Holset users unite!
Setup is on my grudge car. Never see the street. And because of this magical thingy called anti lag our shop has managed a 7.66 1/4. That's a 331ci motor spinning a 106mm precision turbo. Jus cuz ur scared doesn't mean the next guy isn't ready to play big.
I put engine pics a couple posts back. I'm not expecting anything really prob about 10psi on anti lag. Deff. Boost by gear. It's gonna b a pain to dial in the spool time with gear ratio. Should make my power goal at ~25psi
No, the outlet on compressor housing for the intercooler hot side piping. It was originally a v-band, but I don't really want to do that. Just wondering what size coupler you used and if there was any wear because of the lip on the housing.
thought i would add some FYI to those of you using HX35 with 12cm non gated housings
oil feed adapter is a 12mm x 1.50 threading, i got a mine here. ill be drilling out the restrictor hole slightly larger, holsets like oil
http://www.ebay.com/itm/150985176314...84.m1439.l2649
normal t3/t4 drain works i did a cheap ebay one aswell
http://www.ebay.com/itm/T3-T4-T04E-T...2f63eb&vxp=mtr
12cm has vband housing out, you can get this vband for a downpipe
http://www.siliconeintakes.com/produ...e5aa923a560168
anyone can give me info on this turbo the bearing housing is marked for a h2d (3525199)
and the exhaust housing for a h2c (3522952) its a t4 divided housing
Who is Mr Robot?
I have a HX35W 7-blade (from 2002 cummins if it matters) and I need to find a feed adapter. From what I read the threads are 12mmx1.5, but I can't find one from that to -3an. All I could find was to -4an, I don't really wanna have another fitting from -4 to -3an so is there a 12mmx1.5 to -3an. Is there even a fitting available?
Who is Mr Robot?
https://www.pegasusautoracing.com/pr...asp?RecID=5054
You also forget that the holsets have the flare in the bottom of the hole
Here's a straight adapter
http://www.prospeed.bg/en/product/5717/57
Your welcome..
Your welcome..
So do I want a flared fitting end going into the turbo or just a straight fitting? Thanks for the links by the way.
mine is only flared for the AN, but i did use a rubber o ring on the base of the fittin as they are a boss type fitting
if you care making your own just use -4 fittings and -3 line? either way should work fine
i used this'
http://api.viglink.com/api/click?for...13626068092603
i used this'
i used this'
i used this'
no feed fitting to 3am...you have to do a 4an to 3an fitting....it sucks but must be done...speaking of which i need a new 4an-3an since i stripped mine ....oops
