DA Integra's Only
Old Jul 26, 2012 | 08:29 AM
  #52426
Ax3l's Avatar
Default Re: DA Integra's Only
^Pretty cool ^
Tell us about the hole in the foglight? Custom intake duct? Also what wheels are those\spec?
Old Jul 26, 2012 | 08:40 AM
  #52427
hb420's Avatar
When did you get the oem rear lip, looks good.
Old Jul 26, 2012 | 09:49 AM
  #52428
1ac4u2nv's Avatar
Originally Posted by Ax3l
^Pretty cool ^
Thanks. Yes it's an intake duct. I made the hole to feed some more air to the turbo. Wheels are 15X7 + 34 Nippon MAG1 (MA86).
Thanks Herb, I picked up the skirts, and rear lip for $80.00 last month lol. I knew a guy that had them stored away. He needed cash asap, and it worked out for me in the end. I even had door caps which were found in a junkyard, but I sold those.
Old Jul 26, 2012 | 10:48 AM
  #52429
tougetuned_ef's Avatar
Originally Posted by Bond
Get on it! Hope it solves all your problems.
so this morning i had my girl drop me off at 7:30 so i could do this in the shade. the car was pointed east so the sun wasnt beating on me the whole time. i jacked the car up on 4x4's since i dont own a jack to put it on jack stands. once i had the tank resting on more 4x4s i jacked the car up on the low side to slide the tank out. everything came apart pretty easy. it has def been done once before cause it was missing a few bolts and the one hose's clamp was in a different place than before. it fired right up and i drove straight to a gas station. tank took 10.95 gallons. almost completely empty. the car wouldnt even fire up when i first got there.
so i drove it around for about 20 min and then headed down the canyon towards salt lake. usually by the time i got off at my exit it would want to stall out. this time it ran strong with no signs of lacking power. even got up to 100mph to just put it through its paces and see if i could make the problem happen again. im still going to swap out the cat. my brother said that it is a "carsound" high flow cat. cheap is the other word he used. so i have an oem 00' si cat with maybe 30k on it that im going to install soon. i will keep you all posted on wether or not it happens again.
old pump. the filter sock looked like hell. nice and brown!!!
Old Jul 26, 2012 | 11:07 AM
  #52430
Originally Posted by 1ac4u2nv
I have not posted here in a while. My bucket after installing my side skirts and OEM optional rear lip. Also added a Corbeau Forza seat.
oh and this da is beautiful!!! what color blue is that? im digging the trunk spoiler!
Old Jul 26, 2012 | 11:39 AM
  #52431
1ac4u2nv's Avatar
Thanks, it's Laguna Seca Blue.
Old Jul 26, 2012 | 02:00 PM
  #52432
very nice! what part of pa you from? i used to live outside of philly same as herb (hb420) but now im in slc ut and herbs in louisville.
Old Jul 26, 2012 | 04:41 PM
  #52433
thedb63's Avatar
Originally Posted by 92NoTeC
Looks boss. I've never seen the fuel pressure regulator hooked up in that manner. Can you take some close up pics?
Originally Posted by Mattb16teg
Lookin good! What ITBS are those?
obxR they are just like the toda ones....they have a lifetime warrenty
Originally Posted by be18see1
I did this and it worked very well. I like it nice and natural
ok will do thanks guys
Old Jul 26, 2012 | 05:35 PM
  #52434
1ac4u2nv's Avatar
Thanks again. I am from the Lehigh Valley, Allentown area. Most DA's look like hell around here lol.
Old Jul 26, 2012 | 06:23 PM
  #52435
DASquareOne's Avatar
Originally Posted by Lord Helmet
I use to have that issue too. I just wired the turn lights aka city lights into parkngs lights and just used my lower bumper lights as turn signals. that solved my issues.
You can wire the bumper lights to the turn signal in the one-piece via jumper wires. Nobody will see it since it's hidden inside the bumper and behind the headlights. Both will blink when you hit the turn signal stalk.
I'm quite sure there's plenty of other ways to do it.
Thanks ill try that. aha
I hate when it happens because it does it randomly and people are probably like why is this idiot signalling right while trying to turn left.
Old Jul 26, 2012 | 06:56 PM
  #52436
Mattb16teg's Avatar
Community Builder
Community Influencer
Yikes, good luck with those ITBS! They are small diameter right?
Heard you need to take them apart and put them back together like all other OBX parts, LOL!
Old Jul 27, 2012 | 02:31 AM
  #52437
@Db1teggy's Avatar
Can some one help I have a db1 1991 the issues I'm having are e-brake light is on anti-lock and my car idles
Please and thank you
Old Jul 27, 2012 | 03:56 AM
  #52438
Ax3l's Avatar
Check the e-brake switch? That could be the issue.
And what is the problem with your idling? If it idles, that's good, or what?
Old Jul 27, 2012 | 05:16 AM
  #52439
thedb63's Avatar
yeah people were having really bad fitment issues to...but we will see i had no fitment issues and took a few screws out and they all had threadlock on them...and they are lifetime warrenty so if there are any issues then i will just take them back.....i will let you know how they work when i get it tuned....im rocking toda head parts and toda spec b cams so i think i will hit some where around 215ish at the wheels..if that happens i will be very happy!
Old Jul 27, 2012 | 07:52 AM
  #52440
kiDchaos's Avatar
low brake fluid????
Old Jul 27, 2012 | 08:26 AM
  #52441
Mattb16teg's Avatar
Community Builder
Any port work? What manifold and header?
What pistons?
215 seems like a stretch on Spec B's if I recall them correctly. Remember too, these are smaller ITBS, so peak power won't be where you are picking up the most gains with these.
Old Jul 27, 2012 | 12:54 PM
  #52442
so far so good with the pump! ive put about 50 miles on it so far without any hesitation or lack of power. and today was the up hill test since i have to drive 25 miles uphill to get to work. now i just got to figure out this exhaust issue. its still changing exhaust notes when the car has been running for a little. i thought before it was because it wasnt getting enough fuel but now im almost positive it has something to do with the cat. i dont have to be at work till 3 tomorrow so im going to try and get up early and swap it out for the oem one i have. im hoping the exhaust will be much quieter than it is right now.
Old Jul 28, 2012 | 07:58 AM
  #52443
Lsvtec_Integra's Avatar
been awhile since ive been on. any of the old DA squard members still around?
Old Jul 28, 2012 | 08:17 AM
  #52444
jasperDA's Avatar
Heres my teg with the pancake racing/hiro wing painted
Old Jul 28, 2012 | 08:24 AM
  #52445
this makes me want thin side mouldings.
Old Jul 29, 2012 | 12:05 AM
  #52446
@Db1teggy's Avatar
I wanna put some pics of my 91 db1 how does this wrk/:
Old Jul 29, 2012 | 12:07 AM
  #52447
@Db1teggy's Avatar
Idk man some one said I might be low on brake fluid??
Old Jul 29, 2012 | 12:51 AM
  #52448
Ax3l's Avatar
So check if the fluid is low?
Old Jul 29, 2012 | 06:24 AM
  #52449
oh boy! i can tell a lot of people are being really patient right now.
if someone told you this than check it. really easy, just remove the cap and look. check the lines coming out of the master cylinder and make sure there are no leaks. pull off the parking break handle cover between your seats and make sure the little white button that it triggers is moving in and out freely, make sure you parking break is not pulled up and making this light stay on! oh and there is also a search option at the top of the page that might be of some use!
oh and use this. im not sure if you will have more or less questions after going through this page but its worth a shot.
https://honda-tech.com/forums/acura-integra-6/all-gen-integra-%5Bfaq%5D-diy-write-ups-how-etc-2419202/
Old Jul 29, 2012 | 06:33 AM
  #52450
i use photobucket.com upload pics to photobucket and use the img code that each pic has and copy paste it to here.
