Holset users unite!
Old Mar 9, 2012 | 12:34 AM
  #3476
vyrus's Avatar
Default Re: Holset users unite!
How good would the HX35 be on a stock b16 8 psi ? Lookin to get it since i won't need to upgrade turbo later on when i'm buildin the block.
Old Mar 9, 2012 | 07:59 AM
  #3477
MrBui's Avatar
anybody got one a hx35 for sale?
Old Mar 9, 2012 | 09:41 AM
  #3478
HRsi-dan's Avatar
hardcore97, your setup is beautiful. Wow!
Old Mar 9, 2012 | 09:42 AM
  #3479
HRsi-dan's Avatar
I do have a question. How have these performed on Honda engines when running low boost? I know that wouldn't be using the potential of the turbo, but for a daily driven street setup, is that possible?
I saw an H1C for sale locally and am wondering how it would perform at about 7-8 psi on a d series engine.
Old Mar 12, 2012 | 01:33 PM
  #3480
deeweezy187's Avatar
is it true that with these turbos you can block one side of the housing to help with spooling. i want to use my h1c on a stock block b18b will the work. only want 250whp on 10psi.
Old Mar 13, 2012 | 06:25 AM
  #3481
darkhorizon's Avatar
Why get a 500whp turbo to make 250?
Might as well swap an LS v8 in and run on 4cyl's.
Old Mar 13, 2012 | 04:12 PM
  #3482
ive seen this turbo on a stock b18b and d16 that wasnt even close 500. I was asking a question about helping spooling not horsepower. So if you aint helping me don't say nothing at all.
Old Mar 14, 2012 | 11:53 AM
  #3483
sosxbmx's Avatar
so anyone on here tackled rebuilding their hx35/40 hybrid ? my seals are ****ed and im debating tackling it myself or taking it to a shop
Old Mar 14, 2012 | 03:36 PM
  #3484
hardcore97's Avatar
i rebuilt my 35. it was easy. heres a link of a DIY i found on a cummins forum in case you want to try and do it yourself.
http://www.cumminsforum.com/forum/98...your-hx35.html
Old Mar 15, 2012 | 06:22 AM
  #3485
generally speaking the smaller the turbo, the faster the spool... a 250hp turbo is generally going to spool about twice as good as a 500hp turbo.
Old Mar 15, 2012 | 07:24 AM
  #3486
sosxbmx's Avatar
thanks hardcore what were the torque specs on the compressor wheel nut?
Old Mar 15, 2012 | 12:01 PM
  #3487
sosxbmx's Avatar
so before i tear my hx35/40 down i wanna see if anyone else has had similar problems or if my turbo might just be completely toast, im feeding it with a 1/4 oil feed line and am running a 1.5mm restrictor am i not restricted enough? car runs an average of 80psi motor is a stock b16a2 . but oil is just pouring out of my turbo exhaust and compressor sides. im assuming my seals are toast, but when i look up the rebuild kits i only see 1 o-ring in them, before anyone asks yes this will be the first time i tear apart a turbo to rebuild it, if there's only 1 o-ring and im concerned over nothing thats fine id rather ask a dim question then end up not fixing my oil leak
Old Mar 15, 2012 | 12:37 PM
  #3488
Khnemu's Avatar
:O
Old Mar 15, 2012 | 01:48 PM
  #3489
rainmanef's Avatar
HY35 for sale.....
Old Mar 20, 2012 | 01:39 PM
  #3490
B and B's Avatar
Loved
Community Favorite
I'm running H1C on light Tial spring 7.5~8? works fine...spools by 4,000..makes 285 hp, 199 tq....LSvtec tho.
Tired of hearing all that boost spraying out of the dump tube tho...retune soon I hope.
Old Mar 20, 2012 | 02:15 PM
  #3491
you guys think ill be able to run the h1c with cams. ill be able to use the extra powerband. stock b18b
Old Mar 21, 2012 | 06:24 AM
  #3492
I run a -4an feed at 75psi of oil pressure on my hx35. Never smoked an ounce of oil in years and years now.
Check the drain setup on your turbo.. I ran a -10 drain with a steep drop to the pan.
Old Mar 21, 2012 | 06:56 AM
  #3493
HRsi-dan's Avatar
Thanks sir for that post . That gives me some ideas just debating still if I should get it since I wouldn't be doing anything for a few years.
Old Mar 21, 2012 | 06:25 PM
  #3494
B and B's Avatar
Loved
Community Favorite
Just debating still if I should get it since I wouldn't be doing anything for a few years.
I got mine on Ebay NIB from a guy in Sebring FL. for $150 before they were very well known and looked at it for years waiting for the day I could run it.
Get it. They're not making any more simple units like these.
Old Mar 22, 2012 | 05:11 AM
  #3495
dc5214's Avatar
i just finished my rsx on a hx35 getting it tuned friday buy debating because white smoke comes out the down pipe everytime i rev it a little any help on what it is BTW im new to all this
thnx
Old Mar 22, 2012 | 10:45 AM
  #3496
DARob28's Avatar
Im in the process of building my street/race car. The motor is being built but Laskey Racing and sleeved by Bensen racing. I am going to be running my
HX35 with a BWR ramhorn for my street set up somewhere around 20psi hoping to get as close as possible to 500hp on pump gas!
When I switch to race gas ill be beefing up the fuel system and changing the turbo for a precision 67trim or maybe just the 6262 and looking for 700 on race gas.
I know i can hopfully get close to 500 with the Holset but I think 700 on race gas is out of the question with the Holset.
What does anyone think about what Im doing? I like what people say no matter if it negative or positive! helps me figure out what i might need to do!
Old Mar 23, 2012 | 05:09 AM
  #3497
fmfkid250's Avatar
500 on pump is alot to ask for. ESP on that turbo. It might happin on dynopak numbers but your poor tuner is going to be thinking something different when your looking for 500whp on pump with a 55trim(ish) turbo.
I think that turbo will semi-safely do 400 on pump. but anything after that your really just asking for it. I think that turbo will run outta steam around 460(dynojet)
I bet it will do around 400whp at 20psi...
I have used alot of these holsets. Some on good builds some on bad builds!
Old Mar 23, 2012 | 07:06 AM
  #3498
loch's Avatar
thnx
make sure your oil return is unrestrictive. these holsets hate that. i had a kink in my return which caused it to smoke.
Old Mar 23, 2012 | 08:00 AM
  #3499
hardcore97's Avatar
ive seen 400 at around 1 bar on more than dyno sheet
Old Mar 24, 2012 | 04:24 AM
  #3500
fmfkid250's Avatar
I have no clue what your trying to say here?
