► ALL GEN Integra [FAQ] - DIY,Write ups, How to, etc
Old Oct 28, 2008 | 08:11 PM
Jimmy's Avatar
Global Moderator
Icon4 ► ALL GEN Integra [FAQ] - DIY,Write ups, How to, etc
Post up any threads you thought were helpful, and I will add them to the list.. any model integra just specify which generation..
Please NO CONVERSATION OR IRRELEVANT POSTS IN THIS THREAD. They will be deleted.. FAQ/info links only
Glossary
1) General Integra
2) Gen 1 specific
3) Gen 2 specific
4) Gen 3 specific
1) General Integra
Car security information
https://honda-tech.com/forums/acura-integra-6/car-security-time-serious-2505287/
* thanks The G2 Racer
ECU and ABS Codes
https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
---Warranty Extension---
https://honda-tech.com/zerothread/1528650 - 96 and 97 Emissions Warranty Extension
https://honda-tech.com/zerothread/1876291 - Lifetime seat belt warranty for all Acuras.
---Engine, General Information---
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/ - VTEC Not working??
https://honda-tech.com/forums/acura-integra-6/diy-oil-pan-gasket-replacement-%2A%2Apics%2A%2A-2588518/ - How to replace the oil pan gasket - thanks kroze
https://honda-tech.com/forums/acura-integra-6/diy-1995-acura-integra-ls-cam-cap-seal-2591794/ - How to replace cam cap seal - thanks kroze
https://honda-tech.com/forums/forced-induction-16/post-your-turbo-gsr-hp-numbers-1501150/ - turbo GSR numbers * thanks steveo
https://honda-tech.com/forums/acura-integra-6/how-rebuilding-94-97-power-steering-ps-pump-2388562/ - How-to: Rebuilding a '94 to '97 Power Steering (PS) Pump
https://honda-tech.com/forums/acura-integra-6/%5Bfaq%5D-post-your-gas-mileage-mpg-setup-2283874/ - Post your integras gas mileage
https://honda-tech.com/forums/acura-integra-6/oil-pan-install-2463900/- Oil pan install
https://honda-tech.com/forums/acura-integra-6/what-kind-transmission-oil-fluid-manual-trans-2295008/ - What Kind of Transmission oil/fluid in manual trans???
https://honda-tech.com/forums/acura-integra-6/440cc-injector-question-2452766/ - Resistors/resistor box info for hondas
https://honda-tech.com/forums/acura-integra-6/integra-walbro-pump-install-2424575/ - Integra walbro fuel pump install *thanks jayman
https://honda-tech.com/forums/acura-integra-6/need-gsr-torque-specs-1300573/ - GSR bottom end torque specs *thanks 97tegGS
https://honda-tech.com/forums/showthread.php?t=1263795 - How to install turbo kit
http://www.team-integra.net/forum/di...urnPage=Search - How to gauge in dash * thanks lpparker97ls
https://honda-tech.com/zerothread?id=2221344 - Half Dual core radiatior into integra
http://www.g2ic.com/specs.php - Stock integra specifications
http://faq.ef-honda.com/index.php?si...&id=21&lang=en - Honda Weight Chart
https://honda-tech.com/zerothread?id=1433240 - Where to buy oem parts?? (thanks nsxtasy)
https://honda-tech.com/zerothread/1794938 - How to: Vehicle security (thanks suspended hatch)
http://www.team-integra.net/sections...p?ArticleID=45 - What is VTEC?
https://honda-tech.com/zerothread?id=1694483&page=1 - How to GPS system for your car
https://honda-tech.com/zerothread?id=1604753 - How to replace valve stem seals
https://honda-tech.com/zerothread?id=1564019 - How to Clean your fast idle thermo valve
https://honda-tech.com/zerothread?id=1230496&page=2 - All turbo information
http://www.mediafire.com/?3w0nnsmxzip - 98-01 OEM foglight installation (download link to a .pdf file)
http://www.mediafire.com/?tjig5qyjj41 - 98-01 Foglight installation instructions (thanks blueintegraboy)
https://honda-tech.com/zerothread/1575913 - How to clean your idle air control valve (thanks wildoutgsr)
https://honda-tech.com/zerothread/1528650 - 1996-1997 Integra emissions warranty extension
https://honda-tech.com/zerothread?id=978933 - ECU & ABS CODES AND INSTRUCTIONS HERE!!!
https://honda-tech.com/forums/showth...st37569630-ARP head studs TQ specs
https://honda-tech.com/zerothread?id=967256 - B18C1 Internal Specs
https://honda-tech.com/zerothread?id=989547 – B18A1 and B18B1 Specs
https://honda-tech.com/zerothread?id=76154 – Compression Test, How To
https://honda-tech.com/zerothread?id=462021 – Valve Adjustment Tools
https://honda-tech.com/zerothread?id=303365 – Valve Adjustment, How To
https://honda-tech.com/forums/forced-induction-16/hi-def-how-valve-lash-adjustment-honda-engine-gsr-b18c1-3213442/ - HD Video - Adjusting Valve Lash (Thanks to OMG THE GOGGLES)
http://www.dansmc.com/sparkplugs1.htm - Spark Plug Information
https://honda-tech.com/zerothread?id=564764 – Throttle Body Sizes
https://honda-tech.com/zerothread?id=717928 – PCT Piston Compression Ratio
https://honda-tech.com/zerothread?id=1284177 - OBD2 Pinout (THANKS 97TEGGS)
https://honda-tech.com/zerothread?id=1300573 - B18C1 Torque Specs (THANKS 97TEGGS)
https://honda-tech.com/zerothread?id=1522860 - LS/GSR Oil Pan the same? (THANKS ELPIAR)
http://www.itrsport.com/specifications.html - General Integra Specs - (THANKS PREFERIO)
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-%2A%2A%2A-install-valve-springs-valve-stem-seals-1604753/ - How-To Install Valvesprings & Stem seals - (THANKS WILDOUTWHITEGSR & MOOGEN POWAH)
https://honda-tech.com/zerothread?id=715490 - Honda bearing thickness chart (thanks earl)
https://honda-tech.com/zeropost?cmd=tshow&id=2010737 - How to replace altenator w/o removing half shaft
https://honda-tech.com/forums/acura-integra-6/diy-installing-pro-sport-premium-oil-pressure-temp-gauges-2438785/ -Installing Pro Sport Premium Oil Pressure And Temp Gauges * thanks The G2 Racer
---Engine, Swaps---
https://honda-tech.com/zerothread?id=650329 – Hybrid Forum H22 Thread
https://honda-tech.com/zerothread?id=1218841 – F20B into DC Information
https://honda-tech.com/zerothread?id=1084100 – H22A into DC Information
https://honda-tech.com/zerothread?id=460871 – H22A into DC Information
https://honda-tech.com/zerothread?id=1164388 – H22A into DA Information
https://honda-tech.com/zerothread?id=1173283 – B16A into DA Information
https://honda-tech.com/zerothread?id=1100740 – K20A into DA Information
https://honda-tech.com/zerothread?id=830385 – K20A into DC Information
---Engine, LS/VTEC and CRVTEC---
https://honda-tech.com/forums/acura-integra-6/ls-vtec-hp-2207108/ - Good LS/VTEC discussion
https://honda-tech.com/zerothread?id=1676914 - LSVTEC Build (THANKS MADNESS)
https://honda-tech.com/zerothread?id=1812388 - LSVTEC Build price list (THANKS MADNESS)
https://honda-tech.com/zerothread?id=1119323 – A Few Good Links
https://honda-tech.com/zerothread?id=1082172 – A Few More Good Links
https://honda-tech.com/zerothread?id=1083788 – Break-In Period
https://honda-tech.com/zerothread?id=501372 – Reliability Issues
https://honda-tech.com/zerothread?id=720621 – Quarter Mile Times
https://honda-tech.com/zerothread?id=805408 – Using LS ECU
https://honda-tech.com/zerothread?id=1467903 - B20 NonVtec FAQ - (THANKS DRINTEGRA & BAMBAM)
https://honda-tech.com/zerothread/1767009 - B18C1 vs B16A Head flow chart (THANKS dohcMONSTER)
---Engine, Intake Manifolds and ITB’s---
https://honda-tech.com/zerothread?id=682550 – Skunk2 Official Thread
https://honda-tech.com/zerothread?id=1207871 – Skunk2 High Idle Problem
https://honda-tech.com/zerothread?id=1155814 – Blox vs. Skunk2
https://honda-tech.com/zerothread?id=1093861 – Edelbrock vs. Skunk2
https://honda-tech.com/zerothread?id=1122600 – ITB Information
https://honda-tech.com/zerothread?id=947432 – GSXR 1000 ITB’s
https://honda-tech.com/zerothread?id=1031905 – ITB’s and Boost
https://honda-tech.com/zerothread?id=1141806 - How to: Blox Intake Manifold Install (THANKS HONDA HICK)
https://honda-tech.com/zerothread?id=1194241 - AEM CAI vs J's Racing - (THANKS DOHC MONSTER & GUILLOTINE)
---Tranny---
https://honda-tech.com/forums/showthread.php?t=2295008 - What kind of Transmission fluid in manual trans?
https://honda-tech.com/zerothread?id=382416 - Axle replacement No pics, good info.
https://honda-tech.com/zerothread?id=795700 – Overhaul Procedures
https://honda-tech.com/zerothread?id=1037310 – OEM Tranny Comparisons
https://honda-tech.com/zerothread?id=965397 – Fluid Discussion
https://honda-tech.com/zerothread?id=999135 – Fluid Discussion
https://honda-tech.com/zerothread?id=569961 – Final Drive Information
https://honda-tech.com/zerothread?id=239927 – 4.7 Final Drive Information
https://honda-tech.com/zerothread?id=415423 – 4.9 Final Drive Information
https://honda-tech.com/zerothread?id=1225713 - Gear Ratio Discussion
https://honda-tech.com/zerothread?id=1255332 - auto to manual swap
https://honda-tech.com/zerothread?id=273253 - Auto to Manual Conversion Info (THANKS VIRUSIIDX & KENDALL)
http://www.ff-squad.com/tech/temp/Bgears.htm - gear ratios, tranny codes, cars they came in, etc. (THANKS LSVTEC03)
---Flywheel---
https://honda-tech.com/zerothread?id=949790 – Lightweight Flywheel Discussion
https://honda-tech.com/zerothread?id=1016532 – Lightweight Flywheel Discussion
https://honda-tech.com/zerothread?id=1023138 – Stock Flywheel Weight
---Clutch---
https://honda-tech.com/zerothread?id=1181405 – Clutch Break In Period
https://honda-tech.com/zerothread?id=1155839 – Goodridge Clutch Line
https://honda-tech.com/zerothread?id=1210901 – Clutch/Flywheel Combo’s
https://honda-tech.com/zerothread?id=1201903 – ACT Discussion
https://honda-tech.com/zerothread?id=479958 – Bleeding Procedures
https://honda-tech.com/zerothread?id=1274247 - Slave Cylinder Removal (THANKS 97TEGGS)
https://honda-tech.com/zerothread?id=1274249 - Master Cylinder Removal (THANKS 97TEGGS)
---Brakes---
How to: 11 inch brakes on 3rd gen - Honda-Tech - Thanks Dan GSR (picture may not work)
https://honda-tech.com/zerothread?id=1584925 - How to clean front ABS sensor
https://honda-tech.com/zerothread?id=914614 – Bleeding Procedures
https://honda-tech.com/zerothread?id=1205135 – Setup List
https://honda-tech.com/zerothread?id=1079051 – 96spec ITR on DA
https://honda-tech.com/zerothread?id=1024546 – NSX Brakes
https://honda-tech.com/zerothread?id=408117 – ITR Calipers
https://honda-tech.com/zerothread?id=1451186 - ABS Leaks (THANKS GOLD EF)
---Suspension---
https://honda-tech.com/forums/acura-integra-6/faq-how-replace-rear-suspension-bushings-full-guide-2944576/ - Replacing Rear Suspension Bushings
https://honda-tech.com/forums/acura-integra-6/how-install-asr-subframe-brace-itr-sway-bar-dc2-integra-2729517/ - How to: Install ASR subframe brace and ITR sway bar on DC2 Integra * thanks GagnarTheUnruly
https://honda-tech.com/forums/acura-integra-6/install-cusco-18-mm-rear-swaybar-asr-subframe-brace-2559657/ - How to: Cusco 18 mm rear swaybar with the ASR subframe brace * thanks court76wi
https://honda-tech.com/zerothread/887859 - How to pop your lower balljoints
https://honda-tech.com/zerothread?id=230216 – ITR Sway Bars vs. Aftermarket
https://honda-tech.com/zerothread?id=161618 – Rear Subframe Discussion
https://honda-tech.com/zerothread?id=57813 – Strut and Sway Bar Discussion
https://honda-tech.com/zerothread?id=1183184 – GC/Koni vs. Tein Flex
https://honda-tech.com/zerothread?id=1045933 – Omnipower vs. Tein SS
https://honda-tech.com/zerothread?id=1103358 – Omnipower vs. Tein Flex
https://honda-tech.com/zerothread?id=975313 – Coilovers vs. Springs
https://honda-tech.com/zerothread?id=1192976 – Ebay Coilover Discussion
https://honda-tech.com/zerothread?id=1103213 – DA Coilover Discussion
https://honda-tech.com/zerothread?id=1194211 – Shock Discussion
https://honda-tech.com/zerothread?id=1135707 – ITR Shock Discussion
https://honda-tech.com/zerothread?id=957088 – Aftermarket Springs/Stock Shocks
https://honda-tech.com/zerothread?id=1202600 – Lower Mount Discussion
https://honda-tech.com/zerothread?id=1157855 - What Coilovers? Heres 2, Omnipower vs D2 (THANKS BLACK FIRE)
---Headers---
http://bob123e.tripod.com/thegreatheadertest/index.htm - 2001 Header Test
https://honda-tech.com/zerothread?id=700477 – 2003 Header Test (Titan)
https://honda-tech.com/zerothread?id=1214415 – 2005 Header Test (SRZ)
https://honda-tech.com/zerothread?id=1199647 – Header Fitment
https://honda-tech.com/zerothread?id=1178330 – Ground Clearance
---Exhaust---
https://honda-tech.com/zerothread?id=1169148 – 2.25 vs. 2.5
https://honda-tech.com/zerothread?id=1178654 – ITR Exhaust Discussion
https://honda-tech.com/zerothread?id=1178516 – Hangar Removal
https://honda-tech.com/zerothread?id=1190920 – Exhaust Opinions
https://honda-tech.com/zerothread?id=1209065 – Axleback Opinions
---Tires---
https://honda-tech.com/zerothread?id=1001286 – Tire Pressure
https://honda-tech.com/zerothread?id=1202771 – Tire Opinions
https://honda-tech.com/zerothread?id=1096794 – Winter Tire Discussion
https://honda-tech.com/zerothread?id=767737 – Tire Size and Final Drive
---Interior---
https://honda-tech.com/forums/acura-integra-6/%5Bfaq%5D-how-install-integra-type-r-cluster-into-your-non-itr-integra-gsr-ls-etc-1836281/ - [FAQ] How To Install An Integra Type-R Cluster Into Your Non-ITR Integra (GSR, LS, etc...) * thanks BlueIntegraBoy
https://honda-tech.com/forums/acura-integra-type-r-8/how-use-jdm-foglight-switch-usdm-foglights-harness-1530877/ - How to: Use JDM foglight switch with USDM foglights and harness * thanks BlueIntegraBoy
https://honda-tech.com/zerothread?id=2171028 - DIY How to remove window tint
https://honda-tech.com/zerothread?id=1942094 - How to LEDS in your 94-01 integra cluster
https://honda-tech.com/zerothread/1875083 - How to install JDM ITR SRS Steering wheel (thanks blackfire)
https://honda-tech.com/zerothread?id=1920709 - How to install aftermarket steering wheel with working hornbutton
https://honda-tech.com/zerothread?id=1185700 – Maintenance Light Reset
https://honda-tech.com/zerothread?id=490283 – DC Gauge Cluster Swap
https://honda-tech.com/zerothread/1836281 - ITR Gauge Cluster Swap
https://honda-tech.com/zerothread?id=824716 – Weight Reduction
https://honda-tech.com/zerothread?id=901154 – Good Weight Reduction Link
https://honda-tech.com/zerothread?id=347548 - How to: S2000 seats in EG/DC (THANKS KENDALL & SILVERCIVIC2K)
https://honda-tech.com/zerothread?id=1336811 - RSX Seats into DC2/DC4 - (THANKS KENDALL)
https://honda-tech.com/zerothread?id=1925743 - DIY how to dye your tan interior black
---Exterior---
https://honda-tech.com/forums/lighting-107/how-jdm-itr-hid-headlight-fog-light-wiring-2195061/ - How to - JDM ITR HID Headlight and Fog Light Wiring * thanks spids5
https://honda-tech.com/zerothread/2121541 - Integra paint codes
https://honda-tech.com/zerothread?id=1913691 - s2k HID retrofit (thanks slo97coupe)
https://honda-tech.com/zerothread/2163653 - 98-01 Bumper Covers on 94-97
https://honda-tech.com/zerothread?id=1346217 - How to JDM FRONT.. (THANKS JDMOMO AND JUICYFN)
https://honda-tech.com/zerothread?id=1233939 - Integra Taillight Differences by Year (JDM vs USDM) - (THANKS KENDALL & SONICBLUETEG)
https://honda-tech.com/zerothread?id=685131 - How-to USDM Foglight Switch (THANKS CLIFFJUMPER2 & BUNMANGO)
https://honda-tech.com/zerothread?id=790409 - Detailing FAQ - (THANKS BUNMANGO)
https://honda-tech.com/zerothread?id=1358777 - Window Visor Install for coupe (THANKS G-BONIC)
https://honda-tech.com/zerothread?id=1549788 - Another good 2dr coupe window visor install
https://honda-tech.com/zerothread?id...ostid=33155562 - window visor install for 4dr door model integras
https://honda-tech.com/zerothread?id=683685&page=1 - [faq] the official H.I.D thread
https://honda-tech.com/forums/acura-integra-6/diy-jdm-fog-light-wiring-2421886/ - DIY: JDM Foglight wiring * thanks HONDRETTI
---Links to Other FAQ’s That You Should Read---
https://honda-tech.com/zerothread?id=1171263 – EG+ Forum ECU FAQ
2) Gen 1 specific
86-87 US model years were vac advance
88-89 US model years were electronic advance
an SE model was offered in 87 and 88 in Black or White and had body colored side mouldings, sideskirts and a rear rubberized wing. The SE also had power windows and improved front sway bar and larger rear torsion bar in rear "swaybar". http://www.g1teg.org
Available as a 3 door hatchback or a 5 door hatch back in RS or LS trims. All LS trims had a sunroof, Sunroof in an 86-87 was a flip up/ removable piece of glass and 88-89 were a sliding motorized glass piece.
Suspension is comprised of a front torsion bar setup which can be lowered by adjusting a nut on the torque tubes. Rear suspsnion is a Panhard torsion beam setup.
Hasport offers mounts that allow you to swap in any B-series engine (bastard prelude b20 not included). http://www.hasport.com
Aftermarket torsion bars are available to stiffen up the front suspension (popular sizes are 24mm and 27mm)
Tein makes a custom suspenion setup for these cars available only through Heel Toe Automotive ( http://www.heeltoeauto.com ) This kit is known as the Medieval-Pro kit. It can be ordered with whatever rear spring rate you choose and can be custom valved as well. 16 points of dampening adjustment. Comparable to the Super Street kit for other Hondas.
Upgraded front brake kits are available from http://www.fastbrakes.com (11 inch rotors with later model Integra or Civic calipers.
The ECU used in these cars were both PG7 but only the 88-89 ECU can be socketed with an aftermarket chip for tuning. The 86-87 ECU is not tunable at all. http://g1teg.org/phpbb3/viewtopic.php?f=11&t=20338
Information on converting from OBD0 to OBD1 on an 88-89 Integra: http://g1teg.org/phpbb3/viewtopic.php?f=11&t=26661
MLS Head Gaskets for D16A1/ZC
Bore Material Stock Code Pkg Qty Price
75.5mm MLS .030" C4522-030 1 $89.96
76mm MLS .030" C4524-030 1 $89.96
77mm MLS .030" C4525-030 1 $89.96
78mm MLS .030" C4526-030 1 $89.96
http://www.cometic.com/sportcompact.aspx
DO NOT USE FELPRO (failpro) HEADGASKETS OR VALVE SEALS!!!!!! They will fail and leak.
Information on how to put 3rd gen Integra seats into a 1st gen Integra: http://www.g1teg.org/phpbb3/vi...32107
3) Gen 2 specific
* How To: Remove Bumper and Intake Resonator
https://honda-tech.com/forums/acura-integra-6/how-remove-bumper-intake-resonator-3011866/
* HOW TO: S2000 Cluster Swap In 92-93 DA Integra
https://honda-tech.com/forums/showthread.php?t=2465834
* DIY: Fixing The Passenger Side Cowl Leak On A 90-93 Integra
https://honda-tech.com/forums/acura-integra-6/diy-fixing-passenger-side-cowl-leak-90-93-integra-2548435/
* b-series turbo guide
http://beesandgoats.com/boostfaq/g2icturbo.html
* nxs or legend brake upgrade sorry no pics on links
https://honda-tech.com/zerothread?id=239844
* b block build up
https://honda-tech.com/zerothread?id=991796&page=1
* how o identify ecu (dammmmm 5-19-02) been here a long time
https://honda-tech.com/zerothread?id=631250
* year and model of car using vin number
http://www.team-integra.net/se...D=354
* the ever so famous ls/vtec damm one of skribblah first questions back in 03
https://honda-tech.com/zerothread?id=501372&page=1
* another brake upgrade thread
https://honda-tech.com/zerothread?id=734560
* security alarm wiring
http://www.bulldogsecurity.com
* honda distributors
http://www.hondadistributors.n...tegra
* how to clean idle air control valve
* how to install valve springs and valve stem seals
https://honda-tech.com/zerothread/1604753
* radio code retrieval
https://honda-tech.com/zerothread/2373109
* painting your DA's aged trim and moldings
https://honda-tech.com/zerothread/2303815
* main relay repair
http://techauto.awardspace.com/mainrelay.html
* auto to manual conversion
https://honda-tech.com/zerothread/2304301
* installing a 92-93 front bumper on a 90-91
https://honda-tech.com/zerothread/2305064
* basic instructions on swaps for all the b series motors into both the obd0 and obd1 versions of the 2nd gen integra
http://www.g2ic.com/tegtips/engine/15.html
* installing indiglo gauges
http://www.g2ic.com/tegtips/interior/21.html
* Replacing rear trailling arm bushings
http://www.performanceforum.co....html
* 90-91 to 92-93 clutch differences.
http://www.g2ic.com/forums/showthread.php?t=181805
* OBD0 - OBD1 conversion.
http://www.g2ic.com/forums/showthread.php?t=86612
* how to amber your clock
https://honda-tech.com/zerothread?id=2394293
* PGM-FI Main Relay location for the '90-'93 Integra
http://www.tegger.com/hondafaq/mainrelay.html
* Power Steering Removal Gen2 90-93
http://www.team-integra.net/fo...00109
*WRITEUP* 90-93 Integra cruise control fix
https://honda-tech.com/zerothread?id=1868099
* 90-93 Integra Basic Troubleshooting Guide
http://www.team-integra.net/fo...10017
4) Gen 3 specific
ALL GEN 3 SPECIFIC Integra General information/specifications (click here)
*94-97 model pictured
*98-01 model pictured
All Acura integra Service Bulletins
Acura integra wiring manual (.pdf file)
* You will need adobe acrobat reader to read .pdf files..
See: Download adobe reader
* thanks vesperfx, steveo135.
**How-To/DIY: Wire Tucking Engine Bay Side Harnesses for 94-01 3rd Generation Integra
https://honda-tech.com/acura-integra...tegra-3228764/
Thanks to Apathy47
Q: What all is needed to put a 98+ frontend on my 94-97?
A: bumper,headlights,bumper lights,bumper light bracket
Q: Where can i purchase OEM acura parts online?
A: http://www.acuraoemparts.com & http://www.acuraautomotiveparts.org/
Preventive maintenance intervals - thanks steve0135
General engine information
'97-'01 Integra Type R - B18C5 1797 10.6:1 195hp@8000RPM/130lb-ft@7500
'94-'01 Integra GS-R - B18C1 1797 10.0:1 170hp@7600RPM/128lb-ft@6200
'94-'01 Integra LS/RS/GS/SE - B18B1 1834 9.2:1 142hp@6300RPM/127lb-ft@5200
Engine oil capacities:
Integra RS,GS,LS,SE (engine code: b18b1)
4.0 quarts
Integra GSR (engine code: b18c1) & Type R (engine code: b18c5)
4.2 quarts
General transmission information
Transmission fluid capacity:
(Automatic) drain and refil = 2.9 quarts
(manual tranny) = 2.3 quarts
Transmission teeth count, tranny codes, etc.
Ratio
4-speed automatic
1st 2.722
2nd 1.468
3rd 0.975
4th 0.638
Final drive 4.357
reverse 1.954
rs,ls,gs,se 5-speed manual
1st 3.230
2nd 1.900
3rd 1.269
4th 0.966
5th 0.714
Final drive 4.266
reverse 3.000
GS-R 5-speed manual
1st 3.230
2nd 1.900
3rd 1.360
4th 1.034
5th 0.787
Final drive 4.400
reverse 3.000
US 97-01 ITR
JDM 95-97 ITR
JDM 92-00 SiR/CTR
Hydro
1st 3.230
2nd 2.105
3rd 1.458
4th 1.107
5th 0.848
reverse 3.000
Final drive: 4.4
JDM 98-01 ITR
1st 3.230
2nd 2.105
3rd 1.458
4th 1.034
5th 0.787
reverse 3.000
Final drive: 4.785
General integra specs/model info
Integra weight
RS: 2529 (2 door) 2670 (4 door)
LS: 2643 (2 door) 2703 (4 door)
SE: 2663 (2 door) 2723 (4 door)
GS: 2663 (2 door) 2723 (4 door)
GSR: 2687 (2 door) 2765 (4 door)
Type R: 2577 (2 door)
* Note these weights could vary due to options available from the factory and to variations in standard equipment from year to year.
Specific Model information
Integra RS (discontinued after 1998): No abs, No moon roof, power windows,power door locks are an option, came with cloth seats
Integra LS: (luxury sport) Came with power door locks, sun roof, power windows, Has ABS, The LS also came with cloth seats
Integra SE (special edition): (only available in 1995/1996 which is basically the integra GSR without the suspension and engine upgrades) Comes standard with leather, moon roof and all power options
Integra GS (grand sport) the "twin" of the SE but wasn't released until 1997.. Basically the GSR without the engine & suspension (comes standward with all power options and moon roof)
Integra GSR: Moon roof, all power options,In earlier years of GSR's leather was optional, after 1999 leather came standard.. They also came with DOHC VTEC engine
Integra Type R (U.S. 1997-98, 2000-2001): Basically the GS-R with performance upgrades and certain equipment deleted (sunroof, sound insulation, map lights, cruise control). See the FAQ in the Integra Type R forum for more information.
Integra Brakes ALL (except type r)
Front: Front Brakes Ventilated - 10.3 in. rotor
Rear: Solid 9.4 in. rotor
Brake pad lining thickness (minimum) 1/16th inch
Parking brake adjustment (6 to 10 clicks)
* 00-01 are OBDIIb (chip in key). 96-99 are OBDIIa. 94-95 are OBDI.
This [faq] would not be possible without the great contributions kendall (for making the original faq) HybridcivicLS-T, dogg and all the other members who posted links, did a write up or posts helpful information.. thank you all for your contributions.
Last edited by Jimmy; Dec 7, 2014 at 12:41 PM. Reason: Added rear suspension bushings link.
Old Dec 13, 2008 | 05:41 PM
suspendedHatch's Avatar
2nd Gen Integra
http://causeforalarm.thecarthing.com/version6/ - How not to get jacked
3rd Gen Integra
http://causeforalarm.thecarthing.com...gra/index.html - Stealth alarm install
Old Dec 29, 2008 | 06:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ** ► NEW: Integra Forum - Frequently asked questions
Are there any good links on the common G2 Integra water leak problem on the passenger side? That should probably be added in here if there is a good how-to on that.
Old Jan 12, 2009 | 07:48 PM
crxstylin's Avatar
Ask and ye shall receive
https://honda-tech.com/forums/acura-integra-6/dyi-da-passenger-waterleak-fix-pics-2472431/
Old Jan 29, 2009 | 01:48 PM
DuongBros.'s Avatar
Default Re: ** ► NEW: Integra [FAQ] - Write ups, How to, etc
is there a thread on ABS delete on 3rd gen integras?
Old Jan 30, 2009 | 11:30 AM
Spids5's Avatar
Don't judge or question
https://honda-tech.com/forums/showthread.php?t=2195061
Old Jan 30, 2009 | 01:18 PM
Jimmy's Avatar
Global Moderator
Added! Thanks.. everything is up to date
Old Feb 5, 2009 | 02:51 PM
BlueIntegraBoy's Avatar
Old Feb 7, 2009 | 08:12 PM
steveo135's Avatar
came across this and thought it would be a good idea to link it here...
turbo GSR numbers
https://honda-tech.com/forums/showthread.php?t=1501150
Old Feb 23, 2009 | 02:36 PM
OEM Installation Instructions
--- 98-01 Integra OEM Kit Instructions (now with template)
--- 98-01 Integra Fog Light Installation Instructions (now with templates)
Old Feb 23, 2009 | 07:26 PM
JDM JON's Avatar
this went on my favorites ASAP.
Old Apr 9, 2009 | 02:48 PM
DA9_DAD's Avatar
Write up link for Gen 2 Rear Trailing Arm replacement - using Energy Suspension.
https://honda-tech.com/forums/acura-integra-6/replacing-rta-bushings-da9-using-energy-suspension-2544895/
Old May 5, 2009 | 09:09 AM
Eletcrik_600RR's Avatar
Default Re: ► NEW: Integra [FAQ] - Write ups, How to, etc
this is great, loads of usefull information
Old May 28, 2009 | 12:02 PM
HONDRETTI's Avatar
jdm fog light wiring...
https://honda-tech.com/forums/showth...+jdm+fog+light
Old Jun 7, 2009 | 12:52 AM
Jimmy's Avatar
Global Moderator
Added. Everything's up to date
Old Jul 1, 2009 | 02:26 AM
longzorz's Avatar
any write ups on retrofitting ebay one pieces with projectors, what projectors to use, which ones have hi/lo beams. step by step w/ pix. thanks
Old Aug 14, 2009 | 03:55 PM
deeayenine's Avatar
New User
Default Re: ► ALL GEN Integra [FAQ] - DIY,Write ups, How to, etc
Just wanted to let you guys know the tips on here are great and very helpful.;
Old Sep 2, 2009 | 02:25 PM
SlapSmak's Avatar
DIY Alignment, with equipment list:
https://honda-tech.com/forums/acura-integra-type-r-8/diy-r-alignment-quick-method-2631081/
Old Sep 5, 2009 | 01:43 PM
newyorkhcm's Avatar
New User
Default re: pdf creator
Just get this program : PDF Creating v2.0
PDF Creator: create PDF documents easily
Download:
http://www.mediafire.com/download.php?dtnyt5zgez1
Old Sep 13, 2009 | 07:22 AM
kentwat's Avatar
New here I just wanted to give info. 90 Integra LS ECU is under the carpet on the passenger side.
http://www.troublecodes.net/acura/
Can you move this post here please.
https://honda-tech.com/forums/showthread.php?t=978933
Last edited by kentwat; Sep 13, 2009 at 07:24 AM. Reason: Want to move post to another thread.
Old Nov 4, 2009 | 07:36 PM
NYCxTEG's Avatar
need link to diy of '98+ bumpers on '94-'97???
Old Nov 6, 2009 | 03:23 PM
Sephrin's Avatar
i need some help perhaps a picture to show where the sensor is located, i am changing out the crank positioning sensor, but i dont know where it is located at to begin
please send responses to sephrin@hotmail.com
Old Nov 8, 2009 | 06:59 PM
tunerimports_85's Avatar
Default Mr CRX
If Your Heater A/C Blower motor goes out on a 2nd Gen Integra a civic one will work. Alot of parts stores dont stock acura parts but will civic
Old Nov 10, 2009 | 06:38 PM
Si-vtay's Avatar
Useful thread. thanks
Old Nov 11, 2009 | 07:53 PM
EFboosted's Avatar
Did Anyone do a DIY on the teardown and rebuild of a stock B18C1 with pics ??
