Holset users unite!
Old Apr 25, 2014 | 07:08 AM
  #3776
ZCHondaCRX91's Avatar
Default Re: Holset users unite!
I had to use 2.5" 90 degree off the turbo flange, then angle it over to the driver's side a little until I could fit the 3" pipe. It's kind of a slight S shape, but after about 6" it merges to 3" pipe so it worked out good. If you don't want to redo the downpipe then moving the radiator is about all you can do.
Old Apr 25, 2014 | 08:17 AM
  #3777
kingkong_hatch's Avatar
Thanks for the info guys.
Old Apr 25, 2014 | 02:27 PM
  #3778
Icon7 Re: Holset users unite!
Old Apr 25, 2014 | 02:28 PM
  #3779
Old Apr 25, 2014 | 03:52 PM
  #3780
wantboost's Avatar
Who is Mr Robot?
my internet connection is being a *****, still trying to upload
Old Apr 25, 2014 | 04:14 PM
  #3781
^you're lucky to have that elbow on the outlet of the compressor side. Mine didn't come with one and never knew they existed until I saw one in this thread. It would of made things a lot easier.
Old Apr 25, 2014 | 05:04 PM
  #3782
Yea the elbow does make things easier. I bought the turbo without it and I went on a hunt searching for the elbow. I ended up finding it on eBay for $40.
Old Apr 30, 2014 | 06:28 PM
  #3783
wantboost's Avatar
Who is Mr Robot?
if you're good you can find them in pull a parts.
I'm on the email list for whenever a turbo diesel dodge shows up in a yard... mad dash to grab the turbo and other things lol
Old Apr 30, 2014 | 09:01 PM
  #3784
TravisBiggie's Avatar
http://www.ebay.com/itm/171309704698...84.m1497.l2649
picked this up today.. $350 shipped, whatcha think??? Also bought tim turbos t3 .63ar turbine housing.
Old Apr 30, 2014 | 09:40 PM
  #3785
93ls10.0's Avatar
What size engine u using it on?
Old May 1, 2014 | 02:57 AM
  #3786
lsvtec 81mm
Old May 1, 2014 | 05:03 AM
  #3787
92cxyd's Avatar
Should be fun on the LSvtec 1.8
Old May 1, 2014 | 11:24 AM
  #3788
scottdh20's Avatar
Old May 1, 2014 | 07:28 PM
  #3789
7passu's Avatar
He351cw here
Old May 2, 2014 | 09:18 AM
  #3790
92cxyd's Avatar
Nice looking setup there.
Old May 5, 2014 | 01:24 AM
  #3791
HX35 7 Blade .63 AR
Sleeved B18b1
10:1 Pistons
LS crank
eagle rods
Type R cams
Aebs intake manifold
Ramhorn manifold
3" turbo back
50/50 water methanol injection
1000ccs
Shooting for as much power as possible on pump gas with water meth. What do you yall think? Ive seen a stock gsr on 12psi push 360 to the wheels. Idk if I can compare our motors to dsm motors, but there is one out there pushing 485 to the wheels on 28 psi, which is awd which loses even more power than fwd. I am also reading ~25 psi is about the spot where water meth can get you safely, but I believe there are many variables here...
Old May 5, 2014 | 04:08 AM
  #3792
dcmatt's Avatar
Did you end up selling the unit you purchased from pure turbos?
Old May 5, 2014 | 03:36 PM
  #3793
Sure did. Sold it for $600
So I bought a brand new hx35 7 blade chra with compressor housing for $350, and tim turbos 4 bolt .63 ar for 200. Not a bad swap IMO.
Old May 7, 2014 | 02:57 PM
  #3794
sps2112's Avatar
Originally Posted by 7passu
He351cw here
What kind of numbers you running?
Old May 9, 2014 | 08:45 AM
  #3795
dcmatt's Avatar
Whered you pick that up at?
Old May 9, 2014 | 01:08 PM
  #3796
wantboost's Avatar
Who is Mr Robot?
ebay, guy didn't pack it right though and the turbine wheel is damaged beyond repair/use
Old May 23, 2014 | 03:24 AM
  #3797
dcmatt's Avatar
Anyone have a hx35/h1c 9 or 12 cm housing theyd like to part with?
Old May 23, 2014 | 01:05 PM
  #3798
wantboost's Avatar
Who is Mr Robot?
Be hard to find here.
they is a guy on eBay who machines Garrett T31 .63 and .82 housings for Holset turbines. affordable too
Old May 23, 2014 | 01:50 PM
  #3799
hardcore97's Avatar
i see them on craigslist every now and then, that or ebay would be best bet to find a housing. on a sidenote, i go back next to finish the tune on my hx35 lsvtec with vtec actual working. made 377 and 320 on 20 pounds of boost with no vtec and only revving out to 7k. curious to see how much i pick up!
Old May 23, 2014 | 11:53 PM
  #3800
dcmatt's Avatar
Ive got my eye on one on ebay.
wantboost ive heard of him before but cant find them.
