Plastic Dip + Paint question
Old Oct 17, 2014 | 01:53 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Plastic Dip + Paint question
I want to plastic dip some chrome parts and wheels lets say. But it does not come in the OEM color. Plastic dip because I'm not sure if I want it permanent.
What do you think of this:
Plastic dip spray first. Then spray it with OEM color paint. (Then clear coat) So it's a perfect match. Since the bottom coat is plastic dip, it should peel off as it should, correct?
Will paint on top of plastic dip will crack (because plastic dip is "soft"), you think?
Let's say white plastic dip and OEM diamond pearl white. If there are some cracks, it still looks white, and wouldn't stand out, you think?
Comments and thoughts?
Old Oct 17, 2014 | 05:11 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Plastic Dip + Paint question
I think it might last if you put the additive in the OEM color paint to make it flexible.
Old Oct 19, 2014 | 10:37 PM
gorillafart's Avatar
biggest waste of money. but thats just my opinion. go ahead and give it a try.
Old Oct 20, 2014 | 07:25 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Which part? The reply above or my original post?
Old Oct 20, 2014 | 01:37 PM
tollickj's Avatar
I've used plasti dip before... I personally will NEVER use that crap again. I know people have had good experience with it... I did the whole car and rims... If you don't have enough coats, like 4-7 coats on it good luck trying to remove it... It will come off in pieces. If you go to there website they do sell a "solution" that makes it "easier" to remove the plasti dip. Also on their website they have WAY more selections to choose from.
Old Oct 20, 2014 | 02:32 PM
sixstroke's Avatar
Plasti-dip is great stuff. I do it on the side and it can easily last a couple years if taken care of properly.
Essentially, anyone that has an issue with it, installed it wrong. Plain and simple. And then they go online, bashing the product. Due to their ignorance and negligence.
Also, do not paint anything over plasti-dip. That is something that is well-documented, both on their official site and their youtube videos.
Sounds like you need to do more research of your own.
Old Oct 21, 2014 | 10:38 PM
Hidenplanvew's Avatar
paint wont last over plasti dip, just do something custom or suck it up and paint them.
Old Oct 22, 2014 | 12:05 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Have you plasti dipped an entire car before?
Just curious to know how many gallons of spray I might need to cover my 1999 Honda CR-V. I'm just doing it in Black. I was told about 5-7 coats. Kind of depends on what kind of gun I'm using and how much product is coming out on each coat.
Still debating on which gun. I've seen that DYC spray gun direction from dipyourcar.com but it seems pricey considering the specifications on that gun.
Some people have been suggesting the Wagner Control Spray MAX is a good starter gun, cost $100-$120. While the DYC spray gun cost $150, has less psi, and less uh.. something else, less powerful motor or something.
THis is all new to me.
Old Oct 23, 2014 | 04:20 AM
Freemananana's Avatar
When you paint over plastidip, it has a harder time peeling off. It is a real pain in the butt. Either plastidip it or paint it, not both.
Old Oct 29, 2014 | 02:57 AM
vrhyan's Avatar
It can be done but I've heard that it is a PITA to remove a paint over plastidip finish.
tweensquirt
Paint and Body
Mar 19, 2012 06:20 PM
97Ej6mike
Paint and Body
Oct 2, 2007 10:47 AM
dd_jdm
Paint and Body
Sep 14, 2007 08:11 AM
REDTOPAlchemy
Dec 10, 2004 02:05 PM
DA KING
Apr 10, 2004 05:23 PM
