Holset users unite!
Who is Mr Robot?
Strange there aren't any listed.
the guy who does them is called Tims Turbos... he has a website as well.
here's a 12cm wastegate housing
http://m.ebay.com/itm/281311659566?nav=SEARCH
finally got some clean pulls in! i was pretty impressed with the numbers my hx35 put out. made 481 whp and 350 wtq consistently at 20 lbs of boost. at 23 pounds it made 481 whp and 388 wtq. boost controller wasnt wanting to work right so i gotta fix that issue but i was very surprised to see almost 500 whp at only 20 pounds of boost. will post a pic of the dyno sheet when i get home
Who is Mr Robot?
you'd have the lag of a 600hp+ Honda but make less than 300.
You need something like a straight t3 60 trim, a gt2806r, gt28r, or something similarly sized.
I have this old h1c sitting and was wondering if anyone has any info on it? Its a 8 blade with a non wastegated 18.5cm hot side. The Assy. Number is 3528741 but I haven't been able to find anything on it.
Who is Mr Robot?
Housings are a little hard to find at the moment, especially depending upon which turbine wheel you have.
if you are rebuilding the unit I would suggest going with a more aerodynamic wheel, maybe even a billet replacement. they can be found for under 200 dollars for Holsets
Who is Mr Robot?
http://www.ebay.com/itm/Holset-HX35-...-/161332519727
there's a Garrett T31 T3 turbine housing machined for the hx/h1c turbine wheel
Who is Mr Robot?
yea I just noticed that yesterday.
I still need to see if he could machine one of Garrett's new twin scroll housings for an hx40 turbine wheel
Well I took some measurments and the compressor wheel measures Inducer:50mm Exducer:80mm
Hopefully this helps figure out its potential a little more.
