DA Integra's Only
Old May 4, 2012 | 05:42 PM
  #51951
mebarsh's Avatar
Default Re: DA Integra's Only
Found this in the back of my Da I bought. Name:  IMAG0087.jpg
Old May 4, 2012 | 10:21 PM
  #51952
kevster's Avatar
well arent you lucky!!!
Old May 5, 2012 | 05:39 AM
  #51953
OldSkoolDa91's Avatar
hey guys i'm sellin my 90-91 innovative billet engine mounts. if anyone's interested, let me know. askin $250obo
Old May 5, 2012 | 01:45 PM
  #51954
Mattb16teg's Avatar
Community Builder
Community Influencer
Originally Posted by g2_teg_
i am a k-series fan. and love to see them in DAs. hate them in EFs, however.
Hahah why no in EFs?
Old May 5, 2012 | 05:15 PM
  #51955
kevster's Avatar
whats up every one?
anyone here ever changed valve seals? easy? hard?
Old May 5, 2012 | 08:48 PM
  #51956
Lord Helmet's Avatar
Originally Posted by kevster
whats up every one?
pretty simple IMO. Make sure you don't drop the valves into the combustion camber if you plan to replace them with the head on the engine.
It would be better and easier for YOU to remove the head off prior to replacing the valve seals.
Remove the timing belt, camshaft holders, camshafts, valve spring keepers, valve springs, then using some needle nose pliers, pull then off the valves.
Install is easy too, by using the same pliers press the seals in, it should "click in" when you press. Don't go crazy or you will destroy them. BTW don't mix up the intake and exhaust valve seals up either, there is a difference.
On a scale on 1-10 I'd give it a 8 because it's not like you're installing a strut bar or header. It's more critical because you are going into internal engine parts that MUST be installed perfectly the first time, or you will DESTROY that engine quickly.
Old May 5, 2012 | 10:41 PM
  #51957
kevster's Avatar
good tips. thank you sir! ive got experience with the bigger things like pulling motors, trannys, suspension etc but never really did the small pieces like valve train. thanks again for the tips. wish me luck
Old May 6, 2012 | 06:31 AM
  #51958
g2_teg_'s Avatar
hood clearance. im pretty sure a k24 fits under a DA hood. a k20 doesnt even fit under an ef hood.
Old May 6, 2012 | 07:10 AM
  #51959
Brice.Hayden's Avatar
Surprised no one has tried the J32 yet
Old May 6, 2012 | 08:00 AM
  #51960
g2_teg_'s Avatar
...in a da? I'm sure someone has.
Old May 6, 2012 | 08:11 AM
  #51961
I bet you're shittin kittens right now with the way the O's have been playing
Old May 6, 2012 | 04:20 PM
  #51962
g2_teg_'s Avatar
how bout them o's?!?!
Old May 6, 2012 | 07:26 PM
  #51963
Bond's Avatar
Fits tight in my buddies CRX. When switched to the Sir front end it now fits well and no clearance issues at all. Much more room now. I can't imagine an EF being too far off, so it would be a squeeze for sure.
Just picked up another DA. Thats 3 DA's I have now. This one is only for parts. The body is rusted out and it's an auto. I'd love to save it, but have no time.
Old May 6, 2012 | 07:48 PM
  #51964
Ef9vsDa9's Avatar
i want that lip!
Old May 6, 2012 | 10:26 PM
  #51965
RABI_T89's Avatar
Old May 6, 2012 | 10:55 PM
  #51966
kevster's Avatar
that photo makes it look like a dent?
swaped out my tails for a set that doesnt leak in water (in theory). Deleted my cruise control
Old May 6, 2012 | 11:43 PM
  #51967
Bond's Avatar
New one of my DD
Old May 7, 2012 | 06:20 AM
  #51968
Mattb16teg's Avatar
Community Builder
^ Looks great!
Old May 7, 2012 | 06:29 AM
  #51969
RABI_T89's Avatar
That's a shadow..
Old May 7, 2012 | 07:27 AM
  #51970
kiDchaos's Avatar
for sale?
Old May 7, 2012 | 09:35 AM
  #51971
Corey R's Avatar
I had this problem before, it isn't actually the taillights, its the foam gaskets. $30 for a pair from the dealer that can save you from water damage.
Old May 7, 2012 | 11:58 AM
  #51972
Bond's Avatar
^ Looks great!
Thanks. The offset just fits in the fenders. Great running car that's served me well so far.
Old May 7, 2012 | 01:59 PM
  #51973
kevster's Avatar
ahhhh well we will see how this goes, the tailights came with rubbers and look better.
whats up everyone
Old May 7, 2012 | 02:09 PM
  #51974
g2_teg_'s Avatar
a k24 doesnt fit under any ef hood. k20 fits under the jdm hood or the $700 fiber images hood but thats a ridiculous cost to pay in order for your hood to shut.
K24 fits under a stock DA hood if you just cut some of the webbing. Thats a very serious advantage in my opinion.
Old May 7, 2012 | 05:59 PM
  #51975
Bond's Avatar
Ya I know. I was talking about a K20 in my buddies CRX. We found a Sir front clip for $300 locally. We looked at the fiber images hood and our jaws dropped. I can't imagine putting a K24 in a EF/CRX without it looking retarded.
I swapped a K24 from a crashed TSX in a friends EP3. We found a civic si 6speed trans at a wrecker with a cracked case. Swapped cases and as good as new. That mod was the best thing we ever did to that car. It now had torque and made driving an EP3 fun.
I can imagine that setup being a blast in a DA.
