Holset users unite!
Old Nov 22, 2007 | 02:25 PM
  #2126
Frickr's Avatar
Default Re: (rorik)
you mean to say that the turbo we pulled of our cummins (hx35) will work on my little honda??? that thing seems huge. if so, hell i got a turbo, and i just need some parts to bolt it on
Old Nov 22, 2007 | 03:18 PM
  #2127
SwappedTURBOegg's Avatar
you call the 35 a big turbo? lol i have a 40 on mine and its way too small for my goals.
Old Nov 22, 2007 | 03:32 PM
  #2128
Frickr's Avatar
Default Re: (SwappedTURBOegg)
well just the size of the turbo assebly, i held it up just jokin around on my b16, and it took up alot of room. but im readin through this, long list of pages, so be patient. but the turbo i have, the wastegates stuck shut. thats why we took it off our dodge in the first place and got a bigger one on there. now i would have to remove my a/c on my car to make that turbo fit wouldnt i? and also, if i were to put it on, would that turbo be to big for stock internals?? i guess i havent read far enough into this yet, and getting anxious.
Old Nov 23, 2007 | 05:20 PM
  #2129
DLB1994's Avatar
Default Re: (DLB1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">is it true that the hx40 flows 70 lbs/min ?...,,, so has any one tried the hx55?</TD></TR></TABLE>
Old Nov 27, 2007 | 06:49 AM
  #2130
sonicivic's Avatar
ive got a gsr with built internals and a built head, now im lookn for a turbo,will a hx35 be good for me? im lookn to get 400-450 whp, any suggestions?
Old Nov 27, 2007 | 06:32 PM
  #2131
notfastenough's Avatar
Wellll, with the reading I've been doing, you should be well over 20 psi and to hit that 450 number, you will be fairly close to going out of the efficency range of the turbo.
Old Nov 27, 2007 | 09:45 PM
  #2132
blundar's Avatar
Default Re: (notfastenough)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notfastenough &raquo;</TD></TR><TR><TD CLASS="quote">Wellll, with the reading I've been doing, you should be well over 20 psi and to hit that 450 number, you will be fairly close to going out of the efficency range of the turbo. </TD></TR></TABLE>
My tuning experience would seem to differ. I've yet to max out a HX35 or HY35, but I wouldn't sweat 450whp at all.
Old Nov 27, 2007 | 10:27 PM
  #2133
Minor Threat's Avatar
Default Re: (blundar)
You done any single cams yet?
Old Nov 27, 2007 | 10:52 PM
  #2134
b20vtechb's Avatar
i'm with dave here. On my old setup before it dropped a valve, pistons/rods lsvtec stock head i made 428whp after only 3 pulls on the dyno this was all on 19psi when i pulled it in on the dyno it made 360whp on that same boost amazing what a little timing can do! my next setup is an holset HX52 with a 16cm exhaust housing should be fun on the new motor, look a couple pages back for a size comparison i posted between the hx 52 and 35
Old Nov 28, 2007 | 01:34 AM
  #2135
hey guys i bought a 72mm hx55 with 19mm housing for next year. im going to try and do 9s with it haha. was going to sell out and buy a s372.... but the way i look at it is i saved 1.5 K and can go "kinda" fast. WIN
Old Nov 28, 2007 | 06:00 AM
  #2136
blundar's Avatar
egg- pics?
Old Nov 28, 2007 | 01:16 PM
  #2137
ill have some when it comes in the mail.
Old Nov 28, 2007 | 02:52 PM
  #2138
OH NO EPIC FAIL. it was a 72mm exhaust and 65mm compressor... thats what i get for shopping drunk.
Old Nov 28, 2007 | 05:10 PM
  #2139
slowhitEJ1's Avatar
i have a connect through a friend at the dodge dealership, said he MAY be able to get me one for free, though i don't know how he'll sneak THIS out in his pocket..
i'm in need of an HX35, twin scroll .. i'd like to have the ported or "anti-surge" intake shroud, and a v band exhaust shroud.. anyone know specifically what years or even which motors these came off of??
Old Nov 28, 2007 | 07:45 PM
  #2140
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">
My tuning experience would seem to differ. I've yet to max out a HX35 or HY35, but I wouldn't sweat 450whp at all.</TD></TR></TABLE>
That's cool to hear. On a gsr, what kind of psi did it take to hit 425-475? I'm having to go by pretty much what I read until I get to buy more parts and install.
Old Nov 28, 2007 | 08:45 PM
  #2141
blundar's Avatar
figure 18-24 depending on other motor factors
Old Nov 28, 2007 | 09:18 PM
  #2142
Dave,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Minor Threat &raquo;</TD></TR><TR><TD CLASS="quote">You done any single cams yet?</TD></TR></TABLE>
I've yet to see SOHC Holset timeslips or dyno numbers anywhere.
Old Nov 28, 2007 | 10:22 PM
  #2143
blundar's Avatar
me neither. hy35 on a vitara motor would be a lil laggy but probably not the suck
Old Nov 29, 2007 | 02:18 AM
  #2144
Dr. D-Series's Avatar
Just to give you an idea a h1c made 202 whp at 11 psi on my non intercooled stock d15.
Its running in my eagle/vitara motor right now, still at 11 psi. Will up to 20 when tuned.
Old Nov 29, 2007 | 06:01 AM
  #2145
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">me neither. hy35 on a vitara motor would be a lil laggy but probably not the suck</TD></TR></TABLE>
It is a little laggy but you're right it doesn't suck. Winter has come here so the car is away, I never got a chance to get it on the dyno.
I was thinking of doing the bullseye housing on the HX35 but I'm not sure if it would actually be all that different from an HY35 in the end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series &raquo;</TD></TR><TR><TD CLASS="quote">Just to give you an idea a h1c made 202 whp at 11 psi on my non intercooled stock d15.
Its running in my eagle/vitara motor right now, still at 11 psi. Will up to 20 when tuned.</TD></TR></TABLE>
Does it feel slower now than it did with the old motor?
Old Nov 29, 2007 | 09:51 AM
  #2146
teamlegacy's Avatar
Default Re: (Minor Threat)
I've yet to see SOHC Holset tImeslips or dyno numbers anywhere.</TD></TR></TABLE>
I recently had my Holset HX35 powered F22A6 SOHC Accord tuned. Stock block, stock head port, custom E.L. manifold, 3" downpipe no exhaust, etc etc etc.
Made 402whp/325wtq, with a gnarly boost spike across the powerband up to 20psi. I got a bigger wastegate so then we'll be able to tune the powerband and control boost a little more efficiently.
Old Nov 29, 2007 | 10:06 AM
  #2147
slowhitEJ1's Avatar
Default Re: (slowhitEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowhitEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">i have a connect through a friend at the dodge dealership, said he MAY be able to get me one for free, though i don't know how he'll sneak THIS out in his pocket..
i'm in need of an HX35, twin scroll .. i'd like to have the ported or "anti-surge" intake shroud, and a v band exhaust shroud.. anyone know specifically what years or even which motors these came off of??</TD></TR></TABLE>
Old Nov 29, 2007 | 11:33 AM
  #2148
Feels about the same. Maybe a bit less responsive.
But it spools up quicker and just feels like there more torque in the midrange.
I just added a fmic to the setup today. Feels like **** in 1st gear now.
Old Dec 1, 2007 | 01:04 AM
  #2149
b20vtechb's Avatar
i've got one if your looking to buy one.. i'll let it go for 250 and its in excelent condition, and the years your looking for is like 95-2001 manual trans i think
Old Dec 8, 2007 | 07:03 PM
  #2150
oneslowstd's Avatar
Dave you never called me back brother. I know your busy but get back to me soon bro, I need to see how we are going to de this I will probally just trailer it there so let me know
