DA Integra's Only
Old Mar 1, 2012 | 05:56 AM
  #51176
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: DA Integra's Only
Originally Posted by 92NoTeC
Basically the following:
81.5mm stock block LS
Eagle Rods
Mahle Pistons
AEBS head studs
B16 head
Blox Type A cams
Rocket Motorsports valvesprings/retainers
Edelbrock Victor X intake manifold
Blox 72mm throttle body
RLD Fab turbo manifold
T3/T61 turbo (basically a SC61)
Full-Race backdoor intercooler
Custom 3" exhaust and 3" intercooler piping
My setup needs a complete overhaul, mainly in the block department, and I was having issues with head lifting last year so I turned the boost down, but the setup tuned by me on Crome made 433whp at 18psi.
Very similar setups and very similar power
81.25mm stock block LS
Eagle H beam Rods
ACL race Bearings
SRP 9:1 Pistons
ARP head studs and Rod bolts
Ported B16 head
GSR cams
Blox dual springs and titanium retainers (left over from previously running Pro1s)
Stock S2000 Throttle Body
Garret 61mm Turbo
Tial 44mm WG
Tial 50mm BOV
CXRacing IC
S300
Custom 3" exhaust and 2.5" intercooler piping
Precision 1000s
Walbro255 LPH
Old Mar 1, 2012 | 06:05 AM
  #51177
kiDchaos's Avatar
Originally Posted by gsilnc
ill check that out
just a thought but i would also check out your tranny fluid level. If its low or even out of fluid the first thing ive experienced is that it would start to kick you out of fifth when cruising at 60mph.
Old Mar 1, 2012 | 06:15 AM
  #51178
92NoTeC's Avatar
Nice Mattb16teg.
Here's minez, before and after tuning. It's been a while as you can see by the dates.
Old Mar 1, 2012 | 06:40 AM
  #51179
Mattb16teg's Avatar
Community Builder
Nice! Holy crap, what was going on with the red line pull?
Old Mar 1, 2012 | 06:53 AM
  #51180
Ax3l's Avatar
Anyone happen to have a set of taillights in good condition for my 91' GS they are willing to part with and ship to Norway? (There is no market for these cars in Europe, so i have to get all my parts from USA)
(I'm not sure if i need the 90-91 or if the 92-93 with amber indicators fit without any issues?)
I'm also in the market for a tailgate in good condition, although i suspect shipping cost to Norway would be horrible... lol.
Let me know.
Old Mar 1, 2012 | 07:55 AM
  #51181
92NoTeC's Avatar
Unadjusted cam gears and super advanced timing from incorrectly adjusted distributor.
Let me know.
I haz a decent set of 90-91 tails available. Shipping will probably be in the $40 range though. I could probably do $80 shipped in your case?
Old Mar 1, 2012 | 08:49 AM
  #51182
Ax3l's Avatar
Awesome! Pm'ed you.
Old Mar 1, 2012 | 09:40 AM
  #51183
OldskoojdmDA9's Avatar
^ PM'd you
Old Mar 1, 2012 | 10:16 AM
  #51184
problems:
it has a short shifter that likes to pop out of 5th when im cruising at 60 (anyone ever had this problem or know how to adjust it?)
Like kiDchaos said transmission fluid levels could be a factor, definitely check that first. Like Bond as well, if the short shifter is installed correctly then you really shouldn't have issues with it being the cause of popping out of gear. The way to check this is to see [underneath] if it hits the exhaust piping or it the bushings are loose/not tightened down causing it to sit uneven/at an angle.
Another strong thing to consider is the transmission's synchros itself. Depending on your year, transmission type and mileage, 5th gear LS synchros are notoriously know for going out. When I first got my car, the LS tranny I had was good for about a year and then I had issues with it popping out of gear even when the tranny fluid levels were good and what not. I just ended up switching transmissions.
Previously noted suggestions:
Originally Posted by Bond
It's possible that your short shifter is hitting the exhaust and causing it to pop out. Does it ever rattle when this happens? Really if the shifter is installed correctly there is no adjusting you can do. Hope that helps
Old Mar 1, 2012 | 03:25 PM
  #51185
gsilnc's Avatar
will do thanks guys
washed... need a front lip
Old Mar 1, 2012 | 04:36 PM
  #51186
92NoTeC's Avatar
Pretty clean. Looks like quite the blank canvas from a modding standpoint.
Old Mar 1, 2012 | 05:55 PM
  #51187
JDM'd OUT's Avatar
[QUOTE=562db2jdmjunky;46922120]daily driven.
QUOTE]
Is that an EK mugen lip?
Old Mar 1, 2012 | 07:07 PM
  #51188
Brice.Hayden's Avatar
i highly doubt it. looks like a JDP lip in flat black or a replica.
Old Mar 1, 2012 | 07:47 PM
  #51189
FelipeIsJDM's Avatar
Password JDM makes a very similar lip. It's actually made for the DA.
Old Mar 1, 2012 | 07:55 PM
  #51190
hb420's Avatar
Nope it's neither of those, look at the center section, it overlaps the bumper.
Old Mar 1, 2012 | 08:05 PM
  #51191
90HondaDA's Avatar
Matt i had issues with the top hitting the hood latch looks like yours sits right beneath that. .. did you have this issue at first?
Old Mar 1, 2012 | 08:06 PM
  #51192
hb420's Avatar
I tried to buy a 93 db1 today but it was sold tonight fail
Old Mar 1, 2012 | 09:05 PM
  #51193
gsilnc's Avatar
if anyone has got a 90-91 front lip lying around feel free to pm me
Old Mar 1, 2012 | 09:12 PM
  #51194
hb420's Avatar
I just threw one away damm i could of just gave it to you. it was a little beat up though
Old Mar 1, 2012 | 11:05 PM
  #51195
Hey guys, I have a few things for sale if you're interested.
• OEM black floor mat set (complete, coupe hatch)
• 2 sets of 90-91 coupe/hatch tail lights
Had it posted on G2IC as well, but I guess it's down for the weekend
http://forums.nwp4life.com/zerothread?id=32474&page=1
Old Mar 2, 2012 | 04:20 AM
  #51196
Mattb16teg's Avatar
Community Builder
Ehh, I don't know, just pull it down! LoL. How tall is your IC? Mine is a foot tall.
I was able to drop mine down some because I have a JDP lip which covers my IC and traction bar, would look weird without lip.
Mine sits right at the bottom of the latch now after making brackets for it and all.
Old Mar 2, 2012 | 05:07 AM
  #51197
92NoTeC's Avatar
Damn. 12" is just too big (that's what she said).
I also have a few things for sale if anyone wants to check them out: http://hondamarketplace.com/showpost...postcount=5996
Old Mar 2, 2012 | 08:11 AM
  #51198
90HondaDA's Avatar
yeah i think mine is the same size but i don't have a lip kit just the stock lip, its ok we got a tad smaller one ordered and will be here monday
Old Mar 2, 2012 | 11:24 AM
  #51199
i highly doubt it. or a replica.
Old Mar 2, 2012 | 06:41 PM
  #51200
imcnblu's Avatar
I don't know if I posted in here or not, but here's my DA.
Car Details:
92 Integra GS
JDM B18C (SiR, with Y80 LSD transmission)
Custom 3" intake with velocity stack
4-1 header with 2.5" collector
Vibrant 2.5" high flow cat
Greddy SP2 exhaust system
Hasport Motor mounts
Innovative Cable to Hydro conversion kit
RyWire VTEC conversion harness
Koni Yellow Shocks
Ground Control coilovers (380F/450R)
Suspension Techniques sway bars
Energy Suspension bushings (EVERY bushing available is in this car's suspension)
5Zigen FN01R-C wheels with lip color matched in B62-P Captiva Blue Pearl(+42 offset) (original version, not the "hot version" that is available now)
BF Goodrich G-Force Sports (205/45-16)
HIC JDM replica window visors
JDM Thin Moldings
JDM Side Markers
JDM 1pc headlights with Raybrig bulbs
pics:
rolling shot on the way to last year's East Coast Honda Meet
some shots from my visit at CNC Engine Dynamics in Winchester, VA for some baseline pulls
Other shots:
some goodies that are about to go on in a few weeks:
JDP Engineering OE2 Carbon Fiber front lip
VIS Side skirts (aka mugen replica skirts)
*sorry, no pics*
JDM ITR cams and valve train
First gen Skunk2 Intake manifold (no brand logo, etc.)
*no pics, it's in my basement*
having my throttle body bored by maxbore.com (tapered from 67mm-to-64mm)
Being tuned by Chris Miller of GetPowerhouse.com and CNC Engine Dynamics (look him up, he's one of the best available) using Hondata s300.
