Holset users unite!
Old Jun 30, 2012 | 01:05 PM
  #3551
JDM809's Avatar
Default Re: Holset users unite!
Looking to getting a obx topmount. Anyone know if itll work with a hx35w on a b-series eg?
Old Jun 30, 2012 | 03:28 PM
  #3552
bgdriver's Avatar
LOL, no. Holsets are heavy and obx manifolds suck. mucho cracky time.
Old Jun 30, 2012 | 04:40 PM
  #3553
wantboost's Avatar
Who is Mr Robot?
Originally Posted by See_5
Recently picked up a Holset h1c. Its in awesome condition. The exhaust housing is 16cm.Been through this whole thread and I have a few questions.
Im running a JDM GSR with GSR b17 cable trans rebuilt with synchros and mFactory lsd.
I dont mind a little lag if it helps with traction but im worried about spike. I just bought a PFab log.
My question is should i run the Holset 16cm^2 exhaust or look into a BEP .70 a/r. The car is usually used as a weekend warrior and occasional 1/4 track car. I am also considering all other variables such as piping length, innercooler size, etc..
Im still a newb when it comes to all this.
Any input is appreciated, Thanks.
To give you an idea... 10cm is about .73a/r
16cm will be so laggy you won't even enjoy driving it... And either a housing that large you don't have to worry about a spike, you'll barely hit full boost
Old Jun 30, 2012 | 06:44 PM
  #3554
See_5's Avatar
^thanks man.
I just picked up another H1c with a bullseye .70 a/r housing off of here. I kinda figured that gigantic housing was going to take forever to spool.
Old Jul 1, 2012 | 12:27 PM
  #3555
JDM809's Avatar
looking for a decent manifold to use on my set up. nothing crazy. looking to make like 400
Old Jul 12, 2012 | 10:12 PM
  #3556
supaslowdx's Avatar
My freshly tuned setup just for info
7 blade hx35 from a 24 valve with a Tim's turbo .63 hot side
Gsr
Manley h beams and Manley platinum 9:1 pistons
Precision 1000cc and auto phonics 300lph pump
cast manifold and Godspeed 38mm gate
3 inch full exhaust and skunk2 intake manifold
tuned on eCtune with boost by gear 👍
tuned by DKGoodrich on his mustang dyno in Frankfort KY
on gate pressure(5psi) it made 272whp
final pressure at 16.5 psi it made 354/254 and making over 250wtq from about 5000 all the way to redline.
fun on the street for sure
Old Jul 26, 2012 | 10:01 PM
  #3557
JDM809's Avatar
that would be over 400 on a dynojet. your runing this on a log manifold? im looking to put this together soon but with a topmount or ramhorn. looking to make like 450hp probably end up getting a RLD Fab manifold since ive dealt with him before...
Old Jul 29, 2012 | 07:18 PM
  #3558
K20david's Avatar
Just learning about holset turbos and man, im impressed. Looking to put a hy35 turbo on my semi built gsr...goin run my pfab manifold that seems to fit the turbo...any1 know where i can buy a hy35 turbo for a decent price?
Old Jul 30, 2012 | 03:56 PM
  #3559
supaslowdx's Avatar
yessir. with the assumed 13% higher reading of a dyno jet 24c it should be right at 400whp. 430ish on a dynapack setup
Old Jul 30, 2012 | 03:57 PM
  #3560
supaslowdx's Avatar
and yea just a cheap old log manifold lol. I will be switching to an equal length manifold this winter tho. it's just a work car lol
Old Jul 31, 2012 | 06:23 PM
  #3561
HTurbo845's Avatar
hey. i got this h1e holset brand new from a buddy. measured 56/76 compressor wheel and around 76mm exhaust. cant find another like it on the internet, just looking for more info, or experience from someone using it.
Old Jul 31, 2012 | 08:23 PM
  #3562
JDM809's Avatar
somewhat pissed. could not find some blox type b cams or itr cams to trade for my gsr with money on top or for sale period. so ill be assembling my motor tomorrow and running gsr cams for now with my hx35w 7-blade 12cm. hopefully i make my power goals of 450-525 on pump e85...
Old Aug 5, 2012 | 10:45 AM
  #3563
supaslowdx's Avatar
from what I've seen pro1s are the way to go man. try lookin for set of those
Old Aug 5, 2012 | 10:50 AM
  #3564
supaslowdx's Avatar
a friend of mine made 446 on gsr cams tho in a b16 lol so it's not out of reach
Old Aug 6, 2012 | 01:52 PM
  #3565
93ls10.0's Avatar
Anyone have a hx40 comp wheel housing and backing plate?
Old Aug 6, 2012 | 07:27 PM
  #3566
wantboost's Avatar
Who is Mr Robot?
Originally Posted by Schlitzjr
I run a D16 with an undivided ramhorn to an hx35 12cm housing to 3in full exhaust. 22psi at 5500 in third.
im talking about 22psi in first lol... thats what dsm guys are seeing with the vgt he351ve
Old Aug 6, 2012 | 11:57 PM
  #3567
SwappedTURBOegg's Avatar
new setup going for 9s
Old Aug 9, 2012 | 05:00 PM
  #3568
supaslowdx's Avatar
so I was fooling around with the boost by gear in ectune earlier. I can't get it to make anymore than about 12psi in second gear. makes pressure fine in 3rd and 4th of course.
9:1 gsr hx35 with a .63 hotside cast manifold
any ideas?
Old Aug 9, 2012 | 05:45 PM
  #3569
Natural Aspirations's Avatar
any ideas?
Post a screen capture of your EBC screen in eCtune or post your tune file on the eCtune forum.
Be sure your waste gate activation is below your waste gate spring pressure. EBC activation should be around 1 psi.
Old Aug 10, 2012 | 10:14 AM
  #3570
splatranger95's Avatar
Ive been running holsets for years on my Ranger, but I didnt know you could get a turbine housing as small as guys are running. I have a few extra hx's sitting around, so maybe I will throw one on the civic. I would be interested to know where an hx35 or an H1c hits full boost on these little motors.
Old Aug 13, 2012 | 09:45 AM
  #3571
ashb82's Avatar
i have found a hx40 parts
Compressor 62mm x 86mm 7 blade
Turbine Shaft/Wheel 76.00mm X 62.00mm 10 Blade
I am thinking of buying these and machining my hx35 housing to fit them. how would this setup work.
Old Aug 13, 2012 | 10:03 AM
  #3572
fmfkid250's Avatar
I have been tuning a bunch of d series lately! Most cheapo builds
D16 stock head HX40 471WHP@36psi
D16 Build Head HE341 491WHP@32psi
D16 stock head HE341 411WHP@28PSI
Old Aug 13, 2012 | 10:38 AM
  #3573
ashb82's Avatar
stock sleeves also?
Old Aug 13, 2012 | 10:46 AM
  #3574
fmfkid250's Avatar
Originally Posted by ashb82
stock sleeves also?
All of them!
on Vitiras or whatever!
Old Aug 22, 2012 | 04:07 PM
  #3575
just made 751 with my hx52 LSvtec
https://honda-tech.com/forums/drag-racing-36/751whp-stock-sleeve-hoodrat-setup-block-full-concrete-wtf-3081373/
