Holset users unite!
Old Jan 2, 2012 | 11:19 AM
  #3376
TheShodan's Avatar
Moderator
Default Re: Holset users unite!
Originally Posted by nealnanoHX
Interesting, like I said I was just curious on this. I have my turbo choice picked out, a GT3255B from you or a TO4 .57 .63 AR stg 3 with B cover for block clearance.
A lot of DSM owners really love these turbochargers and have made an entire sub-industry from them.
Old Jan 2, 2012 | 12:39 PM
  #3377
lsturbo33's Avatar
Shodan I'm assuming your talking about the 8 blade being similar a 50 trim in terms of flow. If so what about the 7 blade similar to?
Old Jan 2, 2012 | 12:43 PM
  #3378
TheShodan's Avatar
Moderator
8 & 7 blade had the same characteristics really. One was the HY35 the other was the HX35 series. It was really splitting hairs by that point.
Old Jan 2, 2012 | 02:01 PM
  #3379
lsturbo33's Avatar
Doesn't the 7 flow more then the 8 though?
Old Jan 2, 2012 | 02:12 PM
  #3380
TheShodan's Avatar
Moderator
Again, not really, in the overall performance of either compressor wheel. Depends upon the exducer used as there are several sized for both the 7 single bladed and the 8 single bladed. 1 or 2 lbs/min in my experience. Nothing really to write home about or get into a huge debate with..
Old Jan 2, 2012 | 02:25 PM
  #3381
lsturbo33's Avatar
Thanks. I am using a 8 blade hx35w on setup. We have a 7 blade billet wheel hx35 we are using on a test engine at work. When testing is done I could hopefully use it. It sounds like it might not be worth it...Now you see why I'm asking?
Old Jan 2, 2012 | 06:10 PM
  #3382
darkhorizon's Avatar
the 7blade is probably a 56mm while the 8 blade is a 52mm. Technically from the unoffical and unspecific graphs I have seen, you should get 8lb/m more flow potential out of the 7 blade.
I made way more power than I should have made on my HX35 7blade, I can say that for sure.
Old Jan 2, 2012 | 06:50 PM
  #3383
uscivicmc's Avatar
wheres the best place to buy an hx35? are you guys getting them from ebay and craigslist or what?
Old Jan 3, 2012 | 07:58 AM
  #3384
nealnanoHX's Avatar
I looked on Ebay and only found a few, most needed a rebuild.
Old Jan 3, 2012 | 01:50 PM
  #3385
hardcore97's Avatar
they are very easy to rebuild, if you need one rebuilt let me know, ive done a few of them
Old Jan 4, 2012 | 08:19 AM
  #3386
For the record, 99/100 of the turbos on ebay that "need a rebuild" are perfectly fine turbos, they are just sold by vendors under that pretense to avoid issues of waranty or whatnot. Most of them have no way to test them either.
Old Jan 11, 2012 | 10:19 AM
  #3387
Bseriescivic5's Avatar
Is there any reputable re-builders of holset turbos using genuine parts? Im interested in looking into this, versus buying another one and going back for a re-tune if the re-build price exceeds 4-500 bucks.
Old Jan 12, 2012 | 09:26 AM
  #3388
Boost4Breakfast's Avatar
H1c you can get for cheap. I picked up a "core" h1c (with a ridiculous 18cm housing) and ran it on a different build (not honda) and made 253whp @only 10psi on a 2.0L on 91. I was sitting right around 310-315 on e85 @ 13-14psi. My wife is putting an he351 on her d-series build and we're hoping for decent numbers
Old Jan 12, 2012 | 12:00 PM
  #3389
hardcore97's Avatar
there is an h1c for sale right now
http://hondamarketplace.com/showthread.php?t=3015814
Old Jan 12, 2012 | 03:02 PM
  #3390
efcivic317's Avatar
I have joined the club!!! HX35
http://www.flickr.com/photos/73969265@N05/6686985213/http://www.flickr.com/photos/73969265@N05/6686985213/ by http://www.flickr.com/people/73969265@N05/, on Flickr
http://www.flickr.com/photos/73969265@N05/6686993905/http://www.flickr.com/photos/73969265@N05/6686993905/ by http://www.flickr.com/people/73969265@N05/, on Flickr
Old Jan 13, 2012 | 08:57 AM
  #3391
lsturbo33's Avatar
Nice. What size turbine housing is on it?^^
Old Jan 13, 2012 | 09:01 AM
  #3392
efcivic317's Avatar
It's an 8 blade I'm not sure on the exact size
Old Jan 13, 2012 | 02:34 PM
  #3393
fmfkid250's Avatar
I have ran a bunch of those style turbos on b series and d series.
the D series had a ramhorn (he341) and 2.5" intercooler pipeing it made 20psi by 5000rpm and made close to 415whp. Simple build. Ran real good (low 11's) in a hatch
upgraded the IC pipe to 3" it made the turbo spool 300-550rpm later.
Old Jan 20, 2012 | 08:38 PM
  #3394
sosxbmx's Avatar
so i just noticed something that i completely over looked... i have 1.5in between my exhaust housing and my radiator. i have a gut feeling i need to relocate my radiator. ive seen quite a few people that have moved there's over a few inches and angled it against the passenger fender. is there any issues that go along with this relocation?
Old Jan 21, 2012 | 11:21 AM
  #3395
sosxbmx's Avatar
anybody? surely someone on this forum has had to relocate their radiator
Old Jan 21, 2012 | 11:22 AM
  #3396
uscivicmc's Avatar
can anyone find me a part number for the snap ring that holds the compressor housing on? and where i can get one please
Old Jan 21, 2012 | 04:49 PM
  #3397
uscivicmc's Avatar
someone help me identify this, it has no tag type deal on it...
one set of numbers on the compressor housing read ae0600, can't really make out the other ones and one set of number on the exhaust housing read 3592470
its not a twin scroll flange, but it is t3 flanged if that helps at all
Old Jan 21, 2012 | 06:32 PM
  #3398
kingofkrunk's Avatar
the 7 can flow 60lbs/min and the 8 can flow 52
the hy has a quick spool then both hx35's
both 7 and 8 have the same spool characteristics
Old Jan 21, 2012 | 06:35 PM
  #3399
if its not twin scroll its prolly an hy35, the 9cm housing version
IMO these are the best for d series because of their quicker spool
Old Jan 21, 2012 | 07:05 PM
  #3400
uscivicmc's Avatar
well i've got an ls/vtec.
but as far as the turbo is concerned, what adaptor do i need for the oil feed? can't seem to find an answer
