What oil pan are you using?
I would assume that most are running a baffled pan? Just curious as to what one you are using or your opinions on the different ones. I know there is Mugen, Moroso, Canton, PWJDM and Fastline Performance that are a self install into an OEM pan, Spoon, TODA... there's a lot lol.
Re: What oil pan are you using?
OEM. But I did just purchase a brand new Moroso baffled oil pan for $63, can't beat that steal of a deal. Gotta love craigslist. I've been running the OEM pan for 4 years on track and never had an issue.
I had issues pre-baffles with my OEM pan... Added the baffles and now havn't had an issue since... however I am in need of an oil pressure gauge soo... I can't prove it's working yet.
-Teal... Who just realized he should get an Oil pressure gauge....
Mine:
Mine:
Z10 Engineering 5 QT pan with oil levels at 5.5 quarts i was still losing pressure.
Ditched the z10 pan and bought an OEM pan, Ed Sackly welded baffles and haven't had a issue since. Constant pressure in and out corners, thanks Ed! I've heard good things about the Mugen pan, however its costly. If you want to spend a little more look into the Canton Oil pans.
P30 Pan w/baffles
B16 999000 rev to the moon
Gauge indicated proof...
P30 Pan w/baffles
The road race (steel) pan just has a kick out for the extra capacity and doesnt hang any lower than a stock pan. The aluminum one I think might hang lower. But the al one shouldn't be used for a RR car anyway IMO.
i should have my pan down in a couple weeks (silly blowed up motors). if you haven't decided yet, i'll take some pix of the baffles and trap doors.
I am going on vacation for a month starting tomorrow so I'm in no rush lol. I like the idea of the Moroso having the oil drainback and temperature bung already welded in, seems like a great way to run a return off of a oil cooler and of course monitor temperature without having to tap into something. Only problem being they are $250 and that's not exactly what I would like to spend lol.
250 seems like a good deal to me. Just ordered my moroso.I'm interested in seeing how it seals because my oem one has always leaked a small amount even after many attempts and methods used to fix it.
old oil pan was smashed pretty bad, got the moroso baffled replacement.. love it! Oil I run the Castrol Edge and k&n filter.. puts up with track days and I drive there and back.. good stuff!
moroso baffled road race pan.
no leaks or issues at all. does not hang any lower or fit any differently than stock (except for kick-out).
i also run the moroso road race 5.5 quart pad. never any problem. for some reason takes almost 6 quarts to fill.
side not, i could not run the stock b18c pan, would not clear my z10 block girdle.
