Holset users unite!
Old Feb 7, 2012 | 05:58 AM
  #3451
Bseriescivic5's Avatar
Default Re: Holset users unite!
Yeah, also hes using crappy wastegate too.... with the kind of Lb/min these turbos are capable of I certiantly wouldnt crap out on the wastegate. You can get a really nice mini-ram for around 380-425 bucks these days... which is only like another 150 more than a log.
Old Feb 7, 2012 | 06:13 AM
  #3452
darkhorizon's Avatar
Does anyone actually have solid proof that the ram setups are going to be "omg way better" than logs? I can not find anything related to fluid dynamics, etc, that would suggest that the ram would be worlds better. I could understand that a ram could produce a bit more gains in the extreme areas, aka high rpm or off boost areas, but as far as overall gains I have yet to see anything significant.
Old Feb 7, 2012 | 07:38 AM
  #3453
sosxbmx's Avatar
drag log manifold - 50$ no clearance issues with downpipe or turbo , custom mini-ram horn 400-600$ no clearance issues either, but thats 350$ that goes into something else, budget has nothing to do with being smart with your money, are you gonna talk **** because i didnt buy it new?
Old Feb 7, 2012 | 07:41 AM
  #3454
mar778c's Avatar
Community Builder
Community Influencer
Originally Posted by Garage 808 Hatch
I see all these builds using a log mani with a Holset. I understand the whole budget concept, but a decent mini-ram will make such a huge difference, the additional cost is a no brainer. just my .02
Exactly, I made 425 whp @14 psi with a basement build mini-ram horn on a H1C. The compressor was the limit.
http://youtu.be/JhyOvtnmjqU
Old Feb 8, 2012 | 05:50 AM
  #3455
No one said you couldnt get it done with a log, but there is definately some significant gains.... If I cant dig up some dynos, Ill show you. I made more power on less boost with a smaller motor by switching to a ramhorn, and really not changing anything else other than injectors, management, and tuner. (obviously this counts for something but you get the idea)
Old Feb 8, 2012 | 06:43 AM
  #3456
fmfkid250's Avatar
Originally Posted by ScottyMF1
I am putting together a turbo build on my GSR and I am just looking for what you guys think...I daily drive it so I do not want to push it too hard, also it has a stock bottom end.
Current mods:
Brian Crower stage 2 all motor cams
Supertech Dual wound springs and retainers
port and polished head
EPROM ecu tuned by Phearable.net
ACL main and rod bearings
ARP headstuds
MSD Blaster Coil
Blox intake manifold
Exedy OEM clutch
Jasper S80 open diff racing trans
DC sport header
all new gaskets by felpro & Honda
Walboro 255 fuel pump
Turbo build:
log style cast mani
off-brand wg and bov
intercooler...unsure of size, but medium size i would say
AEM wideband
Hx35 7-blade
I am looking to push around 8psi, do you think that would be safe/worth it on this turbo...
Also, what size injectors would you guys suggest, I do not want to push it over 300hp and would rather stick to maybe 250-300hp...550cc-750cc?
Thanks everyone
anything bigger then 450's will be fine for 300whp
Old Feb 8, 2012 | 01:35 PM
  #3457
98hx35teg's Avatar
My build is similar, I plan to use a log but simply for the money aspect...and since I am not trying to.make ridiulous power, it is not a big deal
Old Feb 8, 2012 | 02:06 PM
  #3458
Garage 808 Hatch's Avatar
We did a log mani car, made 350 whp. switched it out to a mini ram, same power on 6 less lbs of boost.
Old Feb 9, 2012 | 03:38 AM
  #3459
How similar where the power curves? Any other changes during?
Old Feb 10, 2012 | 03:16 AM
  #3460
ashb82's Avatar
i am starting to working on a 6262 holset i have no idea how well it will do. i am using
hx35 housings, hx40 turbine wheel and hx50 compressor wheel.
Old Feb 13, 2012 | 06:13 PM
  #3461
98hx35teg's Avatar
Any one know of a website or anywhere else that sells downpipes for hx35s?
Old Feb 14, 2012 | 08:44 AM
  #3462
13173's Avatar
I am interested in seeing what happens with this.
Old Feb 16, 2012 | 04:07 PM
  #3463
crazyassbill's Avatar
From: parkersburg,wv / belpre,ohio, wv or oh, united states
welp i finally blew my he351cw. just got a 7 blade hx35 with bullseye 70 a/r hotside to replace it. trying to figure out what manifold to run on a lsvtec. i have a blox cast manifold now. trying to decide between mini ram, ramhorn and top mount. im gonna try my best to make 500whp.
gonna spray water meth and see what i can make
Old Feb 22, 2012 | 09:20 AM
  #3464
98hx35teg's Avatar
is everyone using a BEP .70 a/r or is anyone using a fully stock hx35 hotside? if so is the stock hotside fine, or will it be necessary to get the bep to get it to spool quicker?
Old Feb 23, 2012 | 03:54 PM
  #3465
E_F_9's Avatar
I have a 18.5cm H1C..The compressor housing has a small inlet compared to any others i have seen.. Are the compressor housings interchangable such as an H1C with the MWE housings?
Old Feb 24, 2012 | 05:11 AM
  #3466
scottdh20's Avatar
im running a stock hx35 with the factory 12cm hotside...does just fine
Old Feb 24, 2012 | 06:53 AM
  #3467
uscivicmc's Avatar
got my hy35 in..
before i painted the housings...
Old Feb 24, 2012 | 08:41 AM
  #3468
98hx35teg's Avatar
Why thank you! Nice to know before I go blow $200+
Old Feb 24, 2012 | 09:03 AM
  #3469
E_F_9's Avatar
So does anyone know if I can swap compressor housings from another h1c as long as it has the same size wheel?
Old Feb 25, 2012 | 04:49 PM
  #3470
hardcore97's Avatar
heres the manifold i just had a friend do for me along with the DP. he does amazing work. anyway, heres some pics
Old Mar 5, 2012 | 11:06 AM
  #3471
93gsr4dr's Avatar
I am building my b18c1 with a holset and with these i understand i need to run a reducer so i don't blow the oil seals. Can anyone point me in the direction where to get one?
Old Mar 5, 2012 | 12:16 PM
  #3472
uscivicmc's Avatar
You don't need one. They don't use them on the trucks and diesel trucks oil pressure is far far beyond what our little hondas think they can do
Old Mar 8, 2012 | 01:21 PM
  #3473
rainmanef's Avatar
does anyone know if you can swap the hy35w turbine housing for another housing?
Old Mar 8, 2012 | 03:14 PM
  #3474
nugmtg757's Avatar
i got his for 150 shipped. let me know what you think. i need manifold help. its going in a 93 teg. has a b18a1 for now but when the turbo goes i it will be mounted to a b16or gsr head.
Old Mar 8, 2012 | 07:52 PM
  #3475
hardcore97's Avatar
what are you guys doing with the hole in the compressor where the old line ran from the internal wastegate? looks like an 1/8 npt? wonder if i should just plug it or put a nipple on it and run a line to my external WG?
