Holset users unite!
Old Jun 13, 2014 | 03:37 AM
  #3826
scottdh20's Avatar
Default Re: Holset users unite!
truth....
there are a few maps floating around for holsets, wantboost and the shodan probably know best but iirc they are approximate maps or guestimates...I don't even know if holset was the one who pumped them out
Old Jun 13, 2014 | 04:12 AM
  #3827
wantboost's Avatar
Who is Mr Robot?
Holset has maps, most are internal and confidential. Holset only publishes maps in a big book for authorised dealers, TheShodan should have one IIRC. I'll see if I can dig up a map somewhere.
Old Jun 13, 2014 | 04:39 AM
  #3828
scottdh20's Avatar
right I know they have maps...its about releasing them...
iirc there is one hx35 map out there...even though there are a couple/few different varients of the turbo. 7blade/8blade/ h1c etc
Old Jun 25, 2014 | 04:57 AM
  #3829
dcmatt's Avatar
Anyone know if there are fitment issues with a inlinepro t3 and holset h1c using the .63 housing from tims turbos. I think it should be ok but figured i check.
Nevermind picked up a miniram instead.
Old Aug 3, 2014 | 02:45 PM
  #3830
bradysyde's Avatar
What's max power of a large h1c? Made 416 on 24 lbs but I'm wondering if could push it further?
Old Aug 3, 2014 | 04:09 PM
  #3831
TheShodan's Avatar
Moderator
About 450whp for the H1C. that's about it.. And that's with optimal conditions.
Old Aug 3, 2014 | 04:22 PM
  #3832
bradysyde's Avatar
What other holset would work? I know the 35 is pretty much same turbo besides v band. Looking between 450-500. Hx35/40?
Old Aug 3, 2014 | 04:41 PM
  #3833
TheShodan's Avatar
Moderator
An HX35/40 is optimal, with the 8-blade compressor wheel with at least 10cm would work for the 450whp. That's if you must stay Holset.
The "B" is considered to be the HX35/40 in the HX40 class
For more towards 500whp-650whp, I'd just do HX40, if you must stay Holset.
Some comparisons of Garrett sizes against the Holset comparable sizes
Old Aug 3, 2014 | 05:51 PM
  #3834
hardcore97's Avatar
I'm on a 7 blade hx35 and I made 481 at 20 pounds of boost. That's with a 12cm housing
Old Aug 3, 2014 | 06:53 PM
  #3835
bradysyde's Avatar
What'd your setup with that? It could still push a couple more psi outta that couldn't you?
Old Aug 3, 2014 | 08:21 PM
  #3836
hardcore97's Avatar
Stock bore lsvtec, ported Gsr head and stock Gsr cams. Victorx intake manifold, top mount turbo manifold, those numbers were open down pipe. FIC 2150's running on e85
Old Aug 4, 2014 | 06:27 AM
  #3837
dcmatt's Avatar
My understanding was the 7 blade could get close to mid 500s
Old Aug 4, 2014 | 06:25 PM
  #3838
hardcore97's Avatar
I've heard that as well, I'm running 25lbs of boost now but haven't had it on the dyno. Should be a bit over 500 I'm guessing
Old Aug 5, 2014 | 10:00 AM
  #3839
dcmatt's Avatar
Im gonna be running an h1c/b16 myself. Just gotta get a housing for it. Try n find a garrett housing for cheap and have it machined or just order the ready to go one from tims turbo.
Old Aug 5, 2014 | 11:07 AM
  #3840
TheShodan's Avatar
Moderator
Get the one from Tim's... It takes a lot to machine those to fit. And they do those in bulk, so the cost becomes a bit more reasonable for those attempting to do this.
Old Aug 5, 2014 | 11:47 AM
  #3841
dcmatt's Avatar
More then likely thats the route. Turbo lab quoted me 100 to machine a garrett housing if i can find one. Havnt been able to find one cheap enough to justify not just ordering the tims turbo one. Either way all my car purchases are on hold till after my vacation in sept unfortunately.
Old Aug 5, 2014 | 02:24 PM
  #3842
TheShodan's Avatar
Moderator
And you won't. Those housings are good quality. But $100 is about right.
Old Aug 15, 2014 | 04:47 AM
  #3843
dcmatt's Avatar
Scooped a 12cm housing for $55 on ebay!!!!!
Old Aug 31, 2014 | 10:48 AM
  #3844
7passu's Avatar
I have my holset he351cw w/cast top mount and 3" down pipe and dump tube setup I'm trying to sell if anyone needs a ready to go setup
Old Aug 31, 2014 | 02:59 PM
  #3845
ZCHondaCRX91's Avatar
How much? What engine is the manifold for?
Old Sep 1, 2014 | 09:59 AM
  #3846
7passu's Avatar
U know a soon as I posted this, it sold a couple hours later. I had it for either engine. Had both the d series spa top mount and b series spa top mount. All I have left is the b series manifold cast top mount
Old Sep 6, 2014 | 12:47 PM
  #3847
dcmatt's Avatar
Ive got a holset h1c and 12cm housing for sale. Pm if interested.
Old Oct 1, 2014 | 08:45 AM
  #3848
hardcore97's Avatar
anyone interested in an H1E? 18cm housing, 8 blade compressor wheel 12 blade exhaust, essentially an older version of the hx40 from what ive seen.
Old Oct 21, 2014 | 04:18 PM
  #3849
blkbb6's Avatar
hey guys just got an hx35 for my h22, tying to make at least 420whp, i got the the turbo from some guy here my area and he said it was rebuilt and it sat for a while, turbo has no shaft play and looked real clean, my only concern is that doesnt spin freely all the way, here's a video below..
Old Oct 21, 2014 | 05:00 PM
  #3850
B and B's Avatar
Loved
Community Favorite
No, contact with housing isn't normal. Shaft bent maybe.
Not good. gonna have to have it checked out inside.
How much did u pay?
