DA Integra's Only
Old Apr 14, 2010 | 03:37 PM
  #38376
kNOwLedGe.'s Avatar
Default Re: DA Integra's Only
Originally Posted by Mattyg2
I still wonder how my exhaust sounds from the rear, in car it's really quiet.
It sounds really deep and quiet until you hit...
Uhhhh.
Old Apr 14, 2010 | 04:14 PM
  #38377
negusjuda's Avatar
Originally Posted by projectTeG
yea all i did was shrink the battery and move it down i got all the room i need and the smaller civic battery.
im also looking into doing this with my battery i was wondering how people did that in the da what is it sitting on the crossmember
Old Apr 14, 2010 | 04:16 PM
  #38378
negusjuda's Avatar
and as far as portflow goes i went with them because im only running the skunk2 tuner stage 1 cams and i seriously doubt i will be up grading only thing im upgrading is from a da to a rsx later lol also how important is balancing crank rods and pistons because i didnt balance them in my build just wondering what will be the negative effect of not doing it
Old Apr 14, 2010 | 04:28 PM
  #38379
projectTeG's Avatar
i never balanced anything. i just got my arp's pressed in, the rods refreshed and checked for weight and that was it. i do 8500 limiter, but i shift around 8200.
and yea my battery just sits on the crossmember i just fabbed up a little hold down for the batter and everything works fine. only reason i did this is because i wanted alittle but more length from my intake and didnt want it as long a a cai.
Old Apr 14, 2010 | 04:44 PM
  #38380
negusjuda's Avatar
yea i wanna do it because i have that velocity stack and the filter for it is huge and also i didnt balance because i was told it wasnt necessary for what my plans are even though i went with je pistons and eagle rods i just dont want my motor to fail because i didnt and i also dont feel like ripping the block apart just to balance pistons rods and crank and find out it didnt need it
Old Apr 14, 2010 | 04:48 PM
  #38381
projectTeG's Avatar
the cranks is fine, all i would have suggested was to weigh the rods and see if they are within the weight of each other. the the same for the pistons. but you should be fine.
Old Apr 14, 2010 | 05:01 PM
  #38382
negusjuda's Avatar
lol its gonna bug me til i rip it back apart and check then it will be next year when i finally get the motor in the car but oh well
Old Apr 14, 2010 | 05:28 PM
  #38383
Mattb16teg's Avatar
Community Builder
Community Influencer
They also make battery mount kits to mount the battery on the frame. Think I may need to do some fab work to fit my Intercooler piping in there.
I've never balanced anything either, revved my old setup to 9k(yes it made power).
Old Apr 14, 2010 | 05:31 PM
  #38384
95-db6-719's Avatar
Originally Posted by Mattb16teg
Portflow springs are aftermarket. They should be fine.
IMO 3 inch on that setup would be too loud and too useless. Not a crazy enough build to warrant 3inch and it is going to be a DD.
Pro 1's FTW
Thanks!
OEM open ended lugs?! There is such a thing?!
umm, I think you should be fine but in order to put the studs in you have to press the hub off the knuckle so you might as well do it then. Would probably ride a bit smoother.
haha thanks man,yeah i can get you a picture if you like..?
Old Apr 14, 2010 | 05:33 PM
  #38385
95-db6-719's Avatar
you need to balance everything that is going to be attached to the crank in one way shape or form, such as the rings and all if you want to be exact.
Old Apr 14, 2010 | 05:42 PM
  #38386
Mattb16teg's Avatar
Community Builder
Yea please, I wanna see them!
  #38387
negusjuda's Avatar
yea i think im just gonna leave it im not reving much past 8k anyway
Old Apr 14, 2010 | 05:54 PM
  #38388
95-db6-719's Avatar
To showed the are radius'd
Old Apr 14, 2010 | 06:32 PM
  #38389
90IntegraTuner's Avatar
Uhhhh.
Nice...deff gonna look into that and the WS2...if Ketchup posts one more time we need to tell him to report to the EG crew cause hes gay...end of story :-D
Old Apr 14, 2010 | 07:06 PM
  #38390
DA is best's Avatar
Old Apr 14, 2010 | 07:25 PM
  #38391
projectTeG's Avatar
opened oem lugs were on accords anfd civ ic
Old Apr 14, 2010 | 07:26 PM
  #38392
projectTeG's Avatar
lol, ive never balanced rings
Old Apr 14, 2010 | 08:30 PM
  #38393
95-db6-719's Avatar
well if you want to get technical you should
Old Apr 15, 2010 | 02:59 AM
  #38394
be18see1's Avatar
Where did you read that? Spoon groups their pistons into batches by weight but I've never heard about them doing a thing with rings, much less anyone else.
Old Apr 15, 2010 | 03:12 AM
  #38395
negusjuda's Avatar
oh well its not balanced lol but its gonna get driven
Old Apr 15, 2010 | 03:14 AM
  #38396
ethnic99's Avatar
u rekon these ground control coilovers sitting on a new set of pedders struts,shocks and bumps stops would make my ride bumpy as ****?
Old Apr 15, 2010 | 04:12 AM
  #38397
hb420's Avatar
What ground controls? I hope you don't think that pic you posted is ground control, and I have no idea what type of shocks you are talking about.
Old Apr 15, 2010 | 04:16 AM
  #38398
Mattb16teg's Avatar
Community Builder
Yea.........
LoL those coils are straight EBayyyyyyyyy!
Def get those man, they will ride like your on air!
*air = a farm road with potholes, divots, sinkholes, missing parts and a lot of speed bumps!
Old Apr 15, 2010 | 05:38 AM
  #38399
tegman23's Avatar
LOL matt...
I always balance my rings with my rotating assembley
Old Apr 15, 2010 | 06:52 AM
  #38400
Mattb16teg's Avatar
Community Builder
JJ, I only have a few big things left to buy, then it's just minor stuff like oil lines and such.
Think I found a deal on some precision 1000's for $210.
