Painting intercooler
Old Apr 29, 2006 | 11:54 AM
Schurke's Avatar
Default Painting intercooler
Planing to paint the intercooler black (stealth). What technique did you guys use? What kind of paint? Any other information regarding the topic would be great as well. Thank you.
Old Apr 29, 2006 | 11:59 AM
boostedK20a2's Avatar
Light coats of radiator paint.
https://honda-tech.com/zerothread?id=1100466
https://honda-tech.com/zerothread?id=1006221
https://honda-tech.com/zerothread?id=578472
Old Apr 29, 2006 | 12:00 PM
purpleh22's Avatar
Default Re: Painting intercooler (Schurke)
I used high temp flat black that is used for wood stoves and their pipes. Doesn't have to be high temp. I'd think that thicker paints (like some enamel) might not be best.
Old Apr 29, 2006 | 12:01 PM
tallyturbo's Avatar
Default Re: Painting intercooler (purpleh22)
i used spraypaint. just sprayed one side of the intercooler that way if i dont like it later on i can always flip it around.
Old Apr 29, 2006 | 12:02 PM
Schurke's Avatar
I know you can anodize an IC... but whats involved in this procedure? is it costly? From what I hear it's the best route to take.
Old Apr 29, 2006 | 12:29 PM
tallyturbo's Avatar
i painted mine and havent had probs. the paint like to chip after a couple hunderd miles. oh well.
Old Apr 29, 2006 | 12:50 PM
Circuit Star-29's Avatar
Default Re: Painting intercooler (tallyturbo)
no matter how much paint you apply, you will not effect the the cooling properties of the intercooler...
Krylon is what I used.
Old Apr 29, 2006 | 01:28 PM
AIRIC's Avatar
Default Re: Painting intercooler (Circuit Star-29)
im painting mine white to go with my white hatch....going to be sick
Old Apr 29, 2006 | 01:44 PM
GS-R Civic's Avatar
Default Re: Painting intercooler (AIRIC)
Light coats of regualr spray paint, although it does chip off after a while. Just reapply another coat as needed.
Old Apr 29, 2006 | 02:03 PM
Schurke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schurke &raquo;</TD></TR><TR><TD CLASS="quote">I know you can anodize an IC... but whats involved in this procedure? is it costly? From what I hear it's the best route to take.</TD></TR></TABLE>
Old Apr 29, 2006 | 04:14 PM
deryck324's Avatar
the only thing that i have heard of that has no problems in the long run is powder coating it
Old Apr 29, 2006 | 05:04 PM
KeyserSoze's Avatar
Wow, there are quite a few threads on this. Search first, really.
https://honda-tech.com/zerothread?id=1574575
https://honda-tech.com/zerothread?id=1029419
https://honda-tech.com/zerothread?id=1422021
https://honda-tech.com/zerothread?id=1321526
https://honda-tech.com/zerothread?id=1243354
https://honda-tech.com/zerothread?id=1171704
https://honda-tech.com/zerothread?id=942296
And then some.........GL.
PS - Anodizing will cost you ~$100.
Old May 6, 2006 | 10:06 PM
mattcivic's Avatar
Default Re: (deryck324)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deryck324 &raquo;</TD></TR><TR><TD CLASS="quote">the only thing that i have heard of that has no problems in the long run is powder coating it</TD></TR></TABLE>
hhmm we have a powder coater at work and a special type of black that has a wrinkle texture to it. im gunna have to try it out and see.
Turbo Neon
Nov 5, 2007 04:53 AM
jdmcivicb16a2sc61
Mar 28, 2006 01:41 PM
Offer
Mar 2, 2006 09:41 AM
89SiR
Dec 21, 2002 03:03 PM
Kamin
Dec 20, 2002 01:30 PM
