What is needed for tapping the oil pan?
Old Mar 25, 2003 | 07:36 AM
1 del slo's Avatar
Default What is needed for tapping the oil pan?
I got a greddy turbo kit used for my d16z6,,,what all do i need to tap the oil pan, and for the feed and return lines??
Old Mar 25, 2003 | 07:45 AM
PM-Performance's Avatar
Default Re: What is needed for tapping the oil pan? (1 del slo)
a drill , the ness fittings and lines.
Old Mar 25, 2003 | 08:44 AM
1 del slo's Avatar
Default Re: What is needed for tapping the oil pan? (itr206)
where can i find this stuff???
Old Mar 25, 2003 | 09:21 AM
mamaboy's Avatar
hit up Flamenco-T aka Stan....he carries the oil feed and return kit.....great service too....
Old Mar 25, 2003 | 09:29 AM
shortyz's Avatar
Default Re: What is needed for tapping the oil pan? (mamaboy)
https://honda-tech.com/zerothread?id=67146 -oil return
https://honda-tech.com/zerothread?id=109160 -oil return line setup
https://honda-tech.com/zerothread?id=114490 -oil return line parts
https://honda-tech.com/zerothread?id=71999 -where to weld oil return
https://honda-tech.com/zerothread?id=119100 -oil return line
https://honda-tech.com/zerothread?id=119539 -oil pan welding
https://honda-tech.com/zerothread?id=119715 -oil pan welding
https://honda-tech.com/zerothread?id=118687 -oil grade to use
https://honda-tech.com/zerothread?id=118694 -ft for oil feed line
https://honda-tech.com/zerothread?id=118807 -oil feed line
https://honda-tech.com/zerothread?id=119681 -oil feed line
https://honda-tech.com/zerothread?id=93550 -part for oil feed line
https://honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
https://honda-tech.com/zerothread?id=126335 -oil t question
https://honda-tech.com/zerothread?id=125438 -another place to buy oil lines
https://honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
https://honda-tech.com/zerothread?id=134078 -feed diagram
https://honda-tech.com/zerothread?id=133948 -oil bpst fitting again
https://honda-tech.com/zerothread?id=144586 -oil feed line restrictor
https://honda-tech.com/zerothread?id=155510 -oil leaks
https://honda-tech.com/zerothread?id=158018 -oil feed 3' better
https://honda-tech.com/zerothread?id=156571 -oil pan bolts
https://honda-tech.com/zerothread?id=170223 -oil pressure readings
https://honda-tech.com/zerothread?id=168084 -oil feed fitting
https://honda-tech.com/zerothread?id=131450 -oil feed diagram
https://honda-tech.com/zerothread?id=195068 -oil pressu
https://honda-tech.com/zerothread?id=364948 -BSPT and NPT AN explanation. ***
solo2fresh
Mar 2, 2011 04:09 PM
gsr x civic
Mar 23, 2007 07:19 AM
UsaTLinh
Jun 2, 2004 10:58 PM
iperez
Jan 18, 2003 04:36 PM
GruvyTune
Nov 18, 2001 03:59 PM
