Holset users unite!
Old May 19, 2006 | 06:24 AM
  #1101
splitime's Avatar
Default Re: (Si Shane)
HE351CW specs... straight from Holset... I emailed them last night.
"60mm inducer / 85mm backface. The tubine housing is a 9cm^2.
Turbine wheel is a 65mm backface / 58mm inducer. "
Old May 19, 2006 | 07:06 AM
  #1102
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">Still having some issues with my setup but the 9cm^2 hy spools super fast. Once I hit 3300rpm the thing just winds up, and depending on what gear I'm in boost comes on soon. I have 10lb at just about every highway speed in 5th gear, and from 3300 and up there is pleanty of posotive pressure to make this thing zoom off. </TD></TR></TABLE>
what r u using to tune it&gt;? any datalogs...id like to compare them w/ my logs and see the changes between the 12cm & 9cm housing....
and that compressor map looks awesome...much better than any hx35 map ive seen....but then again like all holsets they like high pr's....15psi+ and that thing is gonna rip bigtime!
Old May 22, 2006 | 08:57 AM
  #1103
SL0WEGG's Avatar
Default Re: (drumking15)
what would you guys recommend for a 2jzge?? i'm thinkin hx40
Old May 22, 2006 | 04:16 PM
  #1104
MrBond's Avatar
Default Re: (boostedej1)
I got a test on my audi today...
2008cc, hx35w , 12cm housing, split pulse...
ITS MAD!
I can tell you that much, the internal wastegate is worth ZERO.
even with pressure directly to the actuator, it kicks up to 30+psi !
And guess what. 30psi at 3500rpm !
Old May 22, 2006 | 06:48 PM
  #1105
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">what would you guys recommend for a 2jzge?? i'm thinkin hx40 </TD></TR></TABLE>
hx35 turbine w/ a hx40 compressor...or basically the new he35^ that he was talkin about above
Old May 22, 2006 | 06:49 PM
  #1106
drumking15's Avatar
Default Re: (MrBond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrBond &raquo;</TD></TR><TR><TD CLASS="quote">I got a test on my audi today...
heh can i use that in my defense....some newb said holset's couldnt spool because they were meant for 6 liter diesel trucks....need i say own'd!!!
cant wait to see the finished setup....bettin the split scroll is def helpin that thing light up!
Old May 22, 2006 | 06:50 PM
  #1107
wantboost's Avatar
Who is Mr Robot?
looks like i may be using a holset on a 2.7 liter porsche 4 cylinder. strictly track only car (road race)
Old May 22, 2006 | 06:51 PM
  #1108
blundar's Avatar
expletive that. HX50/HX55 for a 2JZ. Supra has a LOT more displacement and a I6 configuration that is ideal for pulse converter divided housing manifolds.
One of the local turbo guys has been stuffing HX50 wheels/shaft in a HX35 housing for diesel guys competing in the "stock" turbo class events. 1200whp from a B1 (aka 5.9L) Cummins motor. Hmm. Apparently lose 200-300 RPM spool time and get one hell of a lot of flow increase...
Old May 22, 2006 | 06:55 PM
  #1109
drumking15's Avatar
Default Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">expletive that. HX50/HX55 for a 2JZ. Supra has a LOT more displacement and a I6 configuration that is ideal for pulse converter divided housing manifolds.
One of the local turbo guys has been stuffing HX50 wheels/shaft in a HX35 housing for diesel guys competing in the "stock" turbo class events. 1200whp from a B1 (aka 5.9L) Cummins motor. Hmm. Apparently lose 200-300 RPM spool time and get one hell of a lot of flow increase...</TD></TR></TABLE>
Holy bejesious!!! id love to see that....screw hx35/40's hybrids....be baller and run a 50...
Old May 22, 2006 | 07:53 PM
  #1110
CoreyR's Avatar
im getting pretty excited i won a what looks to be good condtion, HX35W on ebay for $200. stock JDM GSR/B16 tranny with a HX35 on 10 psi in an EF hatch should feel nice. cant wait till i get this setup in.
definatley a good idea to make a divided manifold though right?
Old May 22, 2006 | 08:13 PM
  #1111
TallKyle's Avatar
Default Re: (CoreyR)
what do you guys think of a HC1 on a built D16A6??
Old May 22, 2006 | 11:09 PM
  #1112
SwappedTURBOegg's Avatar
Default Re: (TallKyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallKyle &raquo;</TD></TR><TR><TD CLASS="quote">what do you guys think of a HC1 on a built D16A6??</TD></TR></TABLE>probbaly be nice. abit laggy... but if you rev the thing out abit you should make LOTS of power. make sure you get one with a 9^cm housing
Old May 23, 2006 | 04:45 AM
  #1113
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">
definatley a good idea to make a divided manifold though right?</TD></TR></TABLE>
nice find!!! the split pulse mani will help it spool up a few hundred rpm quicker...so it really doesnt hurt to be built that way....but itll also run fine in a 4-1 merge collector
Old May 23, 2006 | 07:03 AM
  #1114
TallKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">probbaly be nice. abit laggy... but if you rev the thing out abit you should make LOTS of power. make sure you get one with a 9^cm housing</TD></TR></TABLE>
yea, the kid said its a 12cm housing. He wants 250 bucks, its brand new. i think i will give it a shot.
Old May 23, 2006 | 07:19 AM
  #1115
SL0WEGG's Avatar
Its actually an is300 where in the world would i be able to find a hx50?
Old May 23, 2006 | 10:20 AM
  #1116
Dan GTiR's Avatar
ITS MAD!
DAM!!!!!!!!!!! That's some good spool up
I am wondering if I could get this sort of spool on my GTiR motor????
Any input appreciated.
Dan.
Old May 23, 2006 | 02:57 PM
  #1117
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallKyle &raquo;</TD></TR><TR><TD CLASS="quote">yea, the kid said its a 12cm housing. He wants 250 bucks, its brand new. i think i will give it a shot.</TD></TR></TABLE>
itll spool just like a sc61 on a dseries....prob full boost around 5600-6k....and make sure you exh is very free flowing...dont want anything that is gonna choke it down anymore
Old May 25, 2006 | 12:52 PM
  #1118
trevahhhh's Avatar
well its no honda but i thought i would post up some pics anyways
next to a t04
Old May 25, 2006 | 12:53 PM
  #1119
trevahhhh's Avatar
woops ... forgot a pic
Old May 25, 2006 | 06:03 PM
  #1120
Joseph Davis's Avatar
Default Re: (trevahhhh)
Why did you even bother making that manifold split turbine?
PS - rode in Speed Phreak's CRX Sunday. Two liters, 1800 lbs, and 9 psi was enough to put a vapid look of disbelief on the face of a C6 owner.
Old May 26, 2006 | 05:30 AM
  #1121
robus's Avatar
Hey if you change that housing I'm def interested in the 12^cm one.
hadronfly &lt;at&gt; yahoo.com
Old May 26, 2006 | 05:31 AM
  #1122
robus's Avatar
...or anyone else for that matter: I am looking for a 12^cm or even better a 14^cm housing, for a H2C.
Old May 26, 2006 | 05:43 AM
  #1123
robus's Avatar
Default Re: (robus)
While I'm at it I might as well post the H2C compressor map (from Holset). It's quite an old model! Got a brand new one for 150 bucks.
Old May 26, 2006 | 05:49 AM
  #1124
RACEPAK's Avatar
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Why did you even bother making that manifold split turbine?
.</TD></TR></TABLE>
i think that the manifold is splited too.
Old May 26, 2006 | 07:37 AM
  #1125
trevahhhh's Avatar
.</TD></TR></TABLE>
cause some people look for every little extra bit ? and why not do things the right way ? im not saying just slapping one of these on a regular t3 flanged log manifold is the wrong way .. but there are cerntainly better ways of doing it . and yes the manifold is split
1 nad 4 into one side .. 3 and 2 into the other thats the reason for the funky wastegate pipe
