Remove all clear coat?
Old Aug 10, 2014 | 02:35 PM
slogfilet's Avatar
Default Remove all clear coat?
I'm doing a budget respray on my VX due to massive clear coat peelng and some (previously unknown) Bondo that gave way.
Do I need to completely sand away the clear coat in order to respray, or is it sufficient to sand smooth, removing all bubble and feathering the edges of the peeled areas?
I'm using Rustoleum to respray. Yes, I'm cheap. It's my daily driver that gets me from point A to point B. If it hold up for a couple years, I'll be happy.
Old Aug 11, 2014 | 07:40 PM
Hidenplanvew's Avatar
Default Re: Remove all clear coat?
yes sand a feather 600-800 grit
Old Aug 20, 2014 | 12:45 PM
sleeps's Avatar
If the clear is not peeling you can just scuff those areas, where it is peeling you will need to take it down and the area around it. I suggest at least 400 grit wet or 600 dry. Then just paint over that. Should hold good.
Old Aug 20, 2014 | 04:55 PM
94 accord typeR's Avatar
i painted my car with very little prep and it chips exposing the factory paint job underneath.
"prep is the key to a good/decent paint job."
-everyone LMAO
kitt
Paint and Body
Apr 30, 2010 04:02 AM
skier4life0315
Honda Civic (2006 - 2015)
32
Mar 10, 2009 09:42 PM
MSchu
Paint and Body
Nov 2, 2008 04:16 PM
djtony5
Welding / Fabrication
16
Feb 7, 2007 11:49 AM
