Holset users unite!
Old Feb 2, 2006 | 11:29 PM
  #826
powerofdreams8's Avatar
Default Re: (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">@ what boost?? or do you mean the max you can run on pump? What octane can you get at the pump in Tx?? We can only get shitty 91 here in Cali.
edit: pg 34 pwnage, ya'll can't see me!!! </TD></TR></TABLE>
Always Shell 93 octane for my car. Right, I mean max on pump gas.
Old Feb 2, 2006 | 11:56 PM
  #827
wantboost's Avatar
Who is Mr Robot?
Default Re: (powerofdreams8)
ive been slacking on uploading drums pics... one is too big and i need to resize it and i've had a really bad week..... kill me
Old Feb 3, 2006 | 04:48 AM
  #828
Jays91DXhatch's Avatar
Default Re: (wantboost)
I'll have pics up soon of my modified HY35W.
I blocked the internal wastegate, I am also removing the bracket that was holding the wastegate actuator to the compressor housing, "shaved" the lettering and am polishing the compressor housing, starting to look sweet.
It took 1 week of using liquid wrench everyday with a chissel and a mini-sledge before I could seperate the turbine housing from the center section..
Old Feb 3, 2006 | 05:27 AM
  #829
JCushing's Avatar
Default Re: (Jays91DXhatch)
umm, what method did you use to secure the WG flapper
Old Feb 3, 2006 | 05:42 AM
  #830
95cxh22a's Avatar
Default Re: (JCushing)
my friend that ran the 12.7 tapped his and put a pipe plug in it.
Old Feb 3, 2006 | 06:53 AM
  #831
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">ive been slacking on uploading drums pics... one is too big and i need to resize it and i've had a really bad week..... kill me</TD></TR></TABLE>
i know there huge! i love my moms camera...if you dont get them up soon i might work on tryin to get my server and main comp back up and running then ill hostm again...i love details...and big pictures show everything
Old Feb 3, 2006 | 07:14 AM
  #832
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">umm, what method did you use to secure the WG flapper</TD></TR></TABLE>
On pg 19 I put up some picts of how I did it. I ended up just tack weldin the wg shut from the inside because I had to orient the comp housing and the method I used was no longer applicable.
Old Feb 3, 2006 | 09:12 AM
  #833
drumking15's Avatar
Default Re: (95cxh22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95cxh22a &raquo;</TD></TR><TR><TD CLASS="quote">my friend that ran the 12.7 tapped his and put a pipe plug in it.</TD></TR></TABLE>
thats not a dam bad idea...good thinkin
Old Feb 3, 2006 | 12:03 PM
  #834
Root79's Avatar
Default Re: (drumking15)
Recive today brand new HX35s. Will post some pics...
Old Feb 6, 2006 | 09:57 AM
  #835
Default Re: (Root79)
Here's how I did it:
Before:
After welding
Old Feb 6, 2006 | 11:06 AM
  #836
Joseph Davis's Avatar
Heh.
In the trailerpark, we just wire the flapper shut.
Still, good work.
Old Feb 6, 2006 | 11:16 AM
  #837
lsintegra9's Avatar
heres my hy35, just got done rebuilding it so i thought i would take some pics.
Old Feb 6, 2006 | 12:31 PM
  #838
Si Shane's Avatar
Where is the powaz?
Old Feb 6, 2006 | 02:57 PM
  #839
crazy_eddy's Avatar
i have by now read all 34 pages, and know that many of are running holsets on your petrol driven cars...
i mentioned last page that i have heard only bad things about the exhaust temperature and that the diesel turbo wont be able to resist the much higher petrol exhaust temps...
now, please all u guys who are runnin holsets, can u let me know how long u have been running holset, maybe at what boost levels, and how long the turbo lasted/lasts...
thanks guys ... will be a good info for all of us...
Old Feb 7, 2006 | 12:29 AM
  #840
Root79's Avatar
Default Re: (crazy_eddy)
This turbo goes to Nissan 200sx on CA18DET engine and will top mounted.
Here it is - Holset HX35S:
Near is Garret 25
Old Feb 7, 2006 | 07:11 AM
  #841
highbooster's Avatar
Default Holset VGT
Hi guys. I had some pics of the newer variable geometry holsets but i didnt have any luck when i went to post em. I hope the admins dont mine me posting a link. http://WWW.VGTURBOS.50MEGS.COM Thanks
Old Feb 7, 2006 | 07:38 AM
  #842
Default Re: Holset VGT (highbooster)
Heh.
Looks like fitting a Holset VG into most Honduh chassis ain't gonna happen... that vane controller unit is pretty bulky.
I wonder how tiny they can shrink the hot side down, though? Also, how difficult it would be to control the VG unit. Probably simple microcontroller project, base it off RPM/MAP/TPS loads as a boost controller.
Old Feb 7, 2006 | 07:52 AM
  #843
Si Shane's Avatar
Default Re: Holset VGT (J. Davis)
I don't know how extensive your turbo background is but if you check out http://forums.clubsi.com/postl...=UBB4 one of the regulars has used a VNT garrett turbo on a sandrail. I'm sure you could make a post or whatnot if your interested.
Old Feb 7, 2006 | 10:50 PM
  #844
Default Re: Holset VGT (Si Shane)
That slidevane he351ve opens up to 25cm. There is an he431v that opens up to 29cm. Correct me if i am wrong but that's well over a 2.00 a/r. I belive it closes down to 9cm. I have looked on the exhaust housings and can only find the 25cm and 29cm respectively.
Old Feb 12, 2006 | 12:06 PM
  #845
Si Shane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerofdreams8 &raquo;</TD></TR><TR><TD CLASS="quote">I am dynoing my holset setup tomorrow w/ tony1. I have a forged internal stock bore/stroke b16, HX35 w/ bullseye turbine side and 3-4inch flared open DP, 880cc, and 2.5bar motorola.
Anyone care to guess how much boost/power I will be able to run/make on pump gas? </TD></TR></TABLE>
Old Feb 13, 2006 | 09:02 AM
  #846
Full-Race Geoff's Avatar
Default are there any high-ish boost dynos with good manifolds ?
i searched for like 10 pages and gave up... are there any "good" setups (good manifold, good IC, good DP, good external WG, etc etc) with dyno plots anywhere in this thread?
Old Feb 13, 2006 | 09:21 AM
  #847
Default Re: are there any high-ish boost dynos with good manifolds ? (Full-Race Geoff)
I have only seen two, was requested not to share them.
You might ask Speed Phreak to post up his, since it was his "old" setup. 340 whp @ 12 psi on a 2.0 LS. I only have a hardcopy *somewhere*, lost the jpeg at some point.
Unfortunately by your standards he didn't have a good manifold, etc., so it's probably not what you want to see.
Old Feb 13, 2006 | 01:30 PM
  #848
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">i searched for like 10 pages and gave up... are there any "good" setups (good manifold, good IC, good DP, good external WG, etc etc) with dyno plots anywhere in this thread?</TD></TR></TABLE>
I will be going to the dyno very soon, my project was on hold as I was out of town on business for ~6weeks and on vacation for 2 weeks. Bubba will be doing the tuning.
GSR
mild pnp
itr cams
victor x mani
rc1000cc injectors
crower valvetrain
crane stg II n/a cams
block line honed and balanced
eagle rods
srp pistons
holset hy35 turbo
neukin mani
tial 38mm wg, 50mm bov
4"-3" dp, 3" exhaust
aem ems
aem 3.5 bar map
Maybe this is good enough for you, as I'm sure you have very high standards. Yes I know this is a mild build, but I don't really need 500+ hp. I will be posting up a dyno soon. Dp is being fabbed right now, then just some misc stuff for me to put together, wiring (map, boost solenoid, injector clips), tires (f1 gs-d3's) to be put on, koni/nuespeed to be installed and it should be ready for the roller.
Old Feb 13, 2006 | 02:33 PM
  #849
Evile140's Avatar
I ran an hy35w on my 2.3ford powered rx7 for a couple years and on my mustang a year or so before that. Very reliable turbo's
Even with my bad flowing head the hy35 made 422hp 440tq on a dynojet
http://www.eville140.com/rx7.html
Plan on reusing it for the 5th year on my 3tc powered Toyota starlet
Later
Randy
Old Feb 13, 2006 | 03:10 PM
  #850
drumking15's Avatar
no....geoff come spring hopefully ill make you wish come true altho not many favor my setup being a/w intercooled...
but this is what i was tryin to setup the twin scroll setup for
