DA Integra's Only
Old Mar 31, 2010 | 07:54 PM
  #37901
kNOwLedGe.'s Avatar
Default Re: DA Integra's Only
you like what you like. who cares why?
its like talking **** on papa johns cause you like Pizza hut or Dominos
So ironic coming from you.
Old Mar 31, 2010 | 08:02 PM
  #37902
Brice.Hayden's Avatar
me? NO.
you just can't like Rotas or Sportmaxx's or Drag wheels. other than that you're ok.
Old Mar 31, 2010 | 08:11 PM
  #37903
b16-ef-si's Avatar
^LOL so tru
were u in cali last week by any chance?
Old Mar 31, 2010 | 09:28 PM
  #37904
Rene1123's Avatar
Hey was wondering what color this DA is
Old Apr 1, 2010 | 08:33 AM
  #37905
gsilnc's Avatar
olive drab metallic pearl? lol.. my best guess
Old Apr 1, 2010 | 08:35 AM
  #37906
DumaDA's Avatar
Originally Posted by Mickeeezy
I actually like the 92-93 oem bumper lights. Anyone want to buy amber bumper lights for 20 bucks? Pm me!
you're from san jose, i'll buy it from you today, i need some ASAP
Old Apr 1, 2010 | 10:18 AM
  #37907
OldSkoolDa91's Avatar
Originally Posted by teggi
when the radiator is full no but as soon as it gets like half ways it starts to do it........still dont know y its eating up the coolant tho
is your water pump leaking? any of your hoses? radiator or radiator cap?
Old Apr 1, 2010 | 11:29 AM
  #37908
Mickeeezy's Avatar
so i have this problem....
Old Apr 1, 2010 | 11:38 AM
  #37909
Originally Posted by projectTeG
shoulda went boost....
ouch. what happened?
  #37910
1200 Hobos's Avatar
Sagging exhaust? Take it to any muffler shop, tell them how you want it, problem solved. $20 or less.
Old Apr 1, 2010 | 12:33 PM
  #37911
teggi's Avatar
idk about the pump, but the hoses or radiator are all good. jst got a radiator not too long ago cuz the old one had two nasty wholes in it........the weird thing is the the valve cover has foam build up... there is also some water in the oil
Old Apr 1, 2010 | 12:54 PM
  #37912
kNOwLedGe.'s Avatar
WOW!
You have that ghetto *** muffler and piping, but you have HKS tips.
Go figure...
Old Apr 1, 2010 | 01:05 PM
  #37913
DumaDA's Avatar
are you sure that your headgasket is good...
Old Apr 1, 2010 | 01:09 PM
  #37914
projectTeG's Avatar
to be honest with you. i have no clue. the engine started loosing power within a few months after building it. my compression was 220 which is still good, i just wanted to through some better rings in it because i was burning oil the supplied rings with the pistons i got were trash.
long story short i was running 82mm npr pistons which from what i was told were the best cast oem piston i could get. appartently either i detonated like crazy or they were shitty pistons. im running towards both, because i have heard of others having similar problems with these and they later fixed the problem by moving the top ringland down.
i now have rs machine 82mm pistons on their way and i have cp rings.
im hoping the engine will be stronger, because i had these problems since i built the engine and i was running 100mph traps in the quarter,
Old Apr 1, 2010 | 01:27 PM
  #37915
negusjuda's Avatar
that sounds like a head gasket unless your block is cracked which is worst
Old Apr 1, 2010 | 02:00 PM
  #37916
Mickeeezy's Avatar
For now, I'm using a clothes hanger to keep the tip from dragging.
I'll probably bring it in tomorrow with the $20 bucks Duma is giving me for the bumper lights.
Originally Posted by kNOwLedGe.
WOW!
Go figure...
I got the car exactly the way it is for $400 so im not trippin too hard.
Old Apr 1, 2010 | 02:16 PM
  #37917
teggi's Avatar
the headgasket is good, took the head off last night cuz i thought it was gonnna be that but nope. headgasket is good.
my brother inlaw said that the head might be warped a lil.
if the block is craked them i'm Fd!
Old Apr 1, 2010 | 02:21 PM
  #37918
DumaDA's Avatar
any of you guys ever wrap your headliner or door panels?
Old Apr 1, 2010 | 02:37 PM
  #37919
kNOwLedGe.'s Avatar
Cool deal
I know some folks that would pay half of what you paid for the car for just those exhaust tips.
Old Apr 1, 2010 | 03:02 PM
  #37920
nah you can pick up a block for a good price usually. same with if your head is warped, you can easily pick one up for cheap. not many people want ls's anymore...
Old Apr 1, 2010 | 03:07 PM
  #37921
teggi's Avatar
hmmmm i dont remember seeing any cracks tho
Old Apr 1, 2010 | 03:21 PM
  #37922
Mattb16teg's Avatar
Community Builder
Community Influencer
ok so i took off the head to see if the head gasket was blown but its not
i still dont understand y its eating up the coolant :/
So you just took the head off, looked at it and said it was good? How did you come to the conclusion that the head gasket is good?
I hope you put another NEW head gasket on when you put the head back on the block!!
If your head is not badly warped you can easily get a machine shop to resurface it for you for a decent price.
Old Apr 1, 2010 | 03:24 PM
  #37923
95-db6-719's Avatar
So i am going against what everyone has told me, as i do my 94 LS swap in my 90 RS. I am using the injectors and manifold from the LS, its quite simple actually theory and operation over rule experience anyday. The LS injectors will work with the system as long as the resistor box is taken out of the equation. The specification for the LS injectors is 10-13 ohms. The specification for the RS injectors is 1.5-2.5 ohms, +the resistance of the resistor box. My resistor box has a resistance of roughly 6ohms. So the total for the RS injector system is 9 ohms.
The LS injector will get that same amount of voltage wired to the RS obdo harness as it did in the LS harness. The injector is a ground side switch from the PCM(ECU). Only thing the PCM does is command it on by making a ground connection. You can always give an injector less current as long as it is enough to command the injector on, you never want to give it to much, though as it will fry.
This is what i researched in my Automotive Electrical class today. lol
Old Apr 1, 2010 | 03:31 PM
  #37924
teggi's Avatar
cleaned the head gasked, checked it very close, flipped it over and checked it again. also checked the head and block. spent like an hour looking at those 3. no i didnt put a new headgasket, i'm not gonna drive the car for a few days so its good. (how much is for a new one anyway?)
Old Apr 1, 2010 | 04:23 PM
  #37925
be18see1's Avatar
Tried my door panels once. You can't remove them on da's like on other cars, so it's tricky to get them to look right without any edges hanging out. Mine looked like ****.
