DA Integra's Only
Old Apr 22, 2011 | 06:42 AM
  #47026
be18see1's Avatar
Default Re: DA Integra's Only
Originally Posted by Mattb16teg
Anyone put a manual EF rack in their car?
I've seen someone document this before, probably on G2IC. I think something is different with the bushings so you have to shim it out to compensate, but I'm not sure.
Old Apr 22, 2011 | 09:19 AM
  #47027
Mattb16teg's Avatar
Community Builder
Community Influencer
Yes, that's what I was looking for.
I just wanted to know if anyone has done it in case I had questions.
Old Apr 22, 2011 | 10:50 AM
  #47028
tougetuned_ef's Avatar
hey guys i have a few questions.
can i run without the front crossmember motor mount? will this effect anything and is anybody else running without one and have you had any problems?
does anybody know where i can get the engine bay stickers at? i got the made in japan one off clean and the denso one off clean too. but the caution danger one from the rad support on the left shredded when i tried to take it off. i would like all new stickers if possible cause the made in japan one is kinda faded.
does anybody have the rubber fuel line that goes from the firewall hardline to the fuel filter? mine had a huge split in it and its discontinued from the dealer.
Old Apr 22, 2011 | 12:06 PM
  #47029
be18see1's Avatar
1.) I have never run one but the car has Innovative mounts.
2.) Dealer?
3.) Pick and pull!
Old Apr 22, 2011 | 12:29 PM
  #47030
g2_teg_'s Avatar
G2Guru
http://forums.g2ic.com/showthread.ph...+steering+rack
Old Apr 22, 2011 | 02:28 PM
  #47031
2.) Dealer?
3.) Pick and pull!
noe of the junk yards within 10 miles has a da. has anybody used a fuel line from another integra or civic and been sucsessfull?the one from a 00si wont work. its hardlined right up to the bottom of the filter. do fuel filters have to be upright? if not i could use the 00 si filter it would just be sticking straight out and would prolly touch the tb
Old Apr 22, 2011 | 03:11 PM
  #47032
Mattb16teg's Avatar
Community Builder
I've always ran one and honestly wouldn't but that's just me. People will argue both ways. I just bought a new OEM unit and filled it in with epoxy, working pretty well thus far.
Originally Posted by g2_teg_
Cool, he is still around and active?
Old Apr 22, 2011 | 03:19 PM
  #47033
be18see1's Avatar
Well I can't even if I wanted to because hydro trans don't have a mounting location.
Old Apr 22, 2011 | 03:48 PM
  #47034
hb420's Avatar
There's a teg in shorty's about 4 in harry's and and two more in a yard in roxborough
Old Apr 22, 2011 | 07:07 PM
  #47035
be18see1's Avatar
done annnnnd done.
Old Apr 22, 2011 | 07:36 PM
  #47036
are any of them open tomorrow? im going to get up early and head up if they are.
Old Apr 22, 2011 | 07:51 PM
  #47037
hb420's Avatar
Yeah they are all open, if you go to the place in roxborough hit me up.
Old Apr 22, 2011 | 10:42 PM
  #47038
bonspeed's Avatar
Originally Posted by z0om
The b17a upper bracket, and people say, the b16 upper bracket from the Integra XSi works too. This makes it bolt up like factory stock. Finding one of those isn't trivial.
This is what it looks like with the pump bolted solid to the lower LS bracket, but with a P72 upper (94-01 GSR). There's ~9mm gap.
Some people use washers to fill the gap, then a pry bar to adjust belt tension (because tension bolt doesn't line up).
this answers my thoughts... the reason I asked you if you use your GSR PS pump brackets on my first post is because I'm having trouble with my PS pump and bracket, I'm currently working on my EJ6 and the upper PS pump bracket that i have is like yours and it didn't fit my P72-2 pump. now i know why because it's from a B17 GSR... I always thought all b series vtec PS pump bracket are all the same, and they're not...
Old Apr 23, 2011 | 06:22 AM
  #47039
i dont think im going today cause of the rain. i also have to go do a drain cleaning at someones house. i need the money more than i need that fuel line at this point.
Old Apr 23, 2011 | 04:17 PM
  #47040
90_DA's Avatar
here's my da6, installed my old vis racing cf hood today.
Old Apr 23, 2011 | 04:22 PM
  #47041
Bond's Avatar
Damn looking good chris!
We will need to do a photoshoot with your DA and my EF sedan. I was out in langley getting these off of jason.
Needs a wet sand and quick polish
Old Apr 23, 2011 | 04:50 PM
  #47042
Mattb16teg's Avatar
Community Builder
Well the block has a hairline crack in Cyl 1.
Lasted me 6 years, saw nitrous, high compression and turbo, so no complaints here.
Looks like I need to find another LS block.
Funny though the thing made power with the cracked sleeve!
Old Apr 23, 2011 | 05:24 PM
  #47043
be18see1's Avatar
Keep the block and just get it sleeved. Then you'll never have to worry about that again! Well, hopefully.
Old Apr 23, 2011 | 07:59 PM
  #47044
my buddy has a b16 block and crank for 150$ and i just pulled my ls. had low comp in 2 cyl, but when i had the head off about 400 miles ago it looked good. only thing about it is a very small chip in the top of the no 3 cyl. its on the outside of the cyl tho. i think it was a factory defect. i am willing to part with it. just need a day or 2 to think about it. and you are not too far so i would meet you. make me an offer if you want it. this motor ran great when i pulled it. do you have an obd1 b16 ecu or and obd1 b16 iacv because i will make some kind of deal with you.
Old Apr 23, 2011 | 08:34 PM
  #47045
OldSkoolDa91's Avatar
got to see jj and his car again today at a dyno day. i always love lookin his car over even though i've seen it before. wish we'd have had more time to talk n chill though
Old Apr 23, 2011 | 08:48 PM
  #47046
tegman23's Avatar
I doubt they are open on easter man
Old Apr 23, 2011 | 08:50 PM
  #47047
tegman23's Avatar
Thanks man, I always think my car looks like garbage, but alot of people said it was nice today, so it makes me feel good lol
Old Apr 23, 2011 | 08:54 PM
  #47048
Mattb16teg's Avatar
Community Builder
Would love to but really don't have the money to invest in it, along with new pistons, etc. It's a street car for the most part and makes enough power on the street.
The crack may have been there before this build because I just changed everything out with the block in the car so i COULD have missed it.
Damn, wish I woulda made it up!
Old Apr 23, 2011 | 10:11 PM
  #47049
hb420's Avatar
Still have to finish polishing the driver headlight, that's why it looks like that. I put the wheels on today to see how they look. Still waiting on parts to come in so it didn't get started yet. In a perfect world it would all be done this week and i would get to take it to the big yearly sonic meet this weekend even though it needs a paint job
Old Apr 24, 2011 | 04:33 AM
  #47050
that was on friday when i posted that. but i am going to harbor freight im a little bit. they are having a 25% off any one item sale. prolly going to go get an engine stand finally. they are $54 regularly for a 700lbs one.
