Holset users unite!
I got my he351ve vgt f22b1 civic running good today man i love it. I used a spring to hold the vgt closed then as the exhaust pressure rises the vgt will open on it own i hope. either way it spools fast as hell way better than my 60/62 turbonetics. It feel way faster to. i had to add alot more fuel to the tune. I think it feel better at 8psi than my old setup felt at 15psi. going to the drag strip soon so i will find out.
in the works of building my f20b hx35, using a lovefab ramhorn manifold 44mm gate out the bumper, backdoor IC 3 inch exhaust, s300 for tuning. shooting for 400ish
this was great setup but the size of the turbo was to big. I had no room under the hood to do anything with. with antilag on my ectune i see no need for the fast spool
i looked thought the first 10 pages but i didnt see anything on d16z6 so im here to ask cause 126 pages is a lot for me to read
ok here come the question has anyone ran a hx35/h1c r a hy35 on a d16z6 and if so what were u pushing for power
Powertrain-
1.6 dohc zc, supertech pistons and valvesprings and retainers/ Eagle rods/ Arp Headstuds/ OEM headgasket/ JG engine dynamics cam gears
Converted to obd1
Si transmission/ ACT 6 puck clutch
Go-autoworks intercooler piping kit and miniram manifold
Holset HY35 turbo
Tial MV-R 44mm wastegate
Synapse 50mm bov
Back doored intercooler
3inch downpipe and exhaust
Innovative motor mounts
Aluminum Half Rad with slim fan
1000cc precision injectors
AEM 3.5Bar Map sensor
Converted to obd1
Holset HY35 turbo
Synapse 50mm bov
I got an hy35 on my zc, 335 @ 20 psi... You'd probablly be a little bit less then that... thats with stock intake mani and cams, bottom end and valve springs and retainers were done though
Who is Mr Robot?
I have an he351ve here and am seriously debating about making a viable VNT setup for my d16y8. Dsm guys have been seeing 10psi by 2400 or so(vanes closed) and 24 by 4500 (vanes open). Granted I'm down on displacement but our heads flow way better.
Opinions? The manifold setup would only cost about 125 bucks so if it's a total flop I'm not out a ton of money. I'd simply be using a wastegate actuator to control vane movement. I know people have successfully made electronic controllers but they take too much initial setup and tuning to be viable IMO.
The actuator keeps things simple and even underlow load/cruise situations i don't see having the vanes fully closed (it's about a 2-3cm housing at that point) causing backpressure/egt issues. But I could be wrong.
ive thought about looking into this as well but the only thing i saw that swurved me away from it was the efficiency range of these turbos is at very high psi if i remember correctly.
it would be a killer setup tho for sure
this is how did my vgt with a spring. it work great. i could spool very fast. I just had no room between the radiator and engine. Even with a slim fan pushing
Who is Mr Robot?
You were the one selling the setup on eBay right? I'm the one that messaged you questions lol.
The he351ve map has a broad range. At 10psi on the d16y8 I'm dead center on the bottom of the map
sorry i did not post the video also i never sold my setup i put the compressor wheel on a hx35 it is the some size as a hx40 wheel but made of billet. i am running the wheel now the he351 is no more than a hx35 hx40 hybrid
http://www.youtube.com/watch?v=iiDAB2bB7t8
