DA Integra's Only
Old Apr 14, 2010 | 09:50 AM
  #38351
DumaDA's Avatar
Default Re: DA Integra's Only
you'd need a distributor jumper harness to run the obd1 dizzy too right?
Old Apr 14, 2010 | 10:05 AM
  #38352
90IntegraTuner's Avatar
Originally Posted by negusjuda
oh trust me im in the mountains of north east pa i know about the potholes now my car isnt the best looking i decided to do my motor instead of looks and as far as thieves they are everywhere even up here where im at in the sticks lol
I completely agree...anywhere you go you have to worry about thieves but just a tad bit more in the cities...i have been trying to invest in a decent alarm system but i really don't care if this car gets stolen because it is barely holding together...until I can get a few things done to her this summer then it will be worth it :-P
Old Apr 14, 2010 | 10:15 AM
  #38353
DumaDA's Avatar
check out hookedontronics.com if you want to pick up an alarm
Old Apr 14, 2010 | 10:17 AM
  #38354
Mattb16teg's Avatar
Community Builder
Community Influencer
Originally Posted by projectTeG
i would say ditch the springs, get some good aftermarkets(rockets, omni, supertech, skunk.) run the rsx-s retainers for clearance of larger cams. i would do this just to enable you to run larger cams easier.
i would ditch the tanabe too, my set-up gain alot just from changing my hks hipower exhaust piping from the cat to the rear axle to 2.5in, the hks was 2in in that section. the rest is 60mm.
a nice 3in exhaust would do your engine well.
Portflow springs are aftermarket. They should be fine.
IMO 3 inch on that setup would be too loud and too useless. Not a crazy enough build to warrant 3inch and it is going to be a DD.
Originally Posted by tegman23
Yeah im pretty sure he has a b20...and yeah dude I would look at other cams for all-motor
Pro 1's FTW
Originally Posted by gsilnc
just use bleach dude... took me like 5 mins
works like a charm
edit: didnt see all the last page nvm
Thanks!
Originally Posted by 95-db6-719
i am pretty much gonna be doign the same, i order the same studs, new oem open end lugs, does everyone suggest replacing the wheel bearings, i only have 78k on my gsr..?
also do you have to press the hub off the knuckle to replace studs on integra's??
OEM open ended lugs?! There is such a thing?!
umm, I think you should be fine but in order to put the studs in you have to press the hub off the knuckle so you might as well do it then. Would probably ride a bit smoother.
Old Apr 14, 2010 | 10:18 AM
  #38355
negusjuda's Avatar
wanna help me pay for new set of cams lol
Old Apr 14, 2010 | 10:21 AM
  #38356
negusjuda's Avatar
im not a fan of pro1's if i did upgrade it would be to tuner 2 i have seen many setups make more power with tuner 2 over pro1 so the pro 1's are out also my build is a budget build i cant spend more then i spent already so what ever it turns out to be is what its gonna be this isnt a race car its my daily driver so if i get anywhere in the 185-200 range i reached my goal and i know i can get the 185+ mark hell i see stock bottom end b20vtecs with type r cams make 180-185
Old Apr 14, 2010 | 10:41 AM
  #38357
negusjuda's Avatar
https://honda-tech.com/forums/showpo...postcount=1288
now not to really compare his motor to mine but it isnt really that diffrent besides compression but thats what a 5 hp diffrence if that i think my build will be ok for my goal
Old Apr 14, 2010 | 11:12 AM
  #38358
kNOwLedGe.'s Avatar
Not if you know how to pin your OBD1 distributor into your OBD0 harness.
When I swapped an OBD1 engine into my OBD0 car and converted to OBD1, I didn't use a distributor jumper because they didn't exist back then. I knew some guys at a shop that did it for me.
Old Apr 14, 2010 | 11:49 AM
  #38359
Mattb16teg's Avatar
Community Builder
I'd prefer Pro1's over Tuner 2's anyday! Show my some of these setups where they made more power.
I mean how much did you spend on your cams? You can get the Blox P-1's (which are the same as Pro 1's) for a decent price.
That setup from the link is pretty decent.
Old Apr 14, 2010 | 11:53 AM
  #38360
negusjuda's Avatar
i paid 300 for cams and gears i got em off a buddy of mine
Old Apr 14, 2010 | 11:56 AM
  #38361
negusjuda's Avatar
the skunk 2 stage 2 are a better daily driving cam then the pro 1 only diffrence is the primary lobes on the pro1 are slightly bigger then the tuner 2 but the vtec lobes are the same so the pro1 have a slight better mid range but i have seen tuner2 make more peak power over pro1 my car is a daily driver so i would choose the tuner 2 over the pto1
Old Apr 14, 2010 | 11:57 AM
  #38362
negusjuda's Avatar
one is better mid range while the other is better peak power. drag racing i would also go with tuner 2 over pro1 due to the higher peak power pro1 are gread for autox and road race apps though
Old Apr 14, 2010 | 01:01 PM
  #38363
Thanks man...deff gonna check that out this summer
I will bring this up again...is anyone (besides Herb) selling any parts? I need two doors, a hood, a wingless hatch, and a full interior if possible (black preferred)...or if you know any of your buddies lemme know...deff going to fix up this car this summer...also what exhaust would you guys recommend? N/A, nice sound, not raspy and ricey...and deep preferred
Old Apr 14, 2010 | 01:04 PM
  #38364
DumaDA's Avatar
buddy club spec 2, lol
Old Apr 14, 2010 | 01:07 PM
  #38365
I was looking at that or a WS2...a buddy of mine had a Thermal R and D but that thing was rediculously loud (didn't help he had the test pipe on)...any other ideas from previous owners?
Old Apr 14, 2010 | 01:08 PM
  #38366
DumaDA's Avatar
for me personally i like a car's exhaust to be quiet, so i just have 2.25" piping to a stock muffler with a 2.25" outlet
Old Apr 14, 2010 | 01:22 PM
  #38367
negusjuda's Avatar
the buddy club spec 2 is louder but i like it lol
http://www.youtube.com/watch?v=4qgN1aVvPkE
Old Apr 14, 2010 | 01:28 PM
  #38368
gsilnc's Avatar
exactly what i got... its quiet... but you still get that raspy sound
Old Apr 14, 2010 | 01:41 PM
  #38369
DumaDA's Avatar
what do you guys mean by "raspy" exactly
Old Apr 14, 2010 | 01:47 PM
  #38370
ketchup!'s Avatar
get a ws2 noob
Old Apr 14, 2010 | 01:49 PM
  #38371
Mattb16teg's Avatar
Community Builder
^^^ Video is raspy
Old Apr 14, 2010 | 02:09 PM
  #38372
Mattyg2's Avatar
I still wonder how my exhaust sounds from the rear, in car it's really quiet.
Old Apr 14, 2010 | 02:16 PM
  #38373
da9leo's Avatar
I <3 DA's
OEM dont count
Old Apr 14, 2010 | 02:55 PM
  #38374
projectTeG's Avatar
Originally Posted by kNOwLedGe.
That's odd. Why anyone would want to put more weight in the front of the car on a car that's so front biased is beyond my knowledge. If anything, you want to remove weight from the front to get better weight distribution.
I doubt you'll be doing any type of road racing/auto-X so I guess it doesn't matter.
yea all i did was shrink the battery and move it down i got all the room i need and the smaller civic battery.
Old Apr 14, 2010 | 02:58 PM
  #38375
projectTeG's Avatar
but portflow if i remember correctly is only alittle bit stiffer than the oem itr and tend to coil bind earlier. but as far as the 3in, yea its true it would be loud, but anything na is going to be a tad on the annoying side. hell my hks exhaust with a hi-flow cat a 18in resonator( replacing smaller res.) the stock hks resonator at the rear axle and the hks muffler, my ***** still loud...
ive switching from my previous header to my rmf the exhaust got even louder..
