DA Integra's Only
Old Apr 21, 2010 | 07:30 PM
  #38626
90IntegraTuner's Avatar
Default Re: DA Integra's Only
Originally Posted by slammedg2
ok soo i just got this type r valve cover to day and its a lil dirty does anyone have any trick to get it back to bright red
Either get it powder-coated back to stock or give it a nice bath...lots of scrubbing...if it is chipped or the paint has faded, i would suggest powder-coating it
Old Apr 21, 2010 | 07:37 PM
  #38627
slammedg2's Avatar
its just real dirty i guess ill try to hot a** water and some good soap
Old Apr 21, 2010 | 08:08 PM
  #38628
fox_137's Avatar
super clean.
Old Apr 21, 2010 | 08:24 PM
  #38629
I might also suggest, if that does not work, to take it to a car wash (self) and use some tire acid...now make sure that you do not leave that stuff on there for more than 30 seconds or it will do more damage than good man...but when you spray a light coating on scrub with a good sponge or something non-abrasive...that should do the trick for hard to get up oil stains and such
Old Apr 21, 2010 | 09:18 PM
  #38630
tooquik209's Avatar
oem hood bra for sale! pm me for info and offer!
6.5/10 condition comes with fender pieces to
Old Apr 22, 2010 | 04:13 AM
  #38631
Mattb16teg's Avatar
Community Builder
Community Influencer
Just strip it then clean it up and repaint it with some red wrinkle paint!
Old Apr 22, 2010 | 06:09 AM
  #38632
lilvietboy's Avatar
I guess my parents don't want me tearing apart mydash also haven't had much free time due to school and figuring out college so lucky me my parents are hooking it up. No car next week but it'll all be fixed than I'm going to get tinted maybe 25 rear 35 50 front
Old Apr 22, 2010 | 07:46 AM
  #38633
Mickeeezy's Avatar
i have 5% rear tints. it's dark as fvvvvvvck. lol
25% is perfect for rear. 35 in front might attract the boys. just saying =]
Old Apr 22, 2010 | 08:06 AM
  #38634
slammedg2's Avatar
yea i been uses a tooth brush lol i also heard that wd40 works real good ill try that today n post pics
Old Apr 22, 2010 | 08:56 AM
  #38635
Mickeeezy's Avatar
Damn.. this sounds like a bitch to dooooz!
http://g2ic.com/forums/showthread.ph...+lights+rewire
Old Apr 22, 2010 | 09:37 AM
  #38636
b16-ef-si's Avatar
its actually very easy...and there is absolutely no need to remove the trim surrounding the button..they made it sound harder than it is
Old Apr 22, 2010 | 10:12 AM
  #38637
OldSkoolDa91's Avatar
sounds easy enough to me. i'm gonna have to remember that when i start workin on my da again
Old Apr 22, 2010 | 10:42 AM
  #38638
lilvietboy's Avatar
Yeah not sure how 35 will be definately draw attention to myself
Old Apr 22, 2010 | 10:55 AM
  #38639
DumaDA's Avatar
if i was going to get tint, i'd go with 50%, UV Protective but not noticeable
Old Apr 22, 2010 | 11:04 AM
  #38640
Mickeeezy's Avatar
Anyone know of a DIY for a kill switch?
can't afford an alarm yet. hahah
Old Apr 22, 2010 | 11:09 AM
  #38641
Mickeeezy's Avatar
"Install an in-line fuse on the extension lead, [close to the fuse box, and no more then 5A] then plug the lead into one of the free pins, there is a 12V+ constant, [hot at all times] 2nd ign., [hot in run] and a park light free pin, [hot when park/head lights are on] I would suggest the 2nd ign. free pin."
I don't really understand this part.. help me plzzzz!
where are these pins located? any pics? tips?
Old Apr 22, 2010 | 12:28 PM
  #38642
lilvietboy's Avatar
I want it dark but not too dark in the front
Old Apr 22, 2010 | 01:00 PM
  #38643
when you look at your fuse box under your dash, not every location for a fuse (pin) will be used. they're simply saying to tap into one of those locations (pins). as you look at the diagram that you should have on the fuse box cover, it should show you whats free
Old Apr 22, 2010 | 01:13 PM
  #38644
Mickeeezy's Avatar
Thank you for the clarification!!!
I think i got it from here.
Just one more thing. It's recommended that i use the 2nd ign. pin.
i've searched for this "2nd ign. pin" but i can't seem to find it.
Old Apr 22, 2010 | 01:31 PM
  #38645
95-db6-719's Avatar
actually i dont know how DA's are but i had actual pins at the top of my fuse box and i used them to wire my foglights on my DB6 jdm front, using a switch.
if you are gonna run a kill switch why not just tap into the fuel pump hot circuit and run a switch from that...?
Old Apr 22, 2010 | 01:44 PM
  #38646
not really sure where the "second ign. pin is. havent looked lol
Old Apr 22, 2010 | 02:34 PM
  #38647
Mickeeezy's Avatar
I ran the wire into a fuse slot and the headlight just stays on but the foglights are completely disabled. even when i turn the fog switch on.
Here's what i did: Cut the wire (Red with Yelow line) and put a 5a fuse in between the extended wire that runs into a fuse slot.
Prepare yourself for a horrible diagram:
Dashes (---) = wire
RED/YELLOW WIRE that was connected to FOG switch is connected to EXTENDED WIRE--------------5a fuse--------------FUSE SLOT.
WTF am i doing wrong?
Hope that made some kind of sense. LOL
Old Apr 22, 2010 | 03:14 PM
  #38648
Edgar206's Avatar
new here where all the pics at??
Old Apr 22, 2010 | 05:09 PM
  #38649
hmm, im really not sure man... are you sure you hooked up the right part of the wire to the wire extension? supposed to hook up the wire coming from the switch to the fuse box. then the other part thats still in the harness you cap off. maybe you mixed them up?
Old Apr 22, 2010 | 05:23 PM
  #38650
Mickeeezy's Avatar
WOW! i am puzzled...
OldSkoolDa91 you're the man! i ran the wire that WASN'T coming from the switch.
