpaper pic. I really love the mugen kit on our cars. One of the few reasons why i switched to the 90-91 front bumper
Old Jul 12, 2010 | 02:48 PM
  #41129
DumaDA's Avatar
Originally Posted by Colin
Pretty darn soft IMO (I'm running 700f/600r).
7kg/mm = 392lb/in
3kg/mm = 168lb/in
While that front spring rate isn't crazy soft, the rear is pretty darn soft, not to mention the huge difference from front to back. But really it depends on what you're looking for. A quick search gave me 263 lb/in 143 lb/in as the stock DA spring rates. I haven't looked at those numbers in a long time, but they seem about right (but I cant say for sure).
Check out this thread for some interesting talk about spring rates and some listed rates for various lower springs which typically have had much softer rates than we see with current coilover setups.
http://forums.g2ic.com/showthread.php?47383
keep in mind that this suspension set up isnt going to be used for track or cornering, only looking for a smooth ride that will be comfy for my son and not too bouncy
Old Jul 12, 2010 | 02:56 PM
  #41130
Hondadaturbo's Avatar
Originally Posted by Silva Bullit DC4
Good idea right there.
But regardless, he still needs to get that thing routed outta his engine bay, so he can get the most outta his setup. I dynoed my car with & without a dumptube, (and the difference was 40 whp! ::eek:), but some setups will vary.
heres my problem ......everything under the hood is pretty much black lol and covered in exhaust crap
someone thought it would be funny to cut my dump tube ....some friends ive got!
Old Jul 12, 2010 | 03:01 PM
  #41131
Mattb16teg's Avatar
Community Builder
Community Influencer
Why can't you get something to work with that, that is an easy bend. I need to post pics of my setup and then you'll see a real headache. Gotta get a dump soon though!
Old Jul 12, 2010 | 03:04 PM
  #41132
tegtuner01's Avatar
hahaha damn barry
Old Jul 12, 2010 | 03:07 PM
  #41133
Colin's Avatar
Originally Posted by DumaDA
keep in mind that this suspension set up isn't going to be used for track or cornering, only looking for a smooth ride that will be comfy for my son and not too bouncy
Yeah, that's why I qualified it with "what you're looking for". If you're looking for comfy, then those are some decent rates. "Bounce" will be dictated by your shocks, not your springs. A soft spring will bounce horribly on a blown or under-damped shock. A stiff spring will not bounce on a high quality properly damped shock.
Old Jul 12, 2010 | 03:15 PM
  #41134
kNOwLedGe.'s Avatar
I've been spracking on DA Integras for 10 years. If I didn't know a lot by now, I'd have to be retarded or something.
What I found really funny is that I looked back in my old notebooks from my Freshman year in college (2001) and there are all kinds of "doodles" that I drew of DAs while in class. That was before I even bought my DA. I was researching and plotting my car 2+ years before I even bought it.
Hence: "This aint my first rodeo, cowboy."
Old Jul 12, 2010 | 03:21 PM
  #41135
DumaDA's Avatar
hmm i guess ill have to decide whether i wanna buy those tein basics with extended top hats or just buy some tokico whites for the back
Old Jul 12, 2010 | 03:37 PM
  #41136
Just extend it under the oil pan homie, or at least downward towards the ground right in front of the pan, you'll be fine after that. Has the car been dynoed? Because if so, if you redo your dumptube without a retune, it may cause a lean condition, being that you'll be sucking in more available oxygen & less hot exhaust gases.
If not, at least take it to get some baseline runs done, to make sure your AFR's are reading correctly. Does the car have a wideband?
Old Jul 12, 2010 | 04:28 PM
  #41137
teggi's Avatar
the tein basics are ok ish, but the lower you go the harder the ride is
Old Jul 12, 2010 | 04:33 PM
  #41138
DumaDA's Avatar
thats why we got the extended top hats haha, go dumped and it rides smooth still, i'll never know for sure till i try it, ill probably slap it on and see how it is
Old Jul 12, 2010 | 04:38 PM
  #41139
teggi's Avatar
for the front u will need the extended tops for sure, you might have to do that fork trick to get more travel otherwise you'll bottom out big time
Old Jul 12, 2010 | 04:41 PM
  #41140
DumaDA's Avatar
yeah i already bottom out pretty bad with extended top hats and skunk2 coilovers on the illuminas in front, maybe those spring rates are too soft then
Old Jul 12, 2010 | 04:47 PM
  #41141
teggi's Avatar
maybe
Old Jul 12, 2010 | 05:03 PM
  #41142
bonspeed's Avatar
yesterday's local autoslalom event... just thought i'd share...
video:
http://www.youtube.com/watch?v=xKvEp...eature=related
Old Jul 12, 2010 | 05:40 PM
  #41143
Mattb16teg's Avatar
Community Builder
Just finished my valve cover.
Turned out different....... LoL
The color was an OEM Ford paint, Mocha metallic bronze.
Turned out like a sand, khaki color with metallic flake in it.
Just finished putting my last coat of clear on it.
Will post some pics tomorrow when it dries.
Old Jul 12, 2010 | 06:12 PM
  #41144
Colin's Avatar
Old Jul 12, 2010 | 06:21 PM
  #41145
yes the car is tuned! i tune it myself on eCtune yes i have a wideband and the dumptube is a bigger headache than you think ....the turbo is in the way with no space if i try to bend it twards the passenger side the radiator ...downpipe is in the way since it exits the passenger side! the driver side is ****ed since the compressor and my 3000lb cross member is in the way!
Old Jul 12, 2010 | 06:35 PM
  #41146
Mattb16teg's Avatar
Community Builder
FFFFFFFFFFFFFFUUUUUUUUUUUUUUUU!
Just ruined the paint on the VC, ****ing can of clear spit tons of spots all over it......
Don't really dig the color anyway, probably just spray over it with go old wrinkle black.
Old Jul 12, 2010 | 06:37 PM
  #41147
Mattyg2's Avatar
Nice! is that your steering rack squeaking as you turn?
Old Jul 12, 2010 | 06:42 PM
  #41148
OldSkoolDa91's Avatar
exactly why i DONT clear anything i paint, parts wise
Old Jul 12, 2010 | 06:44 PM
  #41149
projectTeG's Avatar
move the battery and vent it that way? or back towards the passenger side.
Old Jul 12, 2010 | 07:01 PM
  #41150
Post a bay pic homie, lemme see what ya got there.
