[FAQ] Post your Gas mileage (MPG) & Setup
Well with gas being at an all time high.. I'm curious what everyone's MPG is in your integra. Right now it's $3.49 for regular unleaded.
Myself I drive a '94 integra rs with a jdm b20b.. Intake,exhaust..
I'm running a chipped PR-4 with a crome pro basemap for a b20b with i/h/e
City 25-28mpg
Highway 32-35
I've noticed my MPG varies though and it depends where i get gas from.. I do better when i get gas at shell.. (no ethanol i believe)
City 25-28mpg
Highway 32-35
Re: Post your Gas mileage (MPG) & Setup (Jimmy)
man thats cheap $3.49 its like $3.79 where i am.
my car is basically stock except for like intake and i get about the same highway mileage as u. i dont know about city i never calculated it.
Re: Post your Gas mileage (slowtegkauai)
I hope this helps.
City 24-26
Highway 28-30 Record so far 31.6mpg
<U>Exhaust</U>
DC Sports 4-1 2-1/4" Header
SMSP High Flow Cat
Comptech Cat-Back Exhaust
<U>Intake</U>
RC Engineering Ported GSR Throttle Body 70mm>64mm
RC Engineering injectors w/clips 370cc
DPR Ported GSR Intake Manifold
AEM GSR Cold Air Intake
<U>Block</U>
USDM ITR Pistons (81.25)
USDM ITR Rods
<U>Head</U>
DPR Stage 5 Port ‘n’ Polish
Rocker Arm Balance and Lightening
ITR Valves, ITR Springs, ITR Retainers, ITR LMA’s
CTR Intake Cam Shaft
ITR Exhaust Cam Shaft
(Compression Ratio 11.5:1)
<U>Transmission</U>
Spoon Sports Flywheel
ACT HDSS Clutch
ITR LSD
<U>Suspension</U>
Eibach Pro-kit Springs
Koni Yellow Shocks
Ingalls Engine Damper
ITR 22mm Rear Sway Bar
<U>Chassis</U>
EM Racing Trunk Floor Brace
ASR Sub Frame Reinforcement Brace
<U>ECU</U>
Skunk2 OBD2a>OBD1 Harness with IAB control
P72 OBD1 ECU
Hondata S300
<U>Misc.</U>
Unorthodox Light Weight Pulleys, AC and PS ONLY
Samco Radiator Hoses, Black
Hyper Voltage System, Grounding Wires
NGK Power Cables, Plug Wires
Daily Diet-Marathon 93
City 24-26
<U>Exhaust</U>
SMSP High Flow Cat
<U>Intake</U>
<U>Block</U>
USDM ITR Rods
<U>Head</U>
<U>Transmission</U>
ACT HDSS Clutch
ITR LSD
<U>Suspension</U>
Koni Yellow Shocks
<U>Chassis</U>
<U>ECU</U>
P72 OBD1 ECU
Hondata S300
<U>Misc.</U>
97' rs coupe stock b18b engine and trans
127,xxx miles
always 22 MPG no matter what
intake
4-1 header
eibach springs
14" faulken tires with stock brakes
power pulleys
127,xxx miles
intake
4-1 header
eibach springs
power pulleys
98 LS Sedan
***Stock Engine***
T3/T4 Turbo
3" Downpipe
2.25" Thermal exhaust (for the quietness)
DSM 450cc Injectors
Tuned with Crome
AEM Wideband (helps me conserve fuel on highway)
15" Drag DR-16 wheels with Kuhmo SPT tires
Used to get a max of 30-31 Highway pre-turbo
Latest trip I took was 98% highway and I averaged 38 MPG over 200 miles.
That was only boosting a handful of times and being ultra conservative on the throttle. You'd be surprised how backing out of the throttle the slightest bit can do to your MPG (while still maintaining your speed)
Gas this morning was $3.49 for 87, so $3.69 for 91/93
***Stock Engine***
T3/T4 Turbo
3" Downpipe
DSM 450cc Injectors
Tuned with Crome
Re: Post your Gas mileage (honda_joe)
I've hit 36 mpg, combined city/highway before with my GSR. Most recently, I hit 32.9 cruising @ 70-75 MPG with 500 lb worth of passengers. Some city driving as well, but mostly highway.
Rebuilt GSr, 15,000 miles
ITR cams
Shaved head 12 thousandths
Blox IM
AEM SR intake
MSD cap/coil
TUned with chrome
16" Drag (Gt3 knockoffs).
ITR cams
Blox IM
AEM SR intake
MSD cap/coil
TUned with chrome
Semper Fidelis
Re: (hatchling37)
00 GSR (look in sig for setup)
City-22-27
Highway- 30-38
Got 38 last summer on my way to huntsville with the wife and baby at 75
96 GMC 1500 Reg. cab, long bed 4.3l V6 2wd stock
City-13mpg
Highway-14mpg
87 Octane $3.49
93 Octane $3.73
I no longer work out of my truck so it is going up for sale in Sept.
City-22-27
Highway- 30-38
City-13mpg
Highway-14mpg
87 Octane $3.49
93 Octane $3.73
That's probably because we don't mash it every intersection we come across,
But on the average, I get about 25-27 city, 34-35 highway. Last trip I took to Utah though I was getting about 38.
2000 LS, Intake, Exhaust, that's it.
$3.89 Regular Unleaded here.
Bone stock 96 LS. 98% Highway driving about 27MPG (most recent was 25 ) always full passengers and full trunk. To give you an example of how much weight is in the car, the back tires tuck and I'm riding on stock suspension. I'm not sure how much of an impact weight has with gas mileage, but recently it's been going down. A few months ago I was still getting about 29-30.
Modified by NzAnE2K at 2:08 PM 4/23/2008
1 Post
Re: Post your Gas mileage (OH_1fstgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OH_1fstgsr »</TD></TR><TR><TD CLASS="quote">I hope this helps.
City 24-26
<U>Exhaust</U>
SMSP High Flow Cat
<U>Intake</U>
<U>Block</U>
USDM ITR Rods
<U>Head</U>
<U>Transmission</U>
ACT HDSS Clutch
ITR LSD
<U>Suspension</U>
Koni Yellow Shocks
<U>Chassis</U>
<U>ECU</U>
P72 OBD1 ECU
Hondata S300
<U>Misc.</U>
Daily Diet-Marathon 93</TD></TR></TABLE>
With all these mods, I'd expect you to be in the 190+ whp range!
My car... 94 GSR with 200k miles. --- 32mpg hwy, 24-26 city & hwy
Paying $4.05 for premium right now (91 oct)
Dyno'd 167whp and 132lbs of torque
Mods:
comptech ice box intake system
skunk2 IM
ctr intake cam
comptech 4-2-1 header
apexi ws2 exhaust
custom tuned p28 ecu
still runs like a champ!
Modified by iH8RICERZ at 2:11 PM 4/23/2008
City 24-26
<U>Exhaust</U>
SMSP High Flow Cat
<U>Intake</U>
<U>Block</U>
USDM ITR Rods
<U>Head</U>
<U>Transmission</U>
ACT HDSS Clutch
ITR LSD
<U>Suspension</U>
Koni Yellow Shocks
<U>Chassis</U>
<U>ECU</U>
P72 OBD1 ECU
Hondata S300
<U>Misc.</U>
Mods:
skunk2 IM
ctr intake cam
apexi ws2 exhaust
Re: Post your Gas mileage (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">
Mods:
skunk2 IM
ctr intake cam
apexi ws2 exhaust
Modified by iH8RICERZ at 2:11 PM 4/23/2008</TD></TR></TABLE>
The dyno I used reads 5-10hp low compared to another Dynojet in town. Not really a big deal just a bit more work to get to 200.
87 octane $3.58
Mods:
skunk2 IM
ctr intake cam
apexi ws2 exhaust
87 octane $3.58
pretty much stock ls and i get about 35mpg on the highway and going to work ive never did the math lazy but i am getting 320 or so to a tank soon to be boosted so its all down here from there
last time i filled up i think i paid about 3.49 for 87... today i just put some gas in at 3.73... and for the first time in my life, i had to watch the meter to make sure i didnt overdraw my bank account.
as for mileage: i have a 95 ls, intake/exhaust with a system and some crap in the back, propably totalling 100 lbs, and driving like an *** everywhere i go, i get 26 pretty consistenly driving through the backroads of conneticut.
Re: Post your Gas mileage (raj_very)
aight so idk what i'm runnin to be honest as bad as that sounds...i mean i know what i'm running, but i can't really tell u cuz i don't wanna sound like an idiot
but as far as gas prices out here in NW suburbs of chicago, its like 3.50 - 3.60...idk i haven't filled up in a while cuz my car is being revived at the moment...
i don't really know what my mpg is like in the city and the highway but i'll tell u this...
i get around 180 miles to a full tank...
i kno....its bad
i kno....its bad
Re: Post your Gas mileage (infamouskillas)
in my 95jdm gsr i get around 23-28mpg around town.(depending on hw i drive) ive only driven on they highway a few times an gotten about 32 id say. yea gas prices in the NW suburbs of chicago are ridicuous. just filled up at shell yesterday $4.00 a gallon!
