Holset users unite!
well, i guess nobody cares how fast you can go with a holset
i do have a question.
i have an h1c/h1e/hx35 sitting here. it has a 56mm wheel( i think) a 4in inlet. 2in outlet. i have both a 12cm housing(internal gate) and a 18cm housing (ext gate) (started life as a h1c on a piece of equipment, it had a 3in inlet then, i bought the bigger wheel, the 56mm, it origianally had a 54mm wheel, i also bought the housing to go with the 56mm wheel)
would this be good on a 5.0 small block ford(fox mustang) looking for about 450ish?(blocks start to split around 500-520)
my friend with a fox mustang says it will be to small. what do you guys think?
should i just try to find a hx40, or a hx55? i already have this hx35morph sitting here.
i can provide pics of all of this tomorrow, when i get home from work, if needed.
.i do have a question.
Ironically, I have been looking for and researching Holset turbos for about 3 years, and because of this pro-Holset thread I actually ended up purchasing a Garrett. LOL. Not because Holsets are bad, they're great turbos, Holset just doesn't make a VGT turbo you can fit in a Honda...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Jones »</TD></TR><TR><TD CLASS="quote">Ironically, I have been looking for and researching Holset turbos for about 3 years, and because of this pro-Holset thread I actually ended up purchasing a Garrett. LOL. Not because Holsets are bad, they're great turbos, Holset just doesn't make a VGT turbo you can fit in a Honda...
not yet...i have a "gut" feeling that holset will be outputing some nice equipment w/in the next yr or two that will be on a smaller scale...but normally holsets in general are massive...which is awesome when your going for the" my snail is bigger contest"...
i swear 95% of the people think my car is 10x faster because the hx35 is a giant compared to most setups around here running smaller t3/t4 setups
</TD></TR></TABLE>not yet...i have a "gut" feeling that holset will be outputing some nice equipment w/in the next yr or two that will be on a smaller scale...but normally holsets in general are massive...which is awesome when your going for the" my snail is bigger contest"...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Jones »</TD></TR><TR><TD CLASS="quote">with an 88mm compressor and a VGT hotside, i'll be doing pretty good in 'my snail is bigger than yours' contests lol</TD></TR></TABLE>
you should see this HX40W
its like the say...its not how big your snail is....is how you use it
but hot dam...88mm good god thats massive!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 »</TD></TR><TR><TD CLASS="quote">its like the say...its not how big your snail is....is how you use it
but hot dam...88mm good god thats massive!</TD></TR></TABLE>
Yeah its pretty much the same size of an HX50 when it comes to the compressor inducer/exducer...
I can't wait to bolt this badboy on. V band turbine INLET and OUTLET
I can't wait to bolt this badboy on. V band turbine INLET and OUTLET</TD></TR></TABLE>
i def demand pics once its up...had a t3/t4 in my hands today...dam the thing was tiny...
I can't wait to bolt this badboy on. V band turbine INLET and OUTLET</TD></TR></TABLE>i def demand pics once its up...had a t3/t4 in my hands today...dam the thing was tiny...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 »</TD></TR><TR><TD CLASS="quote">Any pics HX35 and HX40 together? Maybe somebody have?</TD></TR></TABLE>
i doubt it...its not much bigger...mostly increase in about 11cfm is due to the bigger inducer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98h22 »</TD></TR><TR><TD CLASS="quote">would a hx35 or hx40 be better for a light built h22?</TD></TR></TABLE>
id go w/ a hx35 turbine w/ maybe a 14 or 16cm housing depending on you desired powerband w/ a hx40 compressor...
once i have some solid #'s on my setup i might be able to convience my friend to run a holset snail on his f22/h22 hybrid...
but i cant even imagine the spool times of a hx35 w/ a standras 12cm housing...i mean on my 1.9ish i already see 42-4300 full boost of 15psi w/ 3" open dp...w/ a h22 id say somewhere in the 3500ish range...would have a nice fat powerband w/ tons to useable power!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 »</TD></TR><TR><TD CLASS="quote">i def demand pics once its up...had a t3/t4 in my hands today...dam the thing was tiny...</TD></TR></TABLE>
here's a pic of pretty much the same thing I'm gonna be running...
hope the link works...
http://vgturbos.50megs.com/images/picture_077.jpg
For those of you that used a ground down 3" v-band band for the 2.75" HX35 turbine outlet, what flange did you use (link, name whatever)? I have given up on buying one from a holset dealer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">For those of you that used a ground down 3" v-band band for the 2.75" HX35 turbine outlet, what flange did you use (link, name whatever)? I have given up on buying one from a holset dealer. </TD></TR></TABLE>
i got mine from turbo-systems performance i believe....its just the generic 3" vband 5 star manufacturing makes...i think stan at fast-turbo.com can get them...
man been building all these other peoples cars...i cant wait to get my hx35 back in and up to see you...very soon
hmm, anyway to know 100% what one you used? I already tried 2 other brands I had laying around. If stan has em, ill buy them
Ya, Im not even close to getting mine going...no manifold, no clutch, no charge pipes....see you soon!
</TD></TR></TABLE>hmm, anyway to know 100% what one you used? I already tried 2 other brands I had laying around. If stan has em, ill buy them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95cxh22a »</TD></TR><TR><TD CLASS="quote">well my buddy ran a 12.52 @ 116. yesterday at hub city dragway in hattiesburg ms with his holset and an ls in a 94 hatch. some of you may remember this car from several pages back. that was on 205/60/15 street tires. run one was a 04 mach 1. run two was a very arrogant srt4 owner.
how much boost was this on? with which holset? and no...nobody in this thread cares about how fast holset powered cars go haha...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98h22 »</TD></TR><TR><TD CLASS="quote">is a hx35 turbine housing a t3 or t4?</TD></TR></TABLE>
they are all off the t3 footprint...but some are divided t3 flanges
Well, I decided I wanted something a touch bigger than the hx30w, and I found this gem on ebay from a great seller.H1C, 315 shipped brand new in the box w/ gaskets and oil fitting included! The compressor housing is a bit small, and I would have expected the wheel to be a bit bigger for an h1c, but nonetheless it should work nicely.
Inducer/exducer on this one is around ~1.77"/~2.83", 2.5" inlet, 2.5" vband...
Turbo in comparison is a t3/t04e 57 trim w/ a stage 3 wheel and .63ar
Modified by ChainbreakR at 2:46 PM 4/5/2006
