Holset users unite!
Old Jan 21, 2012 | 07:09 PM
  #3401
kingofkrunk's Avatar
Default Re: Holset users unite!
Originally Posted by uscivicmc
well i've got an ls/vtec.
but as far as the turbo is concerned, what adaptor do i need for the oil feed? can't seem to find an answer
i know that a lot of the people in the saab and dsm world like these turboes because of their quicker spool ... should work really well on an ls-vtec
not sure what size the oil line is to be honest
Old Jan 21, 2012 | 07:13 PM
  #3402
uscivicmc's Avatar
hmmm i'll keep searching
Old Jan 21, 2012 | 11:48 PM
  #3403
Glock17's Avatar
The oil feed normally is 12mm x 1.5 for Holset. I've use a 12mm x 1.5 to -4an fitting to my oil filter housing. Measure the oil pressure going to the turbo and used -10 or -12an return line.
Here the spec for the oil pressure for the turbo
8. Normal oil temperature is 95+/-5°C (203+/-9° F). It should not exceed 120°C (248°F) under any operating condition.
9. Any pre-lube oil must be clean and meet the minimum CD classification.
10. The orientation of turbine housing, bearing housing and compressor cover is fixed according to application. During installation, do not attempt to rotate these components. Inclined turbocharger installation is not recommended. If an installed angle is necessary, oil inlet centreline must be +/- 10 degrees from vertical and rotor centreline +/- 5 degrees from horizontal.
11. Holset permits oil return pipes to decline at an overall angle of not less than 30 degrees below horizontal.All turbocharger applications require a pipe of internal diameter greater than 19 mm which has integrated connectors. To ensure oil returns into the engine under all operating conditions, the return connection into the engine sump must not be submerged and the outlet flange of the turbocharger must be 50 mm above the maximum oil level of the engine sump pan. Crankcase pressure should be limited ideally to 0.8 kPa (0.12 lbf/in2) but 1.4 kPa (0.20 lbf/in2) can be accepted by reference to Holset.
12. Oil pressure of 150 kPa (20 lbf/in2) must show at the oil inlet within 3 - 4 seconds of engine firing to prevent damage to turbocharger bearing system. A flexible supply pipe is recommended.
13. The minimum oil pressure when the engine is on load must be 210 kPa (30 lbf/in2). Maximum permissible operating pressure is 500 kPa (72 lbf/in2) although 600 kPa (88 lbf/in2) is permitted during cold start up. Under idling conditions pressure should not fall below 70 kPa (10 lbf/in2).
14. Recommended oil flows for the turbochargers are 2 litre/min at idle and 3 litre/min above maximum torque speed.
Old Jan 22, 2012 | 06:44 AM
  #3404
uscivicmc's Avatar
well according to that, i'll need a restrictor, max psi for it is 72
Old Jan 22, 2012 | 03:51 PM
  #3405
deeweezy187's Avatar
Whats the smalllest size housing you can put on a h1c?
Old Jan 22, 2012 | 03:55 PM
  #3406
i head 12
Old Jan 22, 2012 | 06:14 PM
  #3407
Glock17's Avatar
Your going to have to measure oil pressure then get the right size restrictor. Every engine is different and doesn't have the same pressure. I'm running a .078 restrictor.
Old Jan 22, 2012 | 06:23 PM
  #3408
Glock17's Avatar
You can get a Bullseye T3 .70 A/R housing for 200.00. I was running the .55 A/R from Bullseye.
Old Jan 22, 2012 | 06:34 PM
  #3409
Whiterice-gsr's Avatar
the restrictor is a must i use .08 if u dont say goodbye to your seals, ive seen so many ppl overlook this and wonder why their turbos are burning oil and smokin really bad with very few miles on them.
Old Jan 22, 2012 | 07:11 PM
  #3410
scottdh20's Avatar
Hmmmm I'm running no restrictor.....only the stock brass fitting with appropriate fittings to get it down to a -3an feed line
Been like this for a whole season with no issues
Old Jan 22, 2012 | 07:20 PM
  #3411
sometimes if u buy a turbo and the company knows its for a honda they throw one in for u right at the turbo if u pull you oil feed line off the turbo u can see it u can unscrew it with a philips screwdriver to take it out. i dont know oof any seals that will handle 70 or 80 psi without failing soon
Old Jan 23, 2012 | 12:57 AM
  #3412
spawn_616's Avatar
hi, i sort of know which turbo i want but i know there are many diff versions of the 40,so can anyone help me with the closest version of the hx40 that i can purchase,
im looking for NOT more than 500whp(this is on high boost so if it makes more i can live with it)
k24a4
rev limit stock(7400ish)
eagle rods
10cr wisecos
1000id
kpro
i would prefer to make as close to 400whp daily,i am buying the turbo new,so if u can list it in specs then i can order correctly,anything else i need to mention let me no,
Old Jan 23, 2012 | 06:32 AM
  #3413
darkhorizon's Avatar
I ran 75psi out of my 3800 into my HX35 using a -4 braided line... no restrictor, no problems after 20k miles.
Old Jan 23, 2012 | 11:30 AM
  #3414
4dvti's Avatar
k24a4
eagle rods
10cr wisecos
1000id
kpro
similar to my future setup. hx super 40, stock k24a3, ARPs, k20 head, 8000rpm redline, k20 oil pump, 99 octane fuel. It will be an awesome setup and I'm hoping for 550bhp max or 300-350 daily on low boost.
Old Jan 23, 2012 | 12:57 PM
  #3415
SwappedTURBOegg's Avatar
back at it with an hx52
setup is fs i have a friend with a forward facing mani i want...
Old Jan 23, 2012 | 01:01 PM
  #3416
I know very little about holset turbos, maybe they are designed to work that high pressure but i know a garrett won't put up with that for long.
Old Jan 23, 2012 | 01:17 PM
  #3417
hardcore97's Avatar
have any numbers on that setup yet? very curious because my next step is going to be an hx52
Old Jan 23, 2012 | 01:38 PM
  #3418
ive had a few hx52 setups should make 600-650 at 28 psi or so
on both my b series and k20 spool is about 5500
Old Jan 23, 2012 | 05:46 PM
  #3419
jarh79's Avatar
Originally Posted by kingofkrunk
if its not twin scroll its prolly an hy35, the 9cm housing version
IMO these are the best for d series because of their quicker spool
looks just like my hy35 bro.
Old Jan 24, 2012 | 04:19 AM
  #3420
I think I decided on doing a HE351 VGT setup on my D16a6 Vitara. The turbo will at least let me make 500whp... IDK if E85 will be enough to keep the motor together.
Old Jan 24, 2012 | 06:25 AM
  #3421
rainmanef's Avatar
Help me out guys. I have the hy35 with the vband back housing. I want to use it, but the problem I'm running into is how to make the downpipe. Has anyone kept their ac and use this turbo. Or at have a pic of the downpipe they used.
Old Jan 24, 2012 | 07:35 AM
  #3422
uscivicmc's Avatar
It all depends on what manifold you're using
Old Jan 24, 2012 | 07:48 AM
  #3423
rainmanef's Avatar
drag cast iron style
Old Jan 24, 2012 | 01:11 PM
  #3424
hardcore97's Avatar
i would think it would make more power than that, makes me question whether or not to run one next
Old Jan 25, 2012 | 01:04 AM
  #3425
sosxbmx's Avatar
yeah i have a drag log and have a hx35/40 id have to relocate the condensor to have ac or you have to alter the mounting flange but then youd run into block clearance issues , on a different subject does anyones holset spool at idle cuz my compressor doesnt even move
