Holset users unite!
Old Feb 21, 2008 | 07:06 AM
  #2251
billman's Avatar
Default Re: (StavrosRedline)
I think that it is good for at least 650 hp.
Ellinas eisai? Pou vriskesai?
Old Feb 21, 2008 | 08:16 AM
  #2252
b20vtechb's Avatar
my guess would be 85-95lbs/min for the hx50 800whp should be no problem for it
Old Feb 21, 2008 | 08:50 AM
  #2253
StavrosRedline's Avatar
"Only" a 65mm inducer tho, so surely not much more than 700bhp, no? Or are Holsets a bit special like that? Genuinley no idea, just hope it spools fairly nicely, as its not an all-out power car.
Power is good tho :D
Old Feb 21, 2008 | 11:41 AM
  #2254
SwappedTURBOegg's Avatar
Default Re: (b20vtechb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechb &raquo;</TD></TR><TR><TD CLASS="quote">my guess would be 85-95lbs/min for the hx50 800whp should be no problem for it</TD></TR></TABLE>I dont see that happening with a 65mm wheel.
Old Feb 21, 2008 | 11:50 AM
  #2255
for reference i was only trapping 134 with 28psi on my 60mm hx40, thats only around 500.
Old Feb 21, 2008 | 12:21 PM
  #2256
b20vtechb's Avatar
Default Re: (SwappedTURBOegg)
theres more to a turbo then just the inducer diameter exducer diamater is just as important and its much larger on that turbo then the hx40 . also look at the borg-warner turbos they flow more with smaller inducers then the garretts. you can't just boil the flow down to a few measurements.
Old Feb 21, 2008 | 12:33 PM
  #2257
uhh... ok but these ARE the same company and basically the same turbo just a slightly larger compressor wheel. It will still have the same inducer to xducer ratio.
borg warner turbos are extended tip (cheater turbos they have been called)
youre comparing apples to oranges. and quit frankly i think everyone on here has been over inflating the flow rates of the holset turbos just a bit. i have ran 3 diffrent ones on MY car (how many have you ran?) yes i liked it. but if it was flowing as much as you guys think i would have made more power.
we all know its hard to get a map for these turbos especially when they never made 2 of the same turbo (lol?)
Witch brings me back to the initial point. youre over inflating the numbers.
Old Feb 21, 2008 | 12:48 PM
  #2258
Must admit, I thought it had a pretty huge exducer compared to inducer size, which i know is good for high boost efficiency, but didnt think it made much odds regarding overall maximum power.
Old Feb 21, 2008 | 05:32 PM
  #2259
b20vtechb's Avatar
i really doubt that they have the same ratio, that would be the trim the hx 35 and 40's don't have a huge diff in the inducer and exducer. so i guess post up the wheel specs you have and we'll see what the trim is..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">uhh... ok but these ARE the same company and basically the same turbo just a slightly larger compressor wheel. It will still have the same inducer to xducer ratio.
Witch brings me back to the initial point. youre over inflating the numbers. </TD></TR></TABLE>
Old Feb 22, 2008 | 12:21 AM
  #2260
b20vtechb's Avatar
not to be a dick but i don't think you had that thing tuned very well. cause i made 422whp on a pistons and rods ls/vtec stock bore on only 19psi sounds like your ignition timing was overly conservative or there was something else going on. when i made that run it rolled onto the dyno first pull was 360whp 3 pulls later still same boost 422whp amazing what the correct ignition timing can do. i'm pretty sure that if i woulda had some race gas 500+ wouldn't of been a problem at all for the hx35, i didn't wanna push the pump gas much more then that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">for reference i was only trapping 134 with 28psi on my 60mm hx40, thats only around 500.</TD></TR></TABLE>
Old Feb 22, 2008 | 07:17 AM
  #2261
b.serious's Avatar
Default oil pressure for hx35
hey i was just wondering if you people run an oil restrictor for the holset turbos. ive got an hx35 running on a b16.. not boosting as a matter of fact not even driving the car as am waiting on my ecu to come.
what oil pressure will keep it healthy and wont blow past the seals???
thanks
Old Feb 22, 2008 | 07:37 AM
  #2262
h23isnotabigblock's Avatar
i dunno if this appilies here, but i just recently purchased a hx35 for my accord and then stumbled upon this thread, ironic!
anyways, my question is, i have a 95 accord ex coupe with a f22a bottom and a jdm f20b head, going to be running that hx35, and i wanted to know if the 560 evo injectors will be sufficient for around 15lbs? also the FPR im using is boost referenced 1:1 so i dunno if that will help extend the range of those injectors. for pcm im using a chipped p28 on crome.
also what can i use for datalogging? that way i could tell for sure what my duty cycle really is. im looking into trying to tune my car myself, and i have a laptop and crome, but do i have to burn a new chip every time or can i get like a romulator or somethng similar? where do i get one?
thanks
Eric
Old Feb 22, 2008 | 08:05 AM
  #2263
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechb &raquo;</TD></TR><TR><TD CLASS="quote">not to be a dick but i don't think you had that thing tuned very well. cause i made 422whp on a pistons and rods ls/vtec stock bore on only 19psi sounds like your ignition timing was overly conservative or there was something else going on. when i made that run it rolled onto the dyno first pull was 360whp 3 pulls later still same boost 422whp amazing what the correct ignition timing can do. i'm pretty sure that if i woulda had some race gas 500+ wouldn't of been a problem at all for the hx35, i didn't wanna push the pump gas much more then that
22 advanced at 28psi
do you have any trap speeds? dynos lie trap speeds do not.
Old Feb 22, 2008 | 09:25 AM
  #2264
billman's Avatar
Holsets have also some kind of extended wheels compared to Garretts. I ask this question at the Bullseye power forum. Holset calls it High Pressuse Compressor Impeller or something like this. So, Borg Warner and Holset are very close. Borg warner can be sold better because they are not so common like holsets.
Old Feb 22, 2008 | 11:11 AM
  #2265
They certainly do have large educers, it enables them to be efficent at 3bar boost+, where Garretts are usually on their knees at 2bar+, but i still cant get my head around how that would equate to more actual airflow for a specific inducer size.
But hell, im no scientist!
Old Feb 22, 2008 | 06:53 PM
  #2266
slowhitEJ1's Avatar
i'm working on a HX35 D16 vitara build.. Using a custom twin scroll mani, 2 38mm tials, decking the block to raise compression a little, Y8 head, 105300 cam, probably a full valve train, and the other usual bolton mods..i'll keep ya'll updated as it goes..
Old Feb 22, 2008 | 07:24 PM
  #2267
b20vtechb's Avatar
ok well i found a little more info right off holsets site.
Hx35 range base flow is .46 kg/s and that equates to 61lbs/min
Hx40 range base flow is .53 kg/s and that equates to 70lbs/min
Hx50 range base flow is .75 kg/s and that equates to 99lbs/min
these are gonna be a little diff for each turbo cause they have a **** ton of diff options but these should be in the ballpark.
do you have any trap speeds? dynos lie trap speeds do not.</TD></TR></TABLE>
Old Feb 23, 2008 | 01:42 AM
  #2268
70lb/min on the HX40, as i suspected from measuring the wheels, doing comparisons, etc, cool, that will do.
Old Feb 28, 2008 | 07:47 PM
  #2269
holset b18c's Avatar
anyone has a staock holset 5 bolt flange for sale with 3 inch v band!! i need one !! just pm or give me some info where to buy one thanks
Old Feb 28, 2008 | 11:34 PM
  #2270
billman's Avatar
Hi, i am about to upgrade my holset HX40 (56mm inducer 8 blade) to Super 40 (60mm inducer 7 Blade) specs and i was told that because my turbo has allmost no km on it and the new impeller balanced from the factory comes that i must simply put them toghether and dont balance anything.
Can it be? What should i do?
Old Feb 29, 2008 | 12:11 AM
  #2271
85tr's Avatar
Default Re: (billman)
what has everyone been running for oil supply ?
Old Feb 29, 2008 | 11:48 AM
  #2272
3M TA3's Avatar
Getting closer here the Full race mani and HX55/BW hybrid
Old Feb 29, 2008 | 02:28 PM
  #2273
blundar's Avatar
Bruce, if your motor holds together in one piece then it should be a monster. Good to see you actually have your manifold and turbo pieces. Give me a call sometime.
Old Feb 29, 2008 | 05:20 PM
  #2274
speeddave's Avatar
Default Re: (blundar)
whats the deal with that HX55/BW hybrid? custom built? just curious to see what kind of updates there are for the holsets, specifically the hx35's.
Old Feb 29, 2008 | 07:32 PM
  #2275
blundar's Avatar
Default Re: (speeddave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speeddave &raquo;</TD></TR><TR><TD CLASS="quote">whats the deal with that HX55/BW hybrid? custom built? just curious to see what kind of updates there are for the holsets, specifically the hx35's.
It was made by a local turbo shop (Diesel Injection Service in Cincinnati, OH) on a custom basis. Apparently, the Borg exhaust housing with a little machining will work wonders. Which Borg - I have no idea.
If you look through this thread, you'll find that a HX40 compressor wheel is the only real easy upgrade option for a HX35.
